--psx-7 started from widget list doesn't react on gestures
--any build in widget started from widget list reacts on gestures
Agree that this is a bug, as it's obviously inconsistent. psx-7 should act like native glances. What happens if you launch psx-7 from the app/activity list?
When I tested this on my FR955 (22.24), psx-7 used Display > General Use settings whether launched from glance list or app/activity list.
- when activity is started and active and I switch to ciq watch face so the watch face is in foreground, general rules should be active but the watch face
-- doesn't react on gestures
-- also touch doesn't run
"general rules should be active": I disagree 100%. In English the settings are called:
Display > During Activity
and
My understanding of "During Activity" is "while an activity is active" [*], whether or not it's in the foreground. [*] by "activity is active", I mean the activity timer was started and the activity is not yet saved or cancelled (the timer could be running or it could be stopped). Just because you are looking at another screen, does not mean the activity is no longer active.
On my FR955, the behaviour here is very consistent. If an activity is active, then all screens on the watch follow Display > During Activity settings: activity screens, watchface (native or CIQ), native settings, controls menu, native timer, native stopwatch, etc. You don't even have to think about it, it's a very simple and general rule.
If the setting was called Display > Activity Screens, I might agree with you.
Also, you are reporting 2 completely different things, which you did not make clear in the OP:
- While an activity is not being recorded, Display > During Activity settings are used for Connect IQ device app's glance, while Display > General Use settings are used for for native glances. (Again, clearly an inconsistency)
- In your opinion, while an activity is being recorded, Display > General Use settings should be used for CIQ watch face , but actually Display > During Activity settings are used.
and
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
