Hello,
It is not possible to avoid the crashlogs from the devices that use obsolete SW.
Expected: Garmin SDK uses the last SW with the corrections, this info should be embeeded into the .PRG file, and Garmin Connect do not allow to install apps that do not match fixed SW.
NB. I do not understand why the issue is cloned across the series of the devices?
Simple code that worked for years:
// Return the initial view of your application here
function getInitialView() {
//Sys.println("App getInitialView");
return [ new ProjectXLargeWatchView()];
causes this:
Error Name: Too Many Arguments Error
Occurrences: 30
First Occurrence: 2020-02-02
Last Occurrence: 2020-02-09
Devices:
fēnix® 6S Pro / 6S Sapphire: 3.00
fēnix® 6 Pro / 6 Sapphire: 3.00
fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 3.10
App Versions: 1.6.7
Languages: deu, eng, por
Backtrace:
ProjectXLargeWatchApp.getInitialView:94
Error Name: Symbol Not Found Error
Occurrences: 179
First Occurrence: 2020-01-30
Devices:
fēnix® 6S Pro / 6S Sapphire: 2.10
fēnix® 6 Pro / 6 Sapphire: 2.40
fēnix® 5S Plus: 7.60, 8.50
fēnix® 6 Pro / 6 Sapphire: 2.20
fēnix® 5 Plus: 7.10
vívoactive® 4: 2.20
fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 2.30
Venu: 3.50, 3.60, 2.30
vívoactive® 4: 2.70, 3.20
vívoactive® 3: 6.60, 6.30, 6.20
vívoactive® 4S: 2.70
Forerunner® 245 Music: 2.90, 3.00
App Versions: 1.6.7
Languages: ces, chs, cht, deu, dut, eng, fre, kor, nob, pol, por, rus, spa, swe, tha
Backtrace:
Occurrences: 2
First Occurrence: 2020-02-06
Last Occurrence: 2020-02-06
Devices:
fēnix® 5S: 14.20
App Versions: 1.6.7
Languages: eng
Backtrace:
a1234.garmin
in reply to Stephen.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
a1234.garmin
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
