My watch face uses the API `getUserActivityHistory` to show the monthly running distance, but the API is too slow on FR970, firmware 17.33.
On the user's FR970, it took 1853 ms to read 180 records. The user confirmed that his FR255 works fine.
Here is the complete code to read the activities.
function onShow() as Void {
mReadTime = System.getTimer();
mActivities = [] as Array<String>;
if (UserProfile has :getUserActivityHistory) {
var itr = UserProfile.getUserActivityHistory();
if(itr != null){
var next = itr.next();
var start = Time.today().value();
while (next != null) {
if (next.startTime != null) {
// https://forums.garmin.com/developer/connect-iq/f/discussion/356000/weekly-running-distance
var time = (next.startTime as Moment);
var value = time.value();
if ((start - value) > 315576000) { // 10 years
time = new Time.Moment(value + 631065600);
var info = Time.Gregorian.info(time, Time.FORMAT_SHORT);
mActivities.add(Lang.format("$1$$2$$3$ $4$:$5$", [(info.year % 1000).format("%02d"), (info.month as Number).format("%02d"), info.day.format("%02d"), info.hour.format("%02d"), info.min.format("%02d")]));
mActivities.add((next.type as Number).toString());
mActivities.add((next.distance as Number).toString());
next = itr.next();
else {
mActivities.add("The API\ngetUserActivityHistory\nis not available.");
mReadTime = System.getTimer() - mReadTime;
