Hi there,
Two of my apps (TrainingHR and InTheZone, that I've tested), both generate the following restart condition on an Edge 530. Completely reproducible. There is no error recorded in the App Logs, but there is a device error log (below). Both of these apps work absolutely fine in the simulator - no errors.
My App - In The Zone - has a main In App Settings menu containing 24 menu items. When I bring this menu up on the device (from an activity running the App - press SELECT, scroll down to "Data Fields", select Connect IQ fields, select In The Zone) and then scroll down off the 4 menu items displayed on the screen to something off the screen, say item number 7 or anywhere beyond that, select that menu option (might be a list or a stringpicker - doesn't seem to matter) and then press SELECT to return back to the main menu, you will notice there is no item with a visible focus. If you press the DOWN button, focus reestablishes and then you can move up and down the main menu and life continues. However, if you had pressed the UP button immediately after returning out of the sub-menu (before any main menu item had focus), then the device will completely and spontaneously restart. No App error is recorded. only the below, device log is recorded (err_log.bak)
In the simulator (for the Edge530) focus is never lost when returning from a sub-menu.
Are you able to decode this log file and find where the problem is?
Thanks,
Rob.
"unit_id":"3331654924",
"product_name":"Edge 530",
"software_part_number":"006-B3121-00",
"ms_since_epoch":1625974766000,
"system_version":"8.10",
"build_type":"PRODUCTION",
"backtrace":"
Function Address: 0x608ECB7A
Call Address at Function: 0x608ECBA4
Function Address: 0x6015453A
Call Address at Function: 0x6015454C
Function Address: 0x60441ECC
Call Address at Function: 0x60441F0E
Function Address: 0x60440E2C
Call Address at Function: 0x60440EFC
Function Address: 0x60A25C4A
Call Address at Function: 0x60A25CAE
Function Address: 0x60236494
Call Address at Function: 0x602365B6
Function Address: 0x602371A8
Call Address at Function: 0x602378B0
Function Address: 0x60255E74
Call Address at Function: 0x60255F04
Function Address: 0x6020BD3C
Call Address at Function: 0x6020BFB8
Function Address: 0x6020DFA8
Call Address at Function: 0x6020DFE6
Function Address: 0x602191A0
Call Address at Function: 0x60219576
Function Address: 0x60219D0C
Call Address at Function: 0x60219D98
"error_cause":"RTL Trap",
"proprietary_info":{
"Commit ID":"c1a051a53e1ae6a889b2a63d74dc8ab6ecb8ca34",
"Time":"2021-7-11 13:39:26",
"Project Specific":"2021-7-11 13:39:26",
"CDP_LOG":"605F8151,6045B5CD,605D9DCD,6061708D,600E2D69,602124B9,605D9DCD,6020DFA9,6020DFA9,6020DFA9,6020DFA9,6020DFA9,605D9DCD,602124B9,600E2D69,6061708D,600E2D69,602124B9,605D9DCD,6020DFA9,601CBB29,6020DFA9,6020DFA9,6020DFA9,",
"RTL Error Number":"6E5D8024",
"Error Message":"D0850110,00000000,01E8BA10,D0850110,D26DBB30,01E8BA00,0000FE4C,62F5D884,62F63814,62F639C4,000004C6,00000010,D0850120,62F5D674,00000000,608ECBA4,2001001F",
"Task Name":"CDP main",
"Saved SP":"62F5D674",
"Saved LR":"00000000",
"Saved PC":"608ECBA4",
"R[0]":"D0850110",
"R[1]":"00000000",
"R[2]":"01E8BA10",
"R[3]":"D0850110",
"R[4]":"D26DBB30",
"R[5]":"01E8BA00",
"R[6]":"0000FE4C",
"R[7]":"62F5D884",
"R[8]":"62F63814",
"R[9]":"62F639C4",
"R[10]":"000004C6",
"R[11]":"00000010",
"R[12]":"D0850120",
"R[13]":"62F5D674",
"R[14]":"00000000",
"R[15]":"608ECBA4",
"cpsr":"2001001F"
el34rob
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
el34rob
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
