Acknowledged
enum with no integer and no error
enum
    __1 = "test",
    __2,
    __3 = 0
println in console:
test
0
0
but according to doc https://developer.garmin.com/connect-iq/monkey-c/functions/
Note that assigning anything other than an integer will cause an error.
Parents
  • Possibly, if you look at the beginning of the wiki page you'll see:
    In computer programming, an enumerated type (also called enumeration, enum, or factor in the R programming language, and a categorical variable in statistics) is a data type consisting of a set of named values called elements, members, enumeral, or enumerators of the type
    If you look at enumeration on wikipedia, you'll see:
    An enumeration is a complete, ordered listing of all the items in a collection. The term is commonly used in mathematics and computer science to refer to a listing of all of the elements of a set.
    Elements in a set are not integers by definition. It can be anything in that set.
    In any case, I don't think strings should be dropped from being used in enums, but rather, the documentation should be updated.
Comment
Children
No Data
