Please add information about the possible system level and api level each device can have to:
https://developer.garmin.com/connect-iq/reference-guides/devices-reference/
For example:
Fenix 6:
min system: 4
max system: 5
min api: 3.2.0
max api: 3.3.*
(maybe the max values should only be set when Garmin has decided that a certain device will not get further updates)
The use case is that it can help developers to decide which devices they support. When they decided it can help optimizing code by excluding code that is "too new" for a device. For example there's no need for the following code on system 1 devices with max api level < 2.4.0, because they can never have Properties:
function setConfig(key as Application.PropertyKeyType, val as Application.PropertyValueType) {
if (App has :Properties) {
App.Properties.setValue(key, val);
} else {
App.AppBase.setProperty(key, val);
By knowing this we can save some precious bytes in the memory if we use:
(:system2)
(:system3)
} else {
flocsy🤠
in reply to jim_m_58
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
