Given this BarrelTest.mc
module BarrelTest {
(:one)
const Konstant = 2;
(:two)
const Konstant = 1;
and this monkey.jungle
project.manifest = manifest.xml base.excludeAnnotations = one
If I try to build the barrel project, I get
ERROR: BarrelTest.mc:5: Duplicate declaration of symbol 'Konstant' in module 'BarrelTest'.
ERROR: Barrel build failed
But if I include this as a barrel project from my main project via:
base.barrelPath = /path/to/BarrelTest/monkey.jungle
and build my main project, it works, and Konstant has the value 1, as expected.
So when used as a barrel project, the compiler pulls the excludeAnnotations from the barrel's jungle file, and uses them (and I've verified that it *only* uses the excludeAnnotations from the barrel's jungle file; it *doesn't* apply the ones from my main project's jungle file - which makes sense). But when you try to build a .barrel, the compiler ignores the excludeAnnotations in the barrel's .jungle file, and fails to compile.
On the other hand if I change my BarrelTest.mc to
module BarrelTest {
(:release)
const Konstant = 2;
(:debug)
const Konstant = 1;
Then the barrel build succeeds. So it *does* respect excludeAnnotations, it's just failing to pull them in from the .jungle file. Also, if I then *use* the built barrel from my main project by pointing the barrelPath at the .barrel file, I do indeed get the correct values for debug/release builds (no real surprise, the barrel just contains the original source).
My example isn't too realistic... but it means you can't do things like
(:not_round) const isRound = false; (:round) const isRound = true;
with something like this in the barrel's jungle file
base.excludeAnnotations = round round.excludeAnnotations = not_round
It also seems wrong that the excludeAnnotations work when the barrel project is imported, but not when it's built.
