Complete
WERETECH-7776, JAZZ-2402, HESPER-2917, BERLIN-2552
Edge530 datafield ANT communication not work after the device restart
Hey!
I have a datafield which showing my external sensor`s data using ANT communication. It is flawlessly working on Edge 520/520plus since a year.
If I set my datafield on Edge 530 and start it, it works perfectly. However if I restart the Edge and start the datafield it doesn`t communicate with my sensor, not showing any data.
If I swap the datafield to another one, restart the device, swap back, and start it, it is working until I restart the device again.
I don`t know how to debug this problem. Is there anyone who met the same problem?  Is there a bug in my program or in Edge 530?
Thanks in advance! :)
Parents
  • I can only speak for the 1030 and the ebike-field by Jan Capek, which obviously uses the same kind of internal ANT+ communication:
    The problems started with firmware 8.0, where these types of IQ data fields could no longer be connected. This error was 100% reproducible. Only the new setting of the field after a reboot brought (only once) remedy.
    This bug was fixed with firmware beta 8.06. The ANT+ connection worked fine again.
    Since firmware 9.0 there are connection problems with these ANT+ IQ data fields again. This time the error is not reproducible. My ebike-field works mostly. Sometimes, however, no connection can be established and only the resetting of the data field after a reboot leads to success. Unfortunately I haven't found a pattern for the failure of the ANT+ communication yet.
Comment
Children
No Data
