Ticket Created
ACROPOLIS-3011, CASTOR-3047, VVA4-5395
Transferred
Gregorian.info() handles DST incorrectly for dates other than now/today (works in sim, not on device)
Related Issue
https://forums.garmin.com/developer/connect-iq/i/bug-reports/docs-for-gregorian-moment-imply-that-the-input-is-in-local-time-gregorian-info-and-utcinfo-suggest-otherwise
Description
Gregorian.info() handles DST incorrectly for dates other than now/today (works in sim, not on device).
In the sim, if I create a moment for some other date outside of the current DST/non-DST period, Gregorian.info() outputs local time correctly (with the correct adjustment/non-adjustment for DST).
On a real device, the same test will produce output which acts as if the supplied date is today, for the purpose of DST adjustment.
It's as if the device doesn't have/use TZ info for dates other than today, but the sim does.
(EDIT: of course, naturally this would work in the sim, as the underlying OS -- such as windows -- would have correct TZ/DST handling.)
Recreation Procedure
Create a simple data field with the following compute() method:
    function compute(info) {
        var timeInfo = new [2];
        var moment;
        // My timezone is Eastern Time
        // (On the current date (March 17), the timezone offset is UTC-4)
        // On December 1, the timezone offset is UTC-5
        moment = Gregorian.moment({
            // despite docs, this input appears to be interpreted as UTC time
            :year   => 2021,
            :month  => 12,
            :day    => 1,
            :hour   => 16,
            :minutes => 0,
            :seconds => 0
        timeInfo[0] = Gregorian.info(moment, Time.FORMAT_MEDIUM);
        // On July 1, the timezone offset is UTC-4
            :year   => 2021,
            :month  => 7,
            :day    => 1,
            :hour   => 16,
            :minutes => 0,
            :seconds => 0
        timeInfo[1] = Gregorian.info(moment, Time.FORMAT_MEDIUM);
        // On the sim this returns "Dec: 11 | July: 12", as expected
        // On a real 935 this returns "Dec: 12 | July: 12". The TZ offset
        // seems to be calculated from the current time/date, not the given time/date
        return "Dec: " + timeInfo[0].hour + " | July: " + timeInfo[1].hour;
On the sim this returns "Dec: 11 | July: 12", as expected. My timezone is Eastern Time, which is UTC-5 in December (DST) and UTC-4 in July (non-DST).
 On a real 935 this returns "Dec: 12 | July: 12". Today is March 17 and DST is active. The TZ offset used to calculate local time seems to be calculated from the current time/date, not the given time/date
Environment
- Windows 10
- VS Code
- SDK 3.2.5
- Garmin 935 21.00
  • I retested this on a real fr955 and the bug is still present.
    However, if you change the code to use a LocalMoment for NYC (JFK airport), which also observes DST/non-DST at different parts of the year, the bug is not present.
    function testDstBugLocalMoment() as String {
        var moment;
        var localMoment;
        // jfk airport:
        var nycLocation = new Location({
            :latitude =>  40.649546,
            :longitude => -73.7829489,
            :format => :degrees
        // get moment for 2021-12-01 16:00:00 UTC
            :year   => 2021,
            :month  => 12,
            :day    => 1,
            :hour   => 16,
            :minutes => 0,
            :seconds => 0
        localMoment = Gregorian.localMoment(nycLocation, moment);
        timeInfo[0] = Gregorian.info(localMoment, Time.FORMAT_MEDIUM);
        // get moment for 2021-07-16 16:00:00 UTC
            :year   => 2021,
            :month  => 7,
            :day    => 1,
            :hour   => 16,
            :minutes => 0,
            :seconds => 0
        // In both sim and real device located in Eastern timezone, on 2025-03-21 (EDT -04:00),
        // this correctly returns:
        // "(nyc): Dec: 11 | July: 12"
        return "(nyc): Dec: " + timeInfo[0].hour + " | July: " + timeInfo[1].hour;
  • An internal ticket has been created for this issue.
