Environment
- Device: Instinct 3 Solar 45mm, firmware 15.19
- Connect IQ SDK: 9.3.0 (2026-10-20), device files updated 2026-11-04
- App type: watch-app, permissions Background + Notifications
Summary
On a physical Instinct 3 Solar 45mm, Notifications.showNotification() works when called from the foreground app but shows nothing
when called from a background service (onTemporalEvent), even though the background event demonstrably runs.
Background.requestApplicationWake() shows its prompt, but with no vibration or tone. As a result, a Connect IQ app has no way to
alert the user at a scheduled time while the app is closed on this device (Attention is unavailable in the background).
Steps to reproduce (minimal app attached: source + NotifyTest.prg built with SDK 9.3.0)
1. Open NotifyTest and press SELECT. The app calls showNotification() from the foreground.
Result: the notification shows and the watch vibrates. Works.
2. Press DOWN. This registers a temporal event 5 minutes ahead. Exit to the watch face and wait. In onTemporalEvent the service
writes a timestamp to Storage, then calls the same showNotification().
Result: nothing is shown, no vibration. On reopening the app, the line "bg: <time> notify" shows that the background event ran
at the expected time.
3. Press UP. This registers a temporal event 5 minutes ahead that calls Background.requestApplicationWake(). Exit to the watch face
and wait.
Result: the "launch app?" prompt appears, but with no vibration and no tone, so it goes unnoticed unless the user is looking at
the watch.
Simulator
- The instinct3solar45mm profile (also instinct3amoled45mm) in SDK 9.3.0 has no "notification" layout in simulator.json; fenix847mm
has one.
- Any showNotification() call on the instinct3solar45mm profile crashes simulator.exe (minidump written to
%TEMP%\com.garmin.connectiq\GARMIN\Debug\ERRLOG.*.dmp). The same app works on fenix847mm.
Expected
A notification posted from a background service is shown on the device and respects the user's vibration/tone settings, as it does
from the foreground and on other API 5.1+ devices. Failing that, requestApplicationWake should vibrate/beep per the user's alert
settings.
Why it matters
Reminder, medication, interval and timer apps need to alert the user at a set time while the app is closed. On the Instinct 3 this
is currently impossible: background code can't use Attention, background notifications don't appear, and the wake prompt is silent.
NotifyTest-repro.zip
6605284
in reply to jim_m_58
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
6605284
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
