In https://developer.garmin.com/connect-iq/api-docs/Toybox/Communications.html#makeWebRequest-instance_function you do the following:
function makeRequest() {
var url = "https://www.garmin.com"; // set the url
var params = { // set the parameters
"definedParams" => "123456789abcdefg"
var options = { // set the options
:method => Communications.HTTP_REQUEST_METHOD_GET, // set HTTP method
:headers => { // set headers
"Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED},
// set response type
:responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_URL_ENCODED
var responseCallback = method(:onReceive); // set responseCallback to
// onReceive() method
// Make the Communications.makeWebRequest() call
Communications.makeWebRequest(url, params, options, method(:onReceive));
The example code has a "bug", it doesn't make use of the just create responseCallback var.
// Change to
Communications.makeWebRequest(url, params, options, responseCallBack);
