Ticket Created
WERETECH-8672
ERA Backtrace points to a function that is never called
I was recently looking through some ERA backtraces and came across with a few that looked strange in two respects:
1) The backtrace consisted of only one line
2) The exception reference seemed to be impossible within the code that is pointed to by the backtrace
After pushing out a bunch of releases with small tweaks trying to narrow in on the issue, I finally came across an interesting finding: the backtrace *always* points to the last function in the module--even if it's never called!
Looking through the debug XML for my app, I believe I can see why: the last function in the module is also the last symbol referenced in the pcToLineNum mapping.
So I'm guessing the PC for the backtrace is outside the bounds of my code, and the failure mode for the backtrace-prettification is to not print 'Unknown' or just the PC, but instead to default the the highest (or possibly lowest) addressed symbol in the pcToLineNum mapping.
This is a big problem because, well, it causes developers to spend a large number of frustrating hours trying to disprove something that in reality never actually happened!
A better solution IMHO would be to print something like <Unknown Symbol> or <PC is outside application scope> or something to let the developer know that yes it's a problem, but not *your problem*.
 Examples from ERA: (NOTE: lastFunctionInModule is never called, it was added just to prove the theory that the backtrace was erroneous)
Error Name: Too Many Arguments Error
Occurrences: 3
First Occurrence: 2020-03-03
Last Occurrence: 2020-03-03
Devices:
fēnix® 6S Pro / 6S Sapphire: 3.00
App Versions: 4.6.8
Languages: deu
Backtrace:
DownloadSpeed.lastFunctionInModule:65
Error Name: Symbol Not Found Error
Occurrences: 1
Devices:
Forerunner® 945: 2.80
App Versions: 4.6.8
Languages: deu
Backtrace:
Parents
  • Thanks for looking into it!
    I'd be happy to try to build a minimal test case for this issue, but since it requires old firmware to replicate, I don't think I have a means to do so. There still isn't a firmware archive available for devs, is there?
    Obviously this is pie-in-the-sky, but what would be phenomenal:
    1) An Eclipse plugin, like ERA, that lets developers reflash their devices to arbitrary firmware versions
    2) This tool would need developers keys, etc, so would be somewhat protected from use/abuse by casual users (thus avoiding support burden)
    3) This tool would also abstract away the storage/delivery of the firmware. Garmin wouldn't be sharing links directly, but would be authorizing download through the tool and then performing the download for the developers. Very similar to the SDK manager. The difference would be the post-download hook that perform the install via Garmin Express integration
    4) This hypothetical tool could display any EULA or legal stuff needed because of the experimental nature of this tool
    Given the realities of when folks update firmware (hint: they mostly don't), a tool like this is in the best interest of both developers and Garmin. But I understand it would be *a lot* of work. Just thinking out loud...
Comment
Children
No Data
