I started with the BackgroundTimer sample project, and added a println to its BackgroundTimerServiceDelegate.initialize:
public function initialize() {
ServiceDelegate.initialize();
System.println(Application.loadResource(Rez.Strings.TimerExpired));
Now if I build and run the app, it prints out
Background: Your timer has expired!
(thats the expected output of the println)
But if I now add "import Rez" or "using Rez" to the top of the file, I get
Error: Illegal Access (Out of Bounds)
Details: Failed invoking <symbol>
Stack:
- initialize() at ./BackgroundTimer/source/BackgroundTimerBackground.mc:23 0x1000027a
- getServiceDelegate() at ./BackgroundTimer/source/BackgroundTimerApp.mc:64 0x10000042
Looking at Rez.mcgen, and the compiler's output at -g, it looks like background code is supposed to access BackgroundRez.*, and that the runtime somehow binds Rez to BackgroundRez while background code is running.
The problem, then, seems to be that "using Rez;" binds Rez at compile time, and so the background code is actually trying to access the foreground resources.
In fact, I can fix it by adding "using BackgroundRez as Rez" instead - but since BackgroundRez seems to be just an implementation detail (ie its not documented anywhere), it seems like a risky thing to rely on. Also, there could be shared code that runs in both the foreground and background - so its not necessarily clear which one to use...
And the *reason* for that "using Rez" is that Rez.Strings.foo without a using generates 20 bytes of code (and $.Rez.Strings.foo generates 26). But with the using its only 18. Its also faster because it looks up the Rez module directly.
7564012
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
7564012
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
