Acknowledged
Feature-request: split the strings.xml for in-device and settings related strings
In most of the apps I've seen most of the strings are used for settings, still those strings are included in the memory footprint of the app. It would be very useful to split strings.xml to device-strings.xml and settings-strings.xml.
Parents Comment Children
  • Each module scope variable takes 16 bytes in the data segment
    I misremembered this. It's actually only 8 bytes. The symbol is stored in 3 bytes, there's a flag byte (indicating data type amongst other things), and then 4 bytes for the value (which in this case is just a Number). So presumably the resource table uses 16 bytes per string. I guess it needs address, length, id, and something else?
  • maybe 24 but memory monitor shows data only in kB...
    why???? Slight smile
  • Each module scope variable takes 16 bytes in the data segment. That's fixed overhead whether you call loadResource or not. Then I'm guessing the resource table has 8 bytes per resource, but only gets allocated on the first call to loadResource. Which would give 24 bytes per resource.
