Acknowledged
Edge Application Activity recording freeze out the device after the application is closed.
Hello!
I'm developing an Application on Edge 1030 plus which is using Activity recording.
The not deadly issue: In my application you can choose to save or discard the current session. Whatever you choose, the app stop the session, save or discard it then exit with System.exit(). If you go back to main menu and choose one from Garmin's activity profiles then it will start and pop up as it is already paused -> the timer is 00:00, red frame around with little finish flag and asking do I want to save or discard the ride. (The normal stop screen at Activity profiles.).
The deadly issue: today it froze differently. It has the same issue with activity profile's however I couldn't click on the little finish(the discard/save screen didn't pop). I can switch between the Activity's screens, also close the the Activity, go around in the Settings etc. However I couldn't "re"start my Application, nothing happened when I clicked on it. Also couldn't switch off the device because it said and application is still running. I had to reset the device.
