Ticket Created
WERETECH-7423
Failed to connect to the simulator.
When trying the to run the initial Timestamp on Eclipse app I get the following error since the simulator does not start.
BUILD: /usr/lib/jvm/java-13-openjdk-amd64/bin/java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /home/tomi/Documents/GarminIQSDK/connectiq-sdk-lin-3.0.11-2019-4-30-cd45859/bin/monkeybrains.jar -o /home/tomi/eclipse-workspace/SecondTry/bin/SecondTry.prg -w -y /home/tomi/Documents/GarminIQSDK/developer_key -d fenix5s_sim -s 3.0.0 -f /home/tomi/eclipse-workspace/SecondTry/monkey.jungle
BUILD: WARNING: The launcher icon (30x30) is smaller than the specified launcher icon size of the device 'fenix5s' (36x36). Padding will be added to the image to center it.
BUILD: Complete
Before running the app I start the simulator but no window for simulator shows up.
OS: Ubuntu 19.04
Eclipse: Version: 2019-03 (4.11.0)
Build id: 20190314-1200
SDK: 3.0.11-2019-4-30
Parents
  • The CIQ SDK will only be supported for LTS versions of Ubuntu and 18.04 is the current LTS version. However the simulator might work for other distros of linux if the library dependencies for the simulator are resolved. Please try to run the simulator executable from the command line and see if you get any errors.
Comment
Children
No Data
