Acknowledged
CIQQA-3748
Feature Request: SSL (Step Speed Loss) in RunningDynamicsData for Connect IQ (Or make Toybox.BLESecure.RunningDynamicsData)
I'm a runner who uses HRM 600 + Fenix 8 pro - The watch collects SSL (Step Speed Loss) metric during running, but it is not available in Toybox.AntPlus.RunningDynamicsData (nor via SensorHistory) in the SDK.
Could you please consider exposing SSL and/or SSL% as part of the Running Dynamics API so that data-fields and apps can access it? This would enable richer running-dynamics features and better integration with third-party hardware (e.g., glasses from ActiveLook). I want to be able to do a PR to expose these to Engo eyewear for users who have spent a lot of money adopting Garmin Running Dynamics on Modern watch/HRM.
I don't see it exposed here:
https://developer.garmin.com/connect-iq/api-docs/Toybox/AntPlus/RunningDynamicsData.html
There is a pretty bad UX around this, if i want to use the HRM 600 with datafields (such as my Engo eyewear) I have to run it in ANT+ mode, but in doing so, I lose the SSL feature of the 600 making it an HRM 200.
Garmin needs to add SSL to AntPlus or make a toybox that exposes running dynamics over BLE since it seems Secure Bluetooth is the "Way of the future" as mandated by EU and other regulatory bodies.
  • Indeed. This sentence should be repeated in every thread talking about a bug.
  • i figure the more people who contact them directly, the better that's for sure!
  • Thanks for the confirmation. That's indeed a really bad situation right now. If they'll not correct for this then it's a huge step backwards - just to mention in my case it leads to worse results for all my users who use a HRM 600, and furthermore I'm also using RunningDynamics for scientific analyses and publications. Maybe I'll try to contact Garmin separately, hopefully increasing the chances that they'll notice that this is a big deal for some of us.
  • Can confirm, the CIQ sdk only reads what is published to Ant so developers can't read the HRM 600 values unless they switch the HRM 600 to connect via ANT+ and if they do this, they don't get step speed loss and running economy but at least you get the traditional antPlus.runningdynamics.
    It's a terrible flaw in the system right now.
  • Hi,
    a related request regarding the HRM 600 and RunningDynamics: Based on user feedback of my data field, it seems to me that even the other RunningDynamics information (such as the vertical oscillation) is not properly read out when using a HRM 600, whereas it always worked with all the previous HRMs that deliver RunningDynamics. I couldn't yet check for myself as I don't own a HRM 600, but based on the feedback I got it seems pretty obvious that this is indeed the case. Can anybody confirm this? Thanks!
