Acknowledged
Garmin Connect (Android os) - uneditable fields after update (bug)
After latest update in strength workouts editing there are some fields that used to be editable but now numeric keypad shows up and: 1. I can't put or edit any numbers on some of the fields. 2. On the mentioned fields pressing keypad numbers sometimes doesn't even register (no animation as if the keypad was inactive). [tip: when I press a lot of numbers there, as a maniac, it's not possible to scroll up or down normally as if the app tried to do something it couldn't or in an almost endless loop). Other - same type of fields, just few rows up or down - act as they should and were before.
There is no distinguishable pattern which fields are or are not editable. If a now-uneditable field has a number, pressing it deletes said number
