On the Edge 530, the Generic ANT channel freezes after waking from sleep. To view the problem:
- Set up a Data Field with a generic ANT Channel
- Insert the Data Field into a Ride
- Go into a ride with the Data Field showing but don't start the ride
- Wait 5 minutes for the Edge to go to sleep.
- The Generic ANT channel will not work when the Edge is woke up.
This video shows the details.
A work around requires first detecting that it happened and then programmatically resetting the ANT channel so it works again. Detection is not simple because the data field doesn't get any indication when the Edge goes to sleep or wakes up. It's also difficult to distinguish between a frozen ANT channel and a channel that is just searching for a sensor. I have not come up with a sequence to programmatically reset the channel yet, but I will keep trying.
This seems like it might be a rare occurrence, but our customers run into quite frequently and it appears to them like it's a random bug. They assume the problem is on the Moxy side and they try powering it off and hard resetting it and trying to change the sensor settings.
I have firmware 9.73 on the Edge 530.
Please let me know if I can provide more information about the problem.
Roger
6747384
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
6747384
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
