Ticket Created
WERETECH-9597
Garmin 530 Maptrackview Device crash
Hi
When trying to draw on top of a mapview or maptrackview the device crashes and restarts. Works perfectly on the simulator but not on the actual device.
Error log below.
Any ideas on the issue?
"unit_id":"3314263625",
"product_name":"Edge 530",
"software_part_number":"006-B3121-00",
"ms_since_epoch":1598646976000,
"system_version":"6.00",
"build_type":"PRODUCTION",
"backtrace":"
Function Address: 0x6070AFC8
   Call Address at Function: 0x6070BEB4
Function Address: 0x60709F84
   Call Address at Function: 0x6070A0B6
Function Address: 0x604AE620
   Call Address at Function: 0x604AE7D4
Function Address: 0x604B15A0
   Call Address at Function: 0x604B1648
Function Address: 0x604B16C2
   Call Address at Function: 0x604B193C
Function Address: 0x604B2F54
   Call Address at Function: 0x604B2F66
Function Address: 0x60490ED4
   Call Address at Function: 0x60490F90
Function Address: 0x604AAC1C
   Call Address at Function: 0x604AADB4
Function Address: 0x60431FFC
   Call Address at Function: 0x604320A8
Function Address: 0x60222B9C
   Call Address at Function: 0x60222BBC
Function Address: 0x60250158
   Call Address at Function: 0x602501AC
Function Address: 0x6024FFA8
   Call Address at Function: 0x60250030
Function Address: 0x600E71B0
   Call Address at Function: 0x600E7CEA
Function Address: 0x60431E74
   Call Address at Function: 0x60431E86
Function Address: 0x609BCE5A
   Call Address at Function: 0x609BD0CA
Function Address: 0x6043144C
   Call Address at Function: 0x60431488
Function Address: 0x60430D18
   Call Address at Function: 0x60430D3A
Function Address: 0x60431708
   Call Address at Function: 0x6043179E
Function Address: 0x60214000
   Call Address at Function: 0x6021407C
"error_cause":"RTL Trap",
"proprietary_info":{
    "Commit ID":"2d0bc753c0b194019d3d731404ccbdc0cb6f883c",
    "Time":"2020-8-28 22:36:16",
    "Project Specific":"2020-8-28 22:36:16",
    "CDP_LOG":"605CE741,6044BE99,605B5C5D,6020894D,605CDADD,6020894D,601C6919,601C6919,605B5791,",
    "RTL Error Number":"6E5D8024",
    "Error Message":"00000000,FFFFFF00,00000018,0000F7EB,D08FBF80,00000000,00000102,0000003F,0000007A,0000007A,60B87284,61EDB43C,61EDB48C,61EDB3E8,6070BAD4,6070BEB4,2000001F",
    "Task Name":"CDP main",
    "Saved SP":"61EDB3E8",
    "Saved LR":"6070BAD4",
    "Saved PC":"6070BEB4",
    "R[0]":"00000000",
    "R[1]":"FFFFFF00",
    "R[2]":"00000018",
    "R[3]":"0000F7EB",
    "R[4]":"D08FBF80",
    "R[5]":"00000000",
    "R[6]":"00000102",
    "R[7]":"0000003F",
    "R[8]":"0000007A",
    "R[9]":"0000007A",
    "R[10]":"60B87284",
    "R[11]":"61EDB43C",
    "R[12]":"61EDB48C",
    "R[13]":"61EDB3E8",
    "R[14]":"6070BAD4",
    "R[15]":"6070BEB4",
    "cpsr":"2000001F"
Parents
  • Ok so tried running the app with adding a return to onUpdate() and leaving the maptrackview to update itself with no problems. I also added a println() to onUpdate() and updates are maybe slightly more than once per second but does not seem to be an issue. Everything works well until add any kind of draw to onUpdate() even a static dc.drawText(). Will probably just have to work around not have any data on the mapview for now but not ideal.
Comment
Children
  • I also tried moving the mapview.onUpdate() to after the dc.draw call but no difference for me. Works fine on the sim but crashes on the 530.
  • That wasn't it, as I still see the crash at times - like I did before
  • I think I found it in my own app.  I tracked down the crash to a dc.drawText() call, while doing everything else I normally do in onUpdate() like markers..
    So then I looked at reproducing it in the MapSample in the SDK.  It's always good to provide code to reproduce something in a bug report, and I'll often start with a sample.  Made one change, doing a dc.drawText().
    And it worked fine.  So I tried to figure out what was different from my app.
    In the MapSample, if I comment out the line
    MapView.onUpdate(dc);
    I got the crash
    I looked at my code, and for some reason had it comment out there too.  I added it back in, and no crash in my app!
    Are you making that call?
