Complete
WERETECH-7776, JAZZ-2402, HESPER-2917, BERLIN-2552
Edge530 datafield ANT communication not work after the device restart
Hey!
I have a datafield which showing my external sensor`s data using ANT communication. It is flawlessly working on Edge 520/520plus since a year.
If I set my datafield on Edge 530 and start it, it works perfectly. However if I restart the Edge and start the datafield it doesn`t communicate with my sensor, not showing any data.
If I swap the datafield to another one, restart the device, swap back, and start it, it is working until I restart the device again.
I don`t know how to debug this problem. Is there anyone who met the same problem?  Is there a bug in my program or in Edge 530?
Thanks in advance! :)
    Former Member in reply to Stephen.ConnectIQ
    I just re-tried connecting Moxy devices to the Edge 530 with firmware 5.02. Seems like now they won't connect at all. The Moxy ConnectIQ apps all have the sensor ID numbers defined, but they don't pick up at all when the devices are turned on. Seems like something went backward, unfortunately.
    I use the 1030 and the ebike-field by Jan Capek. I tested it with Edge 1030 software version 9.02 Beta. But it does not work. There are connection problems with these ANT+ IQ data fields again.
  • Hi  I apologize for the lack of updates, however we don't have much news to report. As it stands now, we are aware that this issue was not fixed in the latest release fw of e830. Unfortunately, we do not have control over what does or does not get into a device's fw patch. Because of this, I also can not speak to what firmware version will be required to get this fix. Please know that the issue is reported on all the devices in question, and the device teams are working to get this change integrated into their devices.
  • I can only speak for the 1030 and the ebike-field by Jan Capek, which obviously uses the same kind of internal ANT+ communication:
    The problems started with firmware 8.0, where these types of IQ data fields could no longer be connected. This error was 100% reproducible. Only the new setting of the field after a reboot brought (only once) remedy.
    This bug was fixed with firmware beta 8.06. The ANT+ connection worked fine again.
    Since firmware 9.0 there are connection problems with these ANT+ IQ data fields again. This time the error is not reproducible. My ebike-field works mostly. Sometimes, however, no connection can be established and only the resetting of the data field after a reboot leads to success. Unfortunately I haven't found a pattern for the failure of the ANT+ communication yet.
  • Stephen, can you or someone from Garmin provide an update on these issues?  We were thinking it was fixed, but I'm getting complaints still.  For each of the 530, 830, 1030, 945, and 245, can you let us know if the issue is actually fixed and what version of firmware is required?  If the issue is still present, can your provide an estimate of when a beta or final fix will be available.  Some users have been waiting 10-12 weeks for a fix now.  The false start on the fix and then little new information really tries their patience. Thanks!
