Complete
WERETECH-8593
We were unable to reproduce this issue, but we can investigate further if we receive more complaints about this issue.
Fit files created by simulator no longer able to be converted to csv using FitCSVTool.jar
I am using SDK 3.1.7 and FitSDKRelease_21.22.00.
I run the simulator and create some data using Simulation->FIT Data->Simulate Data.  After running this I select Stop and then select 'Save FIT session' which asks me for a filename etc.
In the past I could then convert the FIT file into a csv by running:
java -jar /.../FitSDKRelease_<nn_nn_nn>/java/FitCSVTool.jar -b <file>.fit <file>.csv
but this is now returning the following error:
FIT CSV Tool - Protocol 2.0 Profile 21.22 Release
Exception in thread "main" java.lang.RuntimeException: com.garmin.fit.FitRuntimeException: FIT decode error: File is not FIT format.  Check file header data type. Error at byte: 24
    at com.garmin.fit.csv.CSVTool.run(CSVTool.java:246)
    at com.garmin.fit.csv.CSVTool.main(CSVTool.java:332)
Caused by: com.garmin.fit.FitRuntimeException: FIT decode error: File is not FIT format.  Check file header data type. Error at byte: 24
I am using macOS Mojave v.10.14.6
Parents Comment Children
No Data
