Acknowledged
Given that a newer SDK is required to build for CIQ 5.x devices, what does this mean for existing apps on devices that were upgraded from CIQ 4 to CIQ 5 (e.g. FR955, Fenix 7, etc)? Do these apps just break?
Background:
- it has always by my understanding that if you build an app for a device with a given SDK, then that app should continue to work regardless of future firmware updates (in general). This ofc excludes situations where:
  - the new firmware update has a bug or breaking change
  - the existing app has a dormant bug which is exposed by a legit change in new firmware. e.g. newer firmware has a change where Weather.CurrentConditions.observationLocationName is null, and this caused several existing watchfaces to crash because they assume that field will never be null. But that's an application error, since that field has always been typed to be possibly null
- CIQ 5.* devices require various 7.X (or 8.X) SDKs to run properly
- Compilers have a check to ensure you don't try to build a a too-new device with a too-old device
- Due to a bug in this check, where older compilers (pre 7.2.0) seem to incorrectly believe that SDK version X can build any device with CIQ version X (or lower), it's possible for an SDK 6.X compiler to build an app for CIQ 5 devices. However, it's very possible that such an app will crash when it's run in the simulator or the device (we've already seen "bug reports" about this
- The existing crop of devices that came out with CIQ 4 (e.g. fr955, fr965, fenix7) have all been updated to CIQ 5. As far as I know, this is the first time that existing devices have received a major CIQ update since the move from CIQ 1 to CIQ 2.
- Someone in the CIQ team already clarified that CIQ 5 devices require apps to be built with newer SDKs.
So here's what I don't understand.
The two following statements seem to be mutually exclusive:
- If an app is built for a device with an existing SDK (e.g. SDK 6.4.0) it will continue (in general) to work on the device for all future firmware updates
- Devices with CIQ 5.* require a 7.X or 8.X SDK
The problem is that it was entirely possible to build an app for an fr955 (for example) with SDK 6.4.0 in the past, when fr955 was only on CIQ 4. If I installed such an app on my fr955 when it had CIQ 4, it would expect it to continue to work now that my device is on CIQ 5.
So how can it be possible that going forward, a 7.X or 8.X SDK is required to build for my fr955?
What am I missing? Has something also changed with the device files that's relevant here?
Parents
  • "If a device gets a system update, it should still be able to run any existing PRGs that are on the device. This is our intent, if this isn't the case then there's a bug."
    "You don't have to release a new app version every time a new device configuration is updated. What is on the store is expected to continue to work on device."
    Thank you for confirming that.
    As I mentioned, the prevailing (non-dev) forum "wisdom" is that the opposite is the case: devs have to be constantly updating their apps to keep up with device firmware updates. I've seen at least one comment to that effect from a Garmin support employee (with Garmin in username). (I don't have a link atm though)
    That's not to throw shade at anyone (or get anyone in trouble), just to point out that different divisions of Garmin may not have be speaking with a unified voice.
Comment
Children
  • It is not strictly required to update apps by building with a newer SDK from a technical requirement, but it also shouldn't break anything to do so and would ensure that any SDK bug fixes get built in. If there is a bug in the 6.4.0 SDK that is in your app then it won't ever get fixed until you build your app with a newer SDK that fixes the bug.
    So while it might make sense to update your apps for SDK updates it doesn't make sense to always update your apps for device firmware updates.
