Acknowledged
CIQQA-3309
Extended code space (:extendedCode) is not supported for some of the newest devices
All new devices starting with API level 5.1.0 should support the ":extendedCode" option, but my compiler tells me
WARNING: instinct3amoled45mm: Extended code space is not supported for device 'instinct3amoled45mm'. The (:extendedCode) annotation will be ignored.
WARNING: instinct3amoled50mm: Extended code space is not supported for device 'instinct3amoled50mm'. The (:extendedCode) annotation will be ignored.
WARNING: fr57047mm: Extended code space is not supported for device 'fr57047mm'. The (:extendedCode) annotation will be ignored.
WARNING: vivoactive6: Extended code space is not supported for device 'vivoactive6'. The (:extendedCode) annotation will be ignored.
WARNING: fr970: Extended code space is not supported for device 'fr970'. The (:extendedCode) annotation will be ignored.
WARNING: fr57042mm: Extended code space is not supported for device 'fr57042mm'. The (:extendedCode) annotation will be ignored.
WARNING: venux1: Extended code space is not supported for device 'venux1'. The (:extendedCode) annotation will be ignored.
    • Also the new Vivoactive 6 have no support for extended code at time. But Vivoactive 5 supports this feature
  • I support this bug report.
    A. Some "special focus" devices don't support System8, although they are based on models that are supported:
    approachs7042mm
    approachs7047mm (based on Venu3)
    descentmk343mm
    descentmk351mm (based on EpixPro)
    It would be great if Garmin will support these devices and make them System8 compatible
    B. On some System8 devices :extendedCode does not work:
    d2mach1
    fr570
    fr970
    On these the app crashes with an "out of memory" error, both on the simulator and on the real device. That's especially bad in the case of the new Forerunners! This needs to be fixed asap.
