This just started acting up. So weird. In Eclipse, using the latest SDK and latest Eclipse. Edge 1030 if that matters.
If I hit START first, then PLAY... elapsedDistance is stuck at ZERO meters. However, if I hit PLAY first, then START, elapsedDistance works.
This was never an issue in the past. I always hit START first. Easy work around... just remember to hit PLAY first. But must be some new unintentional bug that might impact other things too?
An image of bug will be included in a follow on reply, since we can't post images in the initial post.
