Acknowledged
Fix Connect IQ
Not only does the app not pick up the latest release, it doesn't install the one it does find.
It goes through the loop of showing
Update, when clicked, it shows Queued, then installing, then all apps installed then back to showing Update again.
This means you can't test private links because you can't be sure to get the latest version, or know which version you actually got, as the displayed may  or correspond to the version installed.
Totally defective.
Please fix.
Parents
  • Unfortunately this happens a lot. The "workaround" I use is to include the version in some visible place. For example in my datafield I change the datafield's name from "X" to "X - 123" so I can see the version.
    Now for the reason why this happens: I have seen some apps (not mine) that are big and this loop happens a lot. Freeing up storage (deleting unused apps/datafields/watchfaces) seems to help (albeit did not fix it 100%)
Comment
Children
  • Solution Found:
    After some research it turns out the MonkeyC: Export Project may not build a PRG file if one already exists and will use the one from a previous RUN if it exists.
    Thus if making minor changes and not running them in the simulator first the export will export the previous version which will cause the symptoms experienced.
  • As for size being an issue, that may be a problem but in this case if you uninstall and reinstall it works fine [except you still get some random version], while update just fails in a loop. So why size should be an issue for update and not install is odd.
    The bottom line is the Connect IQ app is just plain defective, and how it has been left like that for so long is reason for concern.
  • Thanks, but sorry the Connect IQ app is totally defective - no fix works consistently. It may pickup any old version [except the current one], can be out of sync with the description and doesn't do what it is supposed to do.
