Acknowledged
CIQQA-4859
FR745 13.70: BluetoothLowEnergy.Descriptor.requestWrite() blocks Connect IQ callbacks with Rogue Echo Bike V3 FTMS CCCD
Product / firmware
- Watch: Garmin Forerunner 745
- Watch firmware: 13.70 (build 55e840a)
- Connect IQ target: fr745 / API level 3.3
- SDK used to build: Connect IQ SDK 9.3.0
- App type: watch-app
- Permission: BluetoothLowEnergy
Peripheral
- Rogue Echo Bike V3 console
- Fitness Machine Service: 0x1826
- Indoor Bike Data characteristic: 0x2AD2 (Notify)
- Fitness Machine Control Point: 0x2AD9 (Write + Indicate)
- Client Characteristic Configuration Descriptor: 0x2902
Problem
After a successful BLE connection and discovery of the FTMS service, Indoor Bike Data characteristic, and its CCCD, this call causes the Connect IQ application to stop receiving all expected callbacks:
descriptor.requestWrite([0x01, 0x00]b);
The bike remains connected (its Bluetooth indicator changes from flashing to solid and stays solid), but:
1. BleDelegate.onDescriptorWrite() is never called with either success or error.
2. A separate 1 Hz Timer.Timer owned by the visible WatchUi.View also stops receiving callbacks.
3. The UI stays on "Writing data CCCD" indefinitely.
4. Closing the app immediately releases the connection; the bike indicator returns to flashing.
Expected behavior
Descriptor.requestWrite() should return asynchronously and result in BleDelegate.onDescriptorWrite() with STATUS_SUCCESS or a documented STATUS_* failure code. Unrelated Timer callbacks and UI updates should continue while the descriptor write is pending.
Actual behavior
The descriptor write appears to block the Connect IQ app event dispatch entirely. No descriptor completion callback, timeout callback, or view timer callback occurs after the write request.
Reproduction steps
1. Install and launch the attached/minimal Connect IQ watch app on an FR745 running firmware 13.70.
2. Ensure no phone, nRF Connect, ErgZone, or native watch sensor connection is using the bike.
3. Have the app scan for and select the Rogue Echo Bike V3.
4. Register the FTMS profile containing:
- service 0x1826
- characteristic 0x2AD2 with descriptor 0x2902
- characteristic 0x2AD9 with descriptor 0x2902
5. Pair/connect to the bike.
6. Retrieve 0x2AD2 and its 0x2902 descriptor.
7. Call descriptor.requestWrite([0x01, 0x00]b).
8. Observe that the bike indicator is solid but the app remains on "Writing data CCCD" indefinitely and the independent UI timer stops.
9. Exit the app; observe that the bike immediately returns to advertising/flashing.
Control test
The same Rogue Echo Bike V3 console was tested in nRF Connect on iOS. nRF Connect successfully enables notifications on 0x2AD2 by writing 01 00 to 0x2902, enables indications on 0x2AD9 by writing 02 00 to 0x2902, then successfully completes the FTMS Request Control and Start/Resume sequence:
00 -> 80 00 01
07 -> 80 07 01
It receives continuous 25-byte Indoor Bike Data notifications after initialization.
Additional packet information
- Observed Indoor Bike Data notification length: 25 bytes in two independent nRF Connect captures.
- Representative packet:
DE 0B 98 05 00 00 30 00 00 00 82 01 00 1C 00 00 00 01 00 00 00 00 00 D8 00
- The 25-byte delivery behavior has not yet been testable on the FR745 because the CCCD write deadlocks first.
App build under test
- SHA-256 of current PRG: 72a911ebacfe366e483604667cd734f4eaef1c9489f5b5e4a6aba78a3a357c9d
- Reproduction app source is a minimal standalone FTMS central implementation; it does not use FIT recording, phone communication, or external bridges.
Request
Please investigate why Descriptor.requestWrite() to the standard FTMS notification CCCD can halt Connect IQ callback/timer dispatch on the Forerunner 745. If this is a firmware limitation or a required compatibility pattern, please document the supported workaround. Otherwise, please restore the documented asynchronous completion behavior.
  • Remember, CIq's BLE isn't a full implementation.  Mainly just a minimal one, with things like max of 3 services and small send/rec maxes.  For testing I would suggest picking up the Nordic Dongle or DK so you can test in the sim.  It's faster and FW bugs aren't involved,  The dongle is about $15US and worth every penny
    You may also want to look at the NordicThingy62 samples in the SDK, and maybe  make a few mods to see how they work with your devices.  That's how I got started with CIQ BLE back when it was announced.  I've since used a number of different devices to connect to.
