Complete
over 4 years ago
WERETECH-7776, JAZZ-2402, HESPER-2917, BERLIN-2552
Edge530 datafield ANT communication not work after the device restart
Hey!
I have a datafield which showing my external sensor`s data using ANT communication. It is flawlessly working on Edge 520/520plus since a year.
If I set my datafield on Edge 530 and start it, it works perfectly. However if I restart the Edge and start the datafield it doesn`t communicate with my sensor, not showing any data.
If I swap the datafield to another one, restart the device, swap back, and start it, it is working until I restart the device again.
I don`t know how to debug this problem. Is there anyone who met the same problem?  Is there a bug in my program or in Edge 530?
Thanks in advance! :)
    Former Member over 5 years ago in reply to Stephen.ConnectIQ
    on my garmin 830 device it doesn't work, i don't know what to do?
  • Comes from data transfer from old Garmin Edge 1000 where the Original Specialized Levo IQ data fields were compatible. Stopped I think with the 1030.
    Will do as you suggest tomorrow
    Thank you.
  • To be on the safe side:
    delete all Levo attached sensors - stick only to heartrate.
    Then connect IQ-ebike fileld (no other sensors are disturbing)
    After success search and connect 24506 speed/cadence and power.
  • What I would do:
    Delete "SPECIALIZED speed and cadence"  (first row) [where is it from? never seen on mine...]
    Delete "24506 ebike" (second row) [I see - it is disabled, but better delete it]
    Enable "24506 speed and cadence"  (third row)
    Connect - if you want - "24506 power" (in addition)
    That's what I have and that works.
  • Thanks
    I disenabled/deleted the sensors in the menue Sensor (see picture) and deleted them from the training pages.
    No data on EbikeField E-Bike. Then I Started activity and moved the Kenevo for 1 min cause Jan wrote somewhere that it takes appx 40 sec until his data field eorks - nothing (see Pic).
    What did I do wrong?
    Thank you in advance
