Acknowledged
Given that a newer SDK is required to build for CIQ 5.x devices, what does this mean for existing apps on devices that were upgraded from CIQ 4 to CIQ 5 (e.g. FR955, Fenix 7, etc)? Do these apps just break?
Background:
- it has always by my understanding that if you build an app for a device with a given SDK, then that app should continue to work regardless of future firmware updates (in general). This ofc excludes situations where:
  - the new firmware update has a bug or breaking change
  - the existing app has a dormant bug which is exposed by a legit change in new firmware. e.g. newer firmware has a change where Weather.CurrentConditions.observationLocationName is null, and this caused several existing watchfaces to crash because they assume that field will never be null. But that's an application error, since that field has always been typed to be possibly null
- CIQ 5.* devices require various 7.X (or 8.X) SDKs to run properly
- Compilers have a check to ensure you don't try to build a a too-new device with a too-old device
- Due to a bug in this check, where older compilers (pre 7.2.0) seem to incorrectly believe that SDK version X can build any device with CIQ version X (or lower), it's possible for an SDK 6.X compiler to build an app for CIQ 5 devices. However, it's very possible that such an app will crash when it's run in the simulator or the device (we've already seen "bug reports" about this
- The existing crop of devices that came out with CIQ 4 (e.g. fr955, fr965, fenix7) have all been updated to CIQ 5. As far as I know, this is the first time that existing devices have received a major CIQ update since the move from CIQ 1 to CIQ 2.
- Someone in the CIQ team already clarified that CIQ 5 devices require apps to be built with newer SDKs.
So here's what I don't understand.
The two following statements seem to be mutually exclusive:
- If an app is built for a device with an existing SDK (e.g. SDK 6.4.0) it will continue (in general) to work on the device for all future firmware updates
- Devices with CIQ 5.* require a 7.X or 8.X SDK
The problem is that it was entirely possible to build an app for an fr955 (for example) with SDK 6.4.0 in the past, when fr955 was only on CIQ 4. If I installed such an app on my fr955 when it had CIQ 4, it would expect it to continue to work now that my device is on CIQ 5.
So how can it be possible that going forward, a 7.X or 8.X SDK is required to build for my fr955?
What am I missing? Has something also changed with the device files that's relevant here?
Parents
  • To be clear I'm not too worried about having to keep device definitions up to date and to use the latest SDK.
    I'm more worried about whether devs actually do need to be constantly updating their apps to keep up with device firmware / CIQ API updates. That hasn't been my experience in the past, so I'm wondering if it's now the case with the big jump from CIQ 4 to CIQ 5 for a ton of existing devices (almost anything currently supported, other than the absolute latest generation that was released with CIQ 5 - e.g. Fenix 8 series)
Comment
Children
  • After talking to development these are the answers I was given.
    • I'm more worried about whether devs actually do need to be constantly updating their apps to keep up with device firmware / CIQ API updates.
      • If a device gets a system update, it should still be able to run any existing PRGs that are on the device. This is our intent, if this isn't the case then there's a bug.
      • You don't have to release a new app version every time a new device configuration is updated. What is on the store is expected to continue to work on device.
    • I'm wondering if it's now the case with the big jump from CIQ 4 to CIQ 5 for a ton of existing devices
      • Apps built for 4.x API that are already on a device should continue to run on CIQ 5.0 API devices. Same goes for the 5.0 to 5.1 update.
    • In the past I wanted to do this to avoid any possible memory usage increases for old devices
      • Newer SDKs shouldn't be increasing memory usage for older devices except in rare cases, such as a bug fix. Newer SDKs could possibly reduce memory on older devices by using new compiler optimizations. If memory is increasing and causing app crashes on older devices it's an issue. We'd want to know if it's in the sim or on an actual device.
