Acknowledged
Edge Device Reference Error
Recently, I received a report of an error from a user and found it while working on a fix.
Reference Guides
According to the reference guide, the largest screen size in 5 Field B layout mode on the Garmin Edge 1040 is 282x186.
However, the height of replying from the actual device is 184
Please edit the reference ...
  • Oh yeah, I def believe you, I was just answering flocsy's question.
  • yes.
    But, I checked with my Edge 1040 device.
    Reference data was wrong.
  • The "5 Fields B" layout in edge1040/simulator.json matches the device reference, including the 282 x 186 dimensions for the second field..
        "drawBorders": true,
        "fields": [
                "data": {
                    "font": "numberHot",
                    "justification": "center",
                    "width": 282,
                    "x": 141,
                    "y": 82
                "label": {
                    "font": "small",
                    "x": 141,
                    "y": 24
                "labelDisabled": false,
                "location": {
                    "height": 93,
                    "width": 282,
                    "x": 0,
                    "y": 0
                "obscurity": []
                "data": {
                    "font": "numberThaiHot",
                    "width": 282,
                    "x": 141,
                    "y": 134
                "label": {
                    "font": "small",
                    "x": 141,
                    "y": 24
                "location": {
                    "height": 186,
                    "width": 282,
                    "x": 0,
                    "y": 95
                "obscurity": []
                "data": {
                    "font": "numberMedium",
                    "width": 140,
                    "x": 70,
                    "y": 72
                "label": {
                    "font": "small",
                    "x": 70,
                    "y": 24
                "location": {
                    "height": 92,
                    "width": 140,
                    "x": 0,
                    "y": 283
                "obscurity": []
                "data": {
                    "width": 140,
                    "x": 70,
                    "y": 72
                "label": {
                    "font": "small",
                    "x": 70,
                    "y": 24
                "location": {
                    "height": 92,
                    "width": 140,
                    "x": 142,
                    "y": 283
                "obscurity": []
                "data": {
                    "width": 282,
                    "x": 141,
                    "y": 82
                "label": {
                    "font": "small",
                    "x": 141,
                    "y": 24
                "location": {
                    "height": 93,
                    "width": 282,
                    "x": 0,
                    "y": 377
                "obscurity": []
        "name": "5 Fields B"
  • Can you also check in the simulator.json?
