Ticket Created
CIQQA-1326
HR zones are not working in simulator
In the simulator the following code:
var currentSport = UserProfile.getCurrentSport();
var heartRateZones = UserProfile.getHeartRateZones(currentSport);
Syste.println("HR zones:" + heartRateZones);
Always prints the following:
HR zones:[128, 153, 179, 204, 230, 185]
This itself has a bug: max_z5 < max_z4
However when I'm trying to set the HR zones in the simulator: Settings > Set User Profile > Heart Rate Zones:
The default values are: 94, 110, 130, 148, 167, 185
Which look OK, but when saving (or doing any changes and saving) doesn't have any effect on the output of the above code.
Parents
  • BTW there's another issue in the simulator HR zone editor: The header of the table looks like:
    Which is inconsistent with the documentation: https://developer.garmin.com/connect-iq/api-docs/Toybox/UserProfile.html#getHeartRateZones-instance_function where it has the following:
    The returned Array contains zone values as follows:
    • min zone 1 - The minimum heart rate threshold for zone 1
    • max zone 1 - The maximum heart rate threshold for zone 1
    • max zone 2 - The maximum heart rate threshold for zone 2
    • max zone 3 - The maximum heart rate threshold for zone 3
    • max zone 4 - The maximum heart rate threshold for zone 4
    • max zone 5 - The maximum heart rate threshold for zone 5
    So the simulator's table headers are 1 less than they should be: Instead of "Zone 0 min" it should be "Zone 1 min", etc...
Comment
Children
