Ticket Created
WERETECH-12673
Improve documentation: Add api levels and system levels to Device Reference
Please add information about the possible system level and api level each device can have to:
https://developer.garmin.com/connect-iq/reference-guides/devices-reference/
For example:
Fenix 6:
min system: 4
max system: 5
min api: 3.2.0
max api: 3.3.*
(maybe the max values should only be set when Garmin has decided that a certain device will not get further updates)
The use case is that it can help developers to decide which devices they support. When they decided it can help optimizing code by excluding code that is "too new" for a device. For example there's no need for the following code on system 1 devices with max api level < 2.4.0, because they can never have Properties:
function setConfig(key as Application.PropertyKeyType, val as Application.PropertyValueType) {
    if (App has :Properties) {
        App.Properties.setValue(key, val);
    } else {
        App.AppBase.setProperty(key, val);
By knowing this we can save some precious bytes in the memory if we use:
(:system2)
(:system3)
    } else {
Parents
  • But that list only has 1 version for each device. I thought it is the min api version, but I just realized that it's the max, because for FR245 it's 3.3.0, so it's pretty bad 'cause how can one guess what was the 1st (min) api version for a device?
Comment
Children
  • Yeah, but not having "double" code saves some precious bytes, that makes it possible to shrink the code enough to almost fit into 16K with some jungle magic.
  • With my apps, I usually use a min API level of 1.2, and based on which target devices I enable, can exclude some things - Like Garmin weather.  I don't even have targets that won't be 3.2.x or greater.  And even then, use "has" where needed  (if (Toybox has :Weather) {}), as that handles things like APAC devices that might not have something "today" but will next week, and I don't have to change anything.  The app adjusts without me worrying about the APAC FW releases....
    I think you're worrying about things you don't need to worry about with proper coding.
