Acknowledged
CIQQA-3599
FIT CONTRIBUTIONS ERROR
When im trying to compare 2 FIT contributions graphic on Garmin connect desktop the name is ta number
Parents
  • Do you have an example you can share? The problem is not apparent based on your description. It would also be helpful if you could tell us which app was used to create the fit contributions since we need to reproduce this in order to properly investigate. If more information cannot be provided, this issue will be closed.
Comment
Children
No Data
