Complete
WERETECH-6408, WERETECH-7425, WERETECH-7514
Could not reproduce.
File not found error
On real device randomly occurs error: File Not Found Error - while trying to read from Storage
Error is already quite old. From CIQ_LOG.YML I see that it occurs roughly once a day. It is not as visible as before because Watch restart automatically Watchface.
Parents
  • here are some logs,first is the CIQ_LOG.YML (file not found error on MK1), 2nd is printLn from app (from the watch too).
    (My WF halted here, but if i start it again, it may be ok for some random time, one day, one week or one minute!)
    (i guess CIQ log time is UTC/zulu time, with 1 hour less from the watch time...)
    Error: File Not Found Error
    Details: 'Failed invoking <symbol>'
    Time: 2020-02-10T12:45:30Z
    Part-Number: 006-B2859-00
    Firmware-Version: '8.00'
    Language-Code: fre
    ConnectIQ-Version: 3.1.7
    Store-Id: cf4501b9-5acb-4ed7-aef3-6573e7474871
    Store-Version: 127
    Filename: A23A2828
    Appname: CubeWatch
    Stack:
    - pc: 0x1000912e
    0x1000912e is :
    for (var i=0; i<TotalStocks; i++) {
    StocksArray[i][0]= false;
    StocksArray[i][2]= Application.getApp().getProperty("StockCode"+i.toString());
    Application.getApp().setProperty("OSSTOCKS[" + i + "]", StocksArray[i]);
    (-> in userSettings (while init WF) )
    printLn LOG:
    in onUpdate: at 13:45:29
    ********* drawInformation ******** mRequestType =0
    in onUpdate: at 13:45:30
    Background: ***enter onStart - ..
    Background: ****onTemporalEvent **** mType = 0
    *** In onHide.. at 13:45:30
    Background: *** In saveDatatoDisk.. key : ALL at 13:45:31
    ***enter onStop - ..
    Background: ***enter onStop - ..
    Background: **** receiveStock3 **** **** dataFromWebRequest=[0, 200, [[4.150000, 200, false, true, ALVAL.PA],...
    onTemporalEvent =>
    function onTemporalEvent() {
    mType = Storage.getValue("webRequestType");
    what i see :
    First of all, it is quite impossible to have "saveDatatoDisk 'ALL' " function called in BG ( i use it only in onHide and onUserSettings). It may be a printLn display pb?
    2nd, i see 1 onTemporalEvent before onHide, 4 TemporalEvent called following. And each time when i have a file error.
    Why 5 calls of the BG in the same minute ???
    (printLn is accessing IO too, but i have the file not found error without the printLn log ...)
    Some may tell me i should not put disk access here, and i'm ok, but i have not the skill yet to do in other ways...
    but I do not (i should not) have to deal with IO conflicts..
    maybe i made some (concept) errors in my code, it is something i can easily guess !
Comment
    Language-Code: fre
    Store-Version: 127
    Filename: A23A2828
    Appname: CubeWatch
    Stack:
    - pc: 0x1000912e
    0x1000912e is :
    printLn LOG:
    onTemporalEvent =>
    what i see :
Children
  • Hi,
    still debugging, and still having File not found errors.
    Always from events calls (Hide, Sleep ...) while at the same time IO use in Temporal Event.
    Either with properties or Storage while using storage getValue in TemporalEvent..
    Strange behavior : sometime i have another default WF running after the crash, sometime my WF is still running (automatic restart ?)
