Ticket Created
CIQQA-756
Im starting... but...
Hello!
I install the Vs code and the monkey c extension, xml, xml tools, for debugging.
I did this "tutorial"
https://developer.garmin.com/connect-iq/connect-iq-basics/your-first-app/
but... when a try to do: ctrl'+shift+p "run teste, choose watch", then the iq opens and i can see the watch, but nothing happens... some times it give a "time out", but some times not... don't output nothing....
"WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5splus' (40x40). Image will be scaled to the target size."
see this image:
https://ibb.co/92ND7kQ
what i'm doing wrong??
it only shows a blue triangle...
it is very frustating that i cannot do a simple "hello world" ou a simples clock....
thanks!
Parents
    Former Member in reply to jim_m_58
    Hello!. OK, I do CTRL+F5 and the message is always the same "you don't have an extension for debugging xml... should we find...."
    i already have the XML from red hat and XML tools, but... i think the xml tools make the debugging... or not? because always says "you don't have an extension...."
    there's no step by step to use the visual studio plus monkey c to develop apps for garmin?? I know for eclipse...
Comment
Children
