Complete
WERETECH-7776, JAZZ-2402, HESPER-2917, BERLIN-2552
Edge530 datafield ANT communication not work after the device restart
Hey!
I have a datafield which showing my external sensor`s data using ANT communication. It is flawlessly working on Edge 520/520plus since a year.
If I set my datafield on Edge 530 and start it, it works perfectly. However if I restart the Edge and start the datafield it doesn`t communicate with my sensor, not showing any data.
If I swap the datafield to another one, restart the device, swap back, and start it, it is working until I restart the device again.
I don`t know how to debug this problem. Is there anyone who met the same problem?  Is there a bug in my program or in Edge 530?
Thanks in advance! :)
Parents
    Former Member in reply to Stephen.ConnectIQ
    I've tried using the Moxy ConnectIQ apps (with 4x Moxy sensors) on an Edge 530 a few times now with no success.
    On previous firmware, the connections were extremely unreliable, not connecting at all far more often than they would connect. Half the time the datafield would show the IQ error icon. Restarting the 530 device or selecting a new activity profile would just as often cause a different data field to throw up an error icon, as it would solve the existing errors. I never even bothered to test a real-world use case to see if the behaviour work improve or break further over time. I could never get all four sensors to work at the same time.
    Updating to firmware 5.00 seemed to show the exact same issues, with failures to connect, error icons, etc.
    Downgrading to beta 4.25 firmware on Roger's suggestion seemed to be a slight improvement? But the behaviour was still un-usable. Datafields seemed a bit more prepared to connect to a sensor after a 1-2min delay (whereas this is instantaneous on the 520), but still I could never get all 4 to work simultaneously. Restarting an individual sensor might allow it to connect when it hadn't before, or just as often it would fail to connect when it had before. And restarting the 530 device was a crapshoot as well.
    I typically try to isolate and reproduce issues like this before sending support requests, but I don't even know where to start with this one. It's just completely inconsistent.
Comment
Children
No Data
