Environment
- Forerunner 955 Solar, target
fr955, software 29.05, verified over USB before and after the recorded runs. - Connect IQ SDK 9.2.0 for macOS, build
92a1605b2, command-line toolchain. - Gymmade was sideloaded over its existing installation, retaining its app ID, pairing and local data. Diagnostic build tag
308-51ed4bf-v1. - Gymmade 308 was installed alongside the original and left unpaired. The two 939,372-byte packages use the same compiled executable section, SDK, build settings and signer. Their app ID and launcher display name differ.
Steps to reproduce on the affected watch
- Open the Activities & Apps list and highlight the original Gymmade. Press START once and wait. On a slow launch, the list stays visible for nearly 10 seconds before Opening Gymmade appears.
- From Home, press BACK to return to the list. Launch Gymmade 308, wait for Link Garmin, then press BACK. Repeat the pair three times.
- In a separate run, enable airplane mode and launch the original Gymmade three times, returning to the list after each launch.
Expected behavior is a prompt transition into the app. On the affected installation the pause is intermittent and can recur on reopen.
Measured launch times
From visible START release to the first readable Opening Gymmade frame, with about one frame of uncertainty at 30 fps:
- Original Gymmade, alternating run: 9.94 s, 9.87 s, 9.94 s.
- Fresh-ID Gymmade 308, same alternating run: 0.27 s, 0.13 s, 0.27 s.
- Original Gymmade, airplane mode: 0.20 s, 9.87 s, 9.84 s. Home followed Opening Gymmade in about 0.87 s on each launch.
The original also showed the long wait with an uninstrumented build from the same base source (8.27–8.41 s). Two simple probes opened in 0.10–0.17 s. One was resource-padded to within 32 bytes of the diagnostic Gymmade package, so total package size alone does not explain the observed difference.
Matched startup log
The diagnostic samples System.getTimer() at the first statement of initialize(), before AppBase.initialize(), and after the first render. The three original-app records match the alternating video by order and spacing. The two inter-launch gaps differ by 16 ms and 9 ms between the independent video and watch clocks.
- First callback to first draw end: 79 ms, 79 ms, 81 ms.
- First callback to settled draw end: 1,123 ms, 1,123 ms, 1,125 ms.
- App metadata read: 429 ms each, beginning about 560 ms after first draw.
The matched evidence puts almost all the long wait before the first recorded app callback. The airplane-mode video measures visible transitions only.
Request
Can the Connect IQ team advise what to trace between START selection and the first app callback while retaining the affected installation’s state? The fresh-ID copy differs in identity, registration, pairing and saved data, so the individual cause remains open. We have yet to reproduce the slow state with a portable minimal app.
The side-by-side recording, airplane-mode recording and matched startup log excerpt are available on request.
