Acknowledged
The gesture doesn't switch the light on
The gesture in the stock widgets switch the light on but not in CIQ widgets.
  • I've tested it on my F7 and assumed it the general bug.
  • I was not able to reproduce this issue on a Forerunner 965, Fenix 5 Plus, or a Fenix 8 - 43mm AMOLED. The PSX-BarNote widget behaved as intended when the gesture setting was turned on for General Use. The backlight would come on when triggered by a gesture. When the gesture setting was toggled off for During Activity setting, I was able to verify that the backlight would not be triggered by a gesture on the aforementioned devices when performing an activity (i.e. Run).
    However, I was able to reproduce this gesture incident on a Fenix 7X Solar. The settings were the same as the devices above:
    General Use > Gesture toggled on
    During Activity > Gesture toggled off
    I did let our product team know about this finding on the Fenix 7X Solar.
  • Btw. I have the goals alerts ON and I've never seen it during activity although many times I made the goal. And if we're treat alerts as light on they run in the different way.
    Maybe it's a bug idk. Garmin has lots of bugs for sure.
    I think the thing with the "During Activity" settings (with activity in "background") is intentional, although I realize it doesn't matter if you want it to work differently.
    Garmin also has a lot of weird/bad design decisions (especially when it comes to UI), but I the During Activity design makes sense to me.
  • You are right only if we assume that switching on the light by gesture is quite different then making it by pressing the button. For me it's true exactly the same thing so.
    For me they're very different (how many times a day do you use the gesture purposely or accidentally, as opposed to pressing the button?) and I understand why Garmin needs the option to turn off the gesture but not to turn off the light button. Their original reason (for MIP) must be battery life, although of course your reason or the user's reason may be different.
    Then again, for AMOLED, I can see wanting to also disable the Light button, because of:
    - slightly increased chance of burn-in every time the display brightness goes to max
    - more importantly, the chance of annoying people with the full brightness of the display in some situations. e.g. if you're in a dark movie theatre
    -- generally, user shouldn't see anything (black screen) just because activity is in background...
    The user made the choice to turn the gesture off During Activity. This can be easily remedied by turning the gesture on During Activity
    - for most user it doesn't matter :-) and we waste our time for showing our own opinion :-)
    For sure haha :)
    I do think it would be a good feature request to be able to disable single-clicking or double-clicking the Light button. If you post that feature request I will upvote it, although unfortunately there isn't a good subforum for that here.
    Accidental double-click of Light is far worse than accidental siglge-click, since double-click turns on the flashlight, which never times out
    - for tactic activity or real war activity watch should ask 10 times before it switch the light on
    Yeah, I was thinking that Tactix is also a good use case for disabling the Light button (i.e. being able to disable the light completely). I actually searched the internet to see if this is possible, but ofc it isn't. (Tactix AMOLED does have "night vision" mode)
  • The most important thing is the PURPOSE of a functionality. So, what is the purpose of
    - introducing the gestures,
    -- switch on the light (and this the reason the gesture settings are in display group)
    -- inform about exit from sleep for watch face (user can't see this but he can see only the light on)
    -- generally, something connected with situation when USER wants to see something on watch, from the user's point of view: gesture = light on ONLY
    - limitation of gestures during activity
    -- the light shouldn't be on
    -- during activity watch face is all the time in the high power but gesture calls onExitSleep :-) (but not the light on)
    Everything depends on the situation:
    - for me and my user seeing qr code (even during activity in the background) its good to have gesture because I don't have to press button, screen (e.g. it is very cold outside and I have to take off the gloves)
