Acknowledged
ERA joins and mixes errors
Error Name: Invalid Value
Occurrences: 2
First Occurrence: 2022-08-19
Last Occurrence: 2022-08-19
Devices:
    fēnix® 7X / tactix® 7 / quatix® 7X Solar / EnduroTm 2: 8.37
App Versions: 2.0.4
Languages: chs, rus
Backtrace:
    file___1.initialize:62
    file___1.draw:146
    file___2.initialize:68
    file___2.onSC:175
1. Backtrace is completely bad e.g. no onUpdate which calls draw
2. I think it's 2 separated errors and symbols are mixed
3. I suppose errors are connected with getSettingsView()
  • And another issue.
    I'm almost sure that the errors form previous version of app are included into current version.
    I put into store a few version because of workaround and in current version I can see errors "Symbol Not Found Error" that I've fixed. So it looks like:
    - version 1 - workaround
    - version 2 - was bug in workaround
    - version 3 fixing bug
    Some user have still version 2  and I can see their errors in current 3.
    And the bug was very simple (and I've already reported it) -compiler doesn't check the name in local vars, i e.g.
    function f1(key)
    function f2()
      var key1;
      key = 5;//typo
    for compiler is ok there is key in symbol table but just right in f1 not f2
  • I have a lot of such reports, this is fine:
    Occurrences: 1
    First Occurrence: 2022-08-18
    Last Occurrence: 2022-08-18
    Devices:
    App Versions: 2.0.3
    Languages: kor
    Backtrace:        jw.
        file___1.initialize:59
        file___1.draw:146
        file___2.initialize:67
        file___2.onSC:175
    most of them is for APAC languages chs, cht, kor, vie
    it's look like 2 apps run parallel  - for this reason I think it's connected with getSettingsView()
    To save memory I don't change property onBack/onDone but  in onSelect of Menu2InputDelegate but when Menu2 is foreground I can't see what happens with WF.
  • I don't think I've seen a backtrace that looks like that before... it it at all helpful? Have you seen others that appear this way?
