Acknowledged
CIQQA-3370
Instinct 3 Solar has System.DeviceSettings.isTouchScreen in Simulator and on Device
The Instinct 3 Solar exposed the System.DeviceSettings.isTouchScreen-property. It is set to false, but this property is widely used to discern device that have a touch-screen from devices that do not have a touch screen.
In my opinion it should not be exposed on devices that don't have a touch-screen.
The property is exposed in the simulator and on device for the Instinct 3 Solar.
Parents
  • but this property is widely used to discern device that have a touch-screen from devices that do not have a touch screen.
    Are you sure about that? "Widely used..." according to who? chatgpt? DeviceSettings.isTouchScreen is unsuitable for this purpose, for 2 reasons:
    - it's actually present on all CIQ devices (see below)
    - if it's true, it means that a touchscreen is present and is enabled in settings. if it's false, it means that *either* a touchscreen is present (and is disabled in settings) or there is no touchscreen
    isTouchScreen has been available since CIQ 1.2.0, and is present on every single Connect IQ device afaik.
    For example, FR920XT - an 11-year old watch with no touchscreen - has the isTouchScreen property, at least according to the simulator.
    As a matter of fact, I'm almost certain that every single device supported by Connect IQ has the isTouchScreen property.
    There's two ways to figure this out:
    1) From the docs:
    - all CIQ devices have CIQ 1.2 or higher (there's a page in the CIQ dev docs site that confirms this)
    - the CIQ documentation for isTouchScreen says that's it's available since API 1.2 (https://developer.garmin.com/connect-iq/api-docs/Toybox/System/DeviceSettings.html#isTouchScreen-var)
    - there is no "supported devices" list in the isTouchScreen doc (which is what you'd normally see if a given field was excluded for some devices, especially if it's on any other basis than minimum API level)
    2) Search the device library (installed alongside the SDK) as follows:
    - String to search for: symbol="isTouchScreen"
    - Files to search: *.api.debug.xml
    You will see that every single CIQ device has the isTouchScreen symbol.
    As a counter-example, search the same files for symbol="requiresBurnInProtection". You will see that not all devices have this symbol.
    isTouchScreen by itself just means you can check if a device has a touch screen or not.  It's value determines if it's touch or not
    To be more precise: isTouchScreen is "true if the device has a touch screen and it is enabled in settings, otherwise false"
    This is an important distinction, as it's certainly possible for a 5-button device like FR265 or Fenix 7 to have a touchscreen, but the touchscreen is disabled in settings, in which case isTouchScreen would be false. Probably not a great choice of field/property names.
    Ofc you and I know this, but someone who is new to CIQ might just take what you said at face value.
    After all, OP's implicit goal is to figure out whether a device has a touchscreen or not, and the isTouchScreen property is simply not enough.
    - if it's not present, you can be sure that the device does not have a touchscreen
    - if it's present and true, you can be sure that the device has a touchscreen and it's enabled
    - if it's present and false, you have no information about whether the device has a touchscreen. All you know is that either the device does not have a touchscreen, or the device has a touchscreen and it's disabled
Comment
    1) From the docs:
Children
No Data
