Acknowledged
CIQQA-4662
Edge Explore 2 FW 31.33: Ble.registerProfile() with a custom 128-bit service UUID crashes the data field with a System Error (regression from FW 30.23)
Device: Edge Explore 2 (Part-Number 006-B4169-00)
Firmware: 31.33 — broken. 30.23 — worked.
Connect IQ on device: 6.0.2 (API 6.0.0)
SDK: 9.2.0 (2026-06-09)
App type: data field, permissions BluetoothLowEnergy + FitContributor
Summary
On firmware 31.33, calling BluetoothLowEnergy.registerProfile() with a custom 128-bit service UUID kills the data field from inside the call. The failure is a System Error: 'Failed invoking <symbol>', which cannot be caught by try/catch, so an application has no way to recover or degrade gracefully.
The same code runs correctly on firmware 30.23 on the same device with the same peripheral, so this is a regression.
Profile being registered
Ble.registerProfile({
    :uuid => Ble.stringToUuid("000018ef-5348-494d-414e-4f5f424c4500"),
    :characteristics => [
            :uuid => Ble.stringToUuid("00002ac1-5348-494d-414e-4f5f424c4500"),
            :descriptors => [Ble.cccdUuid()]
Registering the same profile without the explicit CCCD descriptor crashes as well.
Crash log (GARMIN/APPS/LOGS/CIQ_LOG.YML)
Error: System Error
Details: 'Failed invoking <symbol>'
Time: 2026-08-22T12:42:54Z
Part-Number: 006-B4169-00
Firmware-Version: '31.33'
ConnectIQ-Version: 6.0.2
Stack:
  - pc: 0x100028a6
    File: 'Di2BleDelegate.mc'
    Line: 396          # the Ble.registerProfile(...) call itself
    Function: registerModeProfile
  - pc: 0x1000325d
    Line: 358
    Function: registerProfiles
  - pc: 0x10003682
    Line: 143
    Function: start
  - pc: 0x1000041a
    File: 'Di2FieldApp.mc'
    Line: 33
    Function: onStart
A standard service registers fine in the same run
Registering the standard Battery Service in the same application succeeds, so registerProfile() itself works — only the custom 128-bit UUID above is fatal:
register mode profile skipped after 2 crashes
profile register 180F:ok
services n=1 [0000180F-0000-1000-8000-00805F9B34FB ]
Earlier symptom on the same firmware
Before the call became fatal, an earlier build received an undocumented status = 2 in onProfileRegister() for this profile, while the battery profile got STATUS_SUCCESS. 2 is not among the documented Status values (0 SUCCESS, 1 NOT_ENOUGH_RESOURCES, 12 READ_FAIL, 14 WRITE_FAIL, 18/19 authentication/encryption). A similar undocumented status = 2 on profile registration was reported for VivoActive 4 and fixed in FW 5.63, so this may be the same defect resurfacing on Edge.
Minimal reproduction
A stand-alone data field (~60 lines) that only registers the profile and draws the result reproduces it. No peripheral is required — the crash happens during registration, before any scan or connection. I can attach the full project if useful.
function onStart(state) {
    var d = new ReproDelegate();
    Ble.setDelegate(d);
    var chr = WITH_CCCD
        ? { :uuid => Ble.stringToUuid(CHAR_UUID), :descriptors => [Ble.cccdUuid()] }
        : { :uuid => Ble.stringToUuid(CHAR_UUID) };
    try {
        // FW 31.33: the application dies here. No exception is delivered.
            :uuid => Ble.stringToUuid(SERVICE_UUID),
            :characteristics => [chr]
    } catch (e) {
        d.status = "exception";   // never reached
On FW 30.23 the field draws "registered"; on FW 31.33 it is replaced by the Connect IQ error icon.
Steps to reproduce
  1. Build a data field with the BluetoothLowEnergy permission.
  2. In AppBase.onStart(), call Ble.setDelegate(...) and then Ble.registerProfile(...) with the custom profile shown above.
  3. Install on an Edge Explore 2 running FW 31.33 and add the field to a data screen.
  4. The field shows the Connect IQ error icon immediately; CIQ_LOG.YML contains the stack above.
Only one BLE profile is registered at this point, so this is not the "3 profiles maximum" limit. Reordering registrations, dropping the descriptor and registering before/after setDelegate make no difference.
Impact
Third-party fields that talk to a peripheral over a vendor-specific GATT service cannot run at all on this firmware — the app dies at startup and cannot detect, catch or work around the failure. On 30.23 the identical build connects, subscribes to the characteristic and receives notifications normally.
Request
  1. Restore the ability to register custom 128-bit service UUIDs, as on FW 30.23.
  2. If registration must fail, please fail through onProfileRegister(uuid, status) with a documented status instead of terminating the application from inside the call — an app cannot catch a System Error.
  3. Please document status = 2.
Parents Comment Children
No Data
