Ticket Created
WERETECH-7046
info.maxCadence reporting odd values in Edge Explore (fw 4.10.0.0)
Is anyone aware of any issues with the API reporting odd values for info.maxCadence on some Edge devices?
I have a user running one of my datafields on an Edge Explore with firmware 4.10.0.0. My datafield is just displaying the value returned from info.maxCadence, no tampering at all.
maxval = info.maxCadence != null ? info.maxCadence : 0;
Before starting the activity the user gets a max cadence of 65535 and it will remain the same until the activity starts.
Once the activity starts the value will change, but only to match the average cadence value all the time.
In summary:
1- Before activity starts info.maxCadence returns 65535.
2- After the activity starts info.maxCadence returns exactly the same value as info.averageCadence.
I found in the forums another user reporting the same issue but on a different device, Edge 820:
https://ciq.forums.garmin.com/developer/connect-iq/f/showcase/5201/diy-data-field/55133#55133
In my case the user already tried with different cadence sensors (to discard a sensor issue) to no avail.
On my side I cannot repro the problem in the simulator nor on my Edge 520.
Any ideas? The odd values are coming directly from the API but I can't tell if it's a hadware (sensor, Edge) or software issue (firmware, ConnectIQ).
I can workaround this problem with some simple code, but that will only fix it for my app, while the issue may affect other users/developers as well.
Thanks.
Parents Comment Children
No Data
