Acknowledged
CIQQA-4267
Device.requestBond() crashes the Connect IQ 9.2.0 simulator (SIGSEGV / null deref)
Seems to be related to CIQQA-4261
Environment: Connect IQ SDK 9.2.0 (2026-06-09), macOS; nRF52840 USB dongle on connectivity_1.0.0_usb_with_s140_6.1.1 (current per the 9.2.0 BLE guide).
Repro:
1. App (data field or device app) with the BluetoothLowEnergy permission.
2. Scan, then connect to a BLE peripheral via BluetoothLowEnergy.pairDevice(scanResult) (called from a compute()/timer tick, not from inside onScanResults, due to the issues in CIQQA-4261).
3. Call device.requestBond().
Result: the simulator process crashes with EXC_BAD_ACCESS (SIGSEGV), KERN_INVALID_ADDRESS at 0x0, on a native BLE worker thread. I attached one of the crash reports
{"app_name":"simulator","timestamp":"2026-06-11 10:27:28.00 +0200","app_version":"9.2.0","slice_uuid":"73186c85-b082-3c5d-865b-e76845f9c7e3","build_version":"9.2.0","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 26.5.1 (25F80)","roots_installed":0,"name":"simulator","incident_id":"9886445A-B5B0-4E97-B424-18E4D1F19DF3"}
  "uptime" : 94000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "Mac17,7",
  "coalitionID" : 11970,
  "osVersion" : {
    "train" : "macOS 26.5.1",
    "build" : "25F80",
    "releaseType" : "User"
  "captureTime" : "2026-06-11 10:27:26.0537 +0200",
  "codeSigningMonitor" : 2,
  "incident" : "9886445A-B5B0-4E97-B424-18E4D1F19DF3",
  "pid" : 91999,
  "translated" : false,
  "cpuType" : "ARM-64",
  "procLaunch" : "2026-06-11 10:27:18.8387 +0200",
  "procStartAbsTime" : 2274850783636,
  "procExitAbsTime" : 2275023841734,
  "procName" : "simulator",
  "procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
  "bundleInfo" : {"CFBundleShortVersionString":"9.2.0","CFBundleVersion":"9.2.0","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
  "storeInfo" : {"deviceIdentifierForVendor":"BBCDC997-6C81-53FE-91D8-58C6CF3472C6","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.garmin.connectiq.simulator",
  "crashReporterKey" : "23CED584-3691-39E8-EFDF-229F34447F24",
  "appleIntelligenceStatus" : {"state":"available"},
  "developerMode" : 1,
  "codeSigningID" : "com.garmin.connectiq.simulator",
  "codeSigningTeamID" : "72ES32VZUA",
  "codeSigningFlags" : 570503953,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 4294967295,
  "codeSigningAuxiliaryInfo" : 0,
  "bootSessionUUID" : "5877D1A8-CB7D-4807-804E-8E4D15E8B55F",
  "sip" : "enabled",
  "vmRegionInfo" : "0 is not in any region.  Bytes before following region: 4371070976\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      104894000-105a84000    [ 17.9M] r-x\/r-x SM=COW  \/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":91999},
  "vmregioninfo" : "0 is not in any region.  Bytes before following region: 4371070976\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      104894000-105a84000    [ 17.9M] r-x\/r-x SM=COW  \/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 30,
  "threads" : [{"id":6560563,"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592,"symbolLocation":32,"symbol":"vtable for WebCore::LibWebRTCDTMFSenderBackend"},{"value":23102629085184},{"value":0},{"value":23102629085184},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":5379},{"value":7696581396224},{"value":18446744073709551569},{"value":8536422160},{"value":0},{"value":4294967295},{"value":2},{"value":23102629085184},{"value":0},{"value":23102629085184},{"value":21592279046},{"value":6095800552},{"value":8589934592,"symbolLocation":32,"symbol":"vtable for WebCore::LibWebRTCDTMFSenderBackend"},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699386228},"cpsr":{"value":0},"fp":{"value":6095800400},"sp":{"value":6095800320},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699310132},"far":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":3},{"imageOffset":79220,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":3},{"imageOffset":39360,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":3},{"imageOffset":4032,"symbol":"mach_msg","symbolLocation":24,"imageIndex":3},{"imageOffset":516312,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":4},{"imageOffset":510404,"symbol":"__CFRunLoopRun","symbolLocation":1188,"imageIndex":4},{"imageOffset":1372612,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":532,"imageIndex":4},{"imageOffset":775520,"symbol":"RunCurrentEventLoopInMode","symbolLocation":320,"imageIndex":5},{"imageOffset":788668,"symbol":"ReceiveNextEventCommon","symbolLocation":488,"imageIndex":5},{"imageOffset":2400588,"symbol":"_BlockUntilNextEventMatchingListInMode","symbolLocation":48,"imageIndex":5},{"imageOffset":7230300,"symbol":"_DPSBlockUntilNextEventMatchingListInMode","symbolLocation":228,"imageIndex":6},{"imageOffset":233604,"symbol":"_DPSNextEvent","symbolLocation":576,"imageIndex":6},{"imageOffset":12380336,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":688,"imageIndex":6},{"imageOffset":12379580,"symbol":"-[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:]","symbolLocation":72,"imageIndex":6},{"imageOffset":180540,"symbol":"-[NSApplication run]","symbolLocation":368,"imageIndex":6},{"imageOffset":12501572,"imageIndex":0},{"imageOffset":11537912,"imageIndex":0},{"imageOffset":11012232,"imageIndex":0},{"imageOffset":10828836,"imageIndex":0},{"imageOffset":12244716,"imageIndex":0},{"imageOffset":11200316,"imageIndex":0},{"imageOffset":297756,"imageIndex":0},{"imageOffset":130560,"symbol":"start","symbolLocation":6992,"imageIndex":7}]},{"id":6560566,"frames":[],"threadState":{"x":[{"value":6096367616},{"value":7171},{"value":6095831040},{"value":0},{"value":409602},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6096367616},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699568136},"far":{"value":0}}},{"id":6560567,"frames":[],"threadState":{"x":[{"value":6096941056},{"value":10499},{"value":6096404480},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6096941056},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699568136},"far":{"value":0}}},{"id":6560646,"frames":[],"threadState":{"x":[{"value":6097514496},{"value":18435},{"value":6096977920},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6097514496},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699568136},"far":{"value":0}}},{"id":6560689,"frames":[],"threadState":{"x":[{"value":6098087936},{"value":81935},{"value":6097551360},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6098087936},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699568136},"far":{"value":0}}},{"id":6560692,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592,"symbolLocation":32,"symbol":"vtable for WebCore::LibWebRTCDTMFSenderBackend"},{"value":129755256979456},{"value":0},{"value":129755256979456},{"value":2},{"value":4294967295},{"value":0},{"value":17179869184},{"value":0},{"value":2},{"value":0},{"value":0},{"value":30211},{"value":0},{"value":18446744073709551569},{"value":8536422160},{"value":0},{"value":4294967295},{"value":2},{"value":129755256979456},{"value":0},{"value":129755256979456},{"value":21592279046},{"value":6098657416},{"value":8589934592,"symbolLocation":32,"symbol":"vtable for WebCore::LibWebRTCDTMFSenderBackend"},{"value":18446744073709550527},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699386228},"cpsr":{"value":0},"fp":{"value":6098657264},"sp":{"value":6098657184},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699310132},"far":{"value":0}},"frames":[{"imageOffset":3124,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":3},{"imageOffset":79220,"symbol":"mach_msg2_internal","symbolLocation":76,"imageIndex":3},{"imageOffset":39360,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":3},{"imageOffset":4032,"symbol":"mach_msg","symbolLocation":24,"imageIndex":3},{"imageOffset":516312,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":4},{"imageOffset":510404,"symbol":"__CFRunLoopRun","symbolLocation":1188,"imageIndex":4},{"imageOffset":1372612,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":532,"imageIndex":4},{"imageOffset":1420412,"symbol":"_NSEventThread","symbolLocation":184,"imageIndex":6},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560695,"name":"TSK bkgd","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6099234408},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614503320},{"value":50614503384},{"value":6099235040},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6099234528},"sp":{"value":6099234384},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":9537804,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560698,"name":"NFM_Region_0","threadState":{"x":[{"value":260},{"value":0},{"value":4352},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6099807608},{"value":0},{"value":512},{"value":2199023256066},{"value":2199023256066},{"value":512},{"value":0},{"value":2199023256064},{"value":305},{"value":8536420280},{"value":0},{"value":50614506456},{"value":50614506520},{"value":6099808480},{"value":0},{"value":0},{"value":4352},{"value":4353},{"value":4608},{"value":4284},{"value":64081}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6099807728},"sp":{"value":6099807584},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":10112400,"imageIndex":0},{"imageOffset":9537856,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560699,"name":"Cache Mngr","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6100381048},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50620713824},{"value":50620713928},{"value":6100381920},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4294967295},{"value":6100381440}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6100381168},"sp":{"value":6100381024},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9535924,"imageIndex":0},{"imageOffset":9569716,"imageIndex":0},{"imageOffset":9818664,"imageIndex":0},{"imageOffset":9804844,"imageIndex":0},{"imageOffset":9537856,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560700,"name":"IOPAppMain","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6100954648},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614507800},{"value":50614507864},{"value":6100955360},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6100954768},"sp":{"value":6100954624},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6654352,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560701,"name":"ant_main","threadState":{"x":[{"value":260},{"value":0},{"value":5376},{"value":0},{"value":0},{"value":65704},{"value":2},{"value":867504000},{"value":5377},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614508248},{"value":50614508312},{"value":1},{"value":867504000},{"value":2},{"value":5376},{"value":5377},{"value":5632},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589972},"cpsr":{"value":2684354560},"fp":{"value":6101528176},"sp":{"value":6101528032},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":29012,"symbol":"_pthread_cond_wait","symbolLocation":1024,"imageIndex":9},{"imageOffset":9536516,"imageIndex":0},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6275144,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560702,"name":"GPS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6102101608},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614511384},{"value":50614511448},{"value":6102102240},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6102101728},"sp":{"value":6102101584},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":9537804,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560703,"name":"SNS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6102675048},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614508696},{"value":50614508760},{"value":6102675680},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6102675168},"sp":{"value":6102675024},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":9537804,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560704,"name":"fit activity","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6103246872},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614509144},{"value":50614509208},{"value":6103249120},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":4392437688},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6103246992},"sp":{"value":6103246848},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6951444,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560705,"name":"ftm main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998907000},{"value":1537},{"value":0},{"value":256},{"value":1099511628034},{"value":1099511628034},{"value":256},{"value":0},{"value":1099511628032},{"value":305},{"value":8536420280},{"value":0},{"value":50614509592},{"value":50614509656},{"value":1},{"value":998907000},{"value":0},{"value":256},{"value":1537},{"value":1792},{"value":4391133184,"symbolLocation":37288,"symbol":"guard variable for wxAnyValueTypeImpl<std::__1::function<void ()>>::sm_instance"},{"value":1}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589972},"cpsr":{"value":2684354560},"fp":{"value":6103820720},"sp":{"value":6103820576},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":29012,"symbol":"_pthread_cond_wait","symbolLocation":1024,"imageIndex":9},{"imageOffset":9536516,"imageIndex":0},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":7013116,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560706,"name":"TVM main","threadState":{"x":[{"value":260},{"value":0},{"value":4352},{"value":0},{"value":0},{"value":65704},{"value":295},{"value":133059000},{"value":4353},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614510488},{"value":50614510552},{"value":1},{"value":133059000},{"value":295},{"value":4352},{"value":4353},{"value":4608},{"value":4392488960},{"value":4391751680}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589972},"cpsr":{"value":2684354560},"fp":{"value":6104395280},"sp":{"value":6104395136},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":29012,"symbol":"_pthread_cond_wait","symbolLocation":1024,"imageIndex":9},{"imageOffset":9536516,"imageIndex":0},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":9152880,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560711,"name":"parse main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6104967672},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614510936},{"value":50614511000},{"value":6104969440},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6104967792},"sp":{"value":6104967648},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":138020,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560712,"name":"GPX archive trk","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6105542040},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614512280},{"value":50614512344},{"value":6105542880},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":5400},{"value":214749}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6105542160},"sp":{"value":6105542016},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":10192200,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560713,"name":"URM Main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6106115656},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614512728},{"value":50614512792},{"value":6106116320},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6106115776},"sp":{"value":6106115632},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6850220,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560714,"name":"mma sql bkg","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6106689128},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614513176},{"value":50614513240},{"value":6106689760},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6106689248},"sp":{"value":6106689104},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":9537804,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560890,"name":"TLG main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":48759},{"value":999267000},{"value":257},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614501976},{"value":50614502040},{"value":1},{"value":999267000},{"value":48759},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589972},"cpsr":{"value":2684354560},"fp":{"value":6108982896},"sp":{"value":6108982752},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":29012,"symbol":"_pthread_cond_wait","symbolLocation":1024,"imageIndex":9},{"imageOffset":9536516,"imageIndex":0},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":10191628,"imageIndex":0},{"imageOffset":9537856,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560891,"name":"libcurl Async H","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6109556200},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50595938456},{"value":50595938520},{"value":6109556960},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":6109556496},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6109556320},"sp":{"value":6109556176},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6818984,"imageIndex":0},{"imageOffset":9537856,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560892,"name":"Download Manage","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6110129528},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50595938904},{"value":50595938968},{"value":6110130400},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4386683549,"symbolLocation":442405,"symbol":"std::__1::piecewise_construct"},{"value":4392404952}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6110129648},"sp":{"value":6110129504},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9541272,"imageIndex":0},{"imageOffset":6830116,"imageIndex":0},{"imageOffset":9537856,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560893,"name":"Shell main","threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":4397654496},{"value":50612685440},{"value":0},{"value":18446744072631617535},{"value":18446726482597246976},{"value":4381233708},{"value":4381233548},{"value":2},{"value":0},{"value":1024},{"value":15224974535138489526},{"value":4397990000},{"value":50612682752},{"value":30},{"value":5200937984},{"value":0},{"value":50612685440},{"value":4391141376,"symbolLocation":568,"symbol":"guard variable for HlsTracker::get(int)::sHlsTracker"},{"value":4392595456},{"value":4392596948},{"value":4392595456},{"value":2048},{"value":4392595456},{"value":4392596944},{"value":16},{"value":4}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4381232476},"cpsr":{"value":1610612736},"fp":{"value":6110703376},"sp":{"value":6110703312},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699345612},"far":{"value":0}},"frames":[{"imageOffset":38604,"symbol":"__accept","symbolLocation":8,"imageIndex":3},{"imageOffset":10161500,"imageIndex":0},{"imageOffset":10149760,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560897,"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":26712,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":32,"imageIndex":10},{"imageOffset":968004,"imageIndex":0},{"imageOffset":967688,"imageIndex":0},{"imageOffset":967348,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6111850040},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50614624736},{"value":50614624800},{"value":6111850720},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6111850160},"sp":{"value":6111850016},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}}},{"id":6560899,"frames":[{"imageOffset":38604,"symbol":"__accept","symbolLocation":8,"imageIndex":3},{"imageOffset":1443968,"imageIndex":0},{"imageOffset":1188344,"imageIndex":0},{"imageOffset":11603692,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":6112423280},{"value":50617441872},{"value":1},{"value":1},{"value":18446726482597246976},{"value":1},{"value":2764917440064258271},{"value":2},{"value":0},{"value":4800998},{"value":15224974535125409894},{"value":4398008288},{"value":50617434112},{"value":30},{"value":39347372518},{"value":0},{"value":50617393024},{"value":50616454640},{"value":4391755368},{"value":4372259480},{"value":6112423672},{"value":4391145561,"symbolLocation":41,"symbol":"guard variable for wxAnyValueTypeImpl<wxVariant>::sm_instance"},{"value":6112423624},{"value":4392181760},{"value":6112423936},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4372514944},"cpsr":{"value":1610612736},"fp":{"value":6112423328},"sp":{"value":6112423296},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699345612},"far":{"value":0}}},{"id":6560993,"name":"Shell handler","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6112996744},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":4391715368},{"value":4391715464},{"value":6112997600},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4391153992},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6112996864},"sp":{"value":6112996720},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}},"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":9535924,"imageIndex":0},{"imageOffset":1441068,"imageIndex":0},{"imageOffset":10160788,"imageIndex":0},{"imageOffset":10158356,"imageIndex":0},{"imageOffset":10152316,"imageIndex":0},{"imageOffset":9537832,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6560994,"frames":[{"imageOffset":21436,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":3},{"imageOffset":10162504,"imageIndex":0},{"imageOffset":10158548,"imageIndex":0},{"imageOffset":1427944,"imageIndex":0},{"imageOffset":1460660,"imageIndex":0},{"imageOffset":11603692,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":4},{"value":0},{"value":12},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":4381233428},{"value":2142777205},{"value":0},{"value":0},{"value":40466964971769994},{"value":40449370638239771},{"value":512000},{"value":16},{"value":29},{"value":8536420376},{"value":0},{"value":12},{"value":50612684256},{"value":50612684208},{"value":12},{"value":40},{"value":50627477936},{"value":48},{"value":9223372036854775799},{"value":3},{"value":50627479712}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4381233480},"cpsr":{"value":536870912},"fp":{"value":6111276192},"sp":{"value":6111276160},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699328444},"far":{"value":0}}},{"id":6561130,"frames":[],"threadState":{"x":[{"value":6114144256},{"value":78939},{"value":6113607680},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6114144256},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699568136},"far":{"value":0}}},{"id":6561131,"frames":[],"threadState":{"x":[{"value":6114717696},{"value":0},{"value":6114181120},{"value":0},{"value":278531},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":0},"fp":{"value":0},"sp":{"value":6114717696},"esr":{"value":0},"pc":{"value":6699568136},"far":{"value":0}}},{"triggered":true,"id":6561233,"threadState":{"x":[{"value":4392477857},{"value":385},{"value":6113568976},{"value":6113568760},{"value":6113568756},{"value":6113568755},{"value":0},{"value":18446726482597246976},{"value":0},{"value":4392477856},{"value":0},{"value":2147497229},{"value":384},{"value":16777216},{"value":3579898695},{"value":50610175289},{"value":6699627360,"symbolLocation":0,"symbol":"_platform_memmove"},{"value":208},{"value":0},{"value":50610126848},{"value":4390325272},{"value":4392169856},{"value":50610127534},{"value":50610127008},{"value":50610127529},{"value":142},{"value":1073741824},{"value":858993459},{"value":4390341704}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4379857680},"cpsr":{"value":1610614784},"fp":{"value":6113569120},"sp":{"value":6113569040},"esr":{"value":2181038086,"description":"(Instruction Abort) Translation fault"},"pc":{"value":0},"far":{"value":0}},"frames":[{"imageOffset":0,"imageIndex":8},{"imageOffset":8786704,"imageIndex":0},{"imageOffset":9454988,"imageIndex":0},{"imageOffset":9472404,"imageIndex":0},{"imageOffset":9475060,"imageIndex":0},{"imageOffset":9477616,"imageIndex":0},{"imageOffset":1771584,"imageIndex":0},{"imageOffset":1922008,"imageIndex":0},{"imageOffset":1570092,"imageIndex":0},{"imageOffset":1932748,"imageIndex":0},{"imageOffset":1562964,"imageIndex":0},{"imageOffset":1460660,"imageIndex":0},{"imageOffset":11603692,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}]},{"id":6561234,"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":26712,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":32,"imageIndex":10},{"imageOffset":10709928,"imageIndex":0},{"imageOffset":10710956,"imageIndex":0},{"imageOffset":10727908,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":260},{"value":0},{"value":30464},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6107262504},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50621109872},{"value":50621109936},{"value":6107263200},{"value":0},{"value":0},{"value":30464},{"value":30465},{"value":30720},{"value":50617663344},{"value":50625667920}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6107262624},"sp":{"value":6107262480},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}}},{"id":6561328,"frames":[{"imageOffset":28612,"symbol":"kevent","symbolLocation":8,"imageIndex":3},{"imageOffset":10768296,"imageIndex":0},{"imageOffset":10773496,"imageIndex":0},{"imageOffset":10772864,"imageIndex":0},{"imageOffset":10801728,"imageIndex":0},{"imageOffset":10801424,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":6108403728},{"value":128},{"value":6108403696},{"value":0},{"value":1},{"value":50619452640},{"value":2},{"value":0},{"value":2},{"value":0},{"value":0},{"value":808960},{"value":10},{"value":363},{"value":30001322174},{"value":0},{"value":6108409264},{"value":50619452600},{"value":0},{"value":1},{"value":50619452544},{"value":6108409264},{"value":50604605648},{"value":50604605648},{"value":1},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4381839272},"cpsr":{"value":1610612736},"fp":{"value":6108408944},"sp":{"value":6108403648},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699335620},"far":{"value":0}}},{"id":6561455,"frames":[{"imageOffset":17676,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":3},{"imageOffset":28968,"symbol":"_pthread_cond_wait","symbolLocation":980,"imageIndex":9},{"imageOffset":26712,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":32,"imageIndex":10},{"imageOffset":10733136,"imageIndex":0},{"imageOffset":10737444,"imageIndex":0},{"imageOffset":27736,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":9},{"imageOffset":7196,"symbol":"thread_start","symbolLocation":8,"imageIndex":9}],"threadState":{"x":[{"value":260},{"value":0},{"value":3584},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6115290344},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8536420280},{"value":0},{"value":50596059736},{"value":50596059800},{"value":6115291360},{"value":0},{"value":0},{"value":3584},{"value":3585},{"value":3840},{"value":61},{"value":50617441968}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6699589928},"cpsr":{"value":1610612736},"fp":{"value":6115290464},"sp":{"value":6115290320},"esr":{"value":1442840704,"description":"(Syscall)"},"pc":{"value":6699324684},"far":{"value":0}}}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4371070976,
    "CFBundleShortVersionString" : "9.2.0",
    "CFBundleIdentifier" : "com.garmin.connectiq.simulator",
    "size" : 18808832,
    "uuid" : "73186c85-b082-3c5d-865b-e76845f9c7e3",
    "path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "name" : "simulator",
    "CFBundleVersion" : "9.2.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4395712512,
    "size" : 49152,
    "uuid" : "ca58aa96-b997-3a6d-9132-19d49be4b3e9",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4889313280,
    "CFBundleShortVersionString" : "351.2",
    "CFBundleIdentifier" : "com.apple.AGXMetalG17X",
    "size" : 10207232,
    "uuid" : "81e8aeac-3aa5-3303-a8d0-b18b74a6d94b",
    "path" : "\/System\/Library\/Extensions\/AGXMetalG17X.bundle\/Contents\/MacOS\/AGXMetalG17X",
    "name" : "AGXMetalG17X",
    "CFBundleVersion" : "351.2"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6699307008,
    "size" : 250544,
    "uuid" : "cc1cf985-bc65-3725-809f-4c1e36b8f4ba",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6699847680,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5628704,
    "uuid" : "04e3598b-f226-3250-b3b2-ce938dd4db7e",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "5026.5.4"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6915481600,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3125536,
    "uuid" : "8716490e-acc2-3688-8c2f-5ca42b4c9da9",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6771617792,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 24260512,
    "uuid" : "cf57a4fc-4be3-3d95-b543-d744e8718b26",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2685.60.104"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6695534592,
    "size" : 680472,
    "uuid" : "a237ef81-b68b-37ba-a165-92c965529534",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6699560960,
    "size" : 52028,
    "uuid" : "4f33683c-18c8-39a1-800b-2e3bd43bcc13",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6698602496,
    "size" : 592616,
    "uuid" : "5013c0f8-84a9-3b56-9feb-c353816a750f",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6699614208,
    "size" : 35172,
    "uuid" : "160fd864-8d15-36fc-9e97-9725388cfafe",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
  "sharedCache" : {
  "base" : 6694404096,
  "size" : 5990596608,
  "uuid" : "ff7119a7-f64d-305d-8135-7e6eb1c207d1"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.8G resident=0K(0%) swapped_out_or_unallocated=1.8G(100%)\nWritable regions: Total=323.0M written=721K(0%) resident=721K(0%) swapped_out=0K(0%) unallocated=322.3M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               128K        1 \nActivity Tracing                   256K        1 \nCG image                          3808K        9 \nCG raster data                    2480K        6 \nColorSync                           48K        3 \nCoreAnimation                     1360K       53 \nCoreGraphics                        48K        3 \nCoreUI image data                 1152K        9 \nDispatch continuations           144.0M        2 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                            82.5M       30 \nMALLOC guard page                 4000K        4 \nMemory Tag 22                     64.0M        1 \nSTACK GUARD                       56.5M       34 \nStack                             25.5M       35 \nVM_ALLOCATE                        160K       10 \n__AUTH                            5954K      628 \n__AUTH_CONST                      88.2M     1013 \n__CTF                               824        1 \n__DATA                            35.4M      960 \n__DATA_CONST                      35.4M     1019 \n__DATA_DIRTY                      8298K      867 \n__FONT_DATA                        2352        1 \n__LINKEDIT                       577.4M        4 \n__OBJC_RO                         79.1M        1 \n__OBJC_RW                         2599K        1 \n__TEXT                             1.2G     1043 \n__TPRO_CONST                       128K        2 \nmapped file                      420.6M       28 \npage table in kernel               721K        1 \nshared memory                     1392K       13 \n===========                     =======  ======= \nTOTAL                              2.8G     5785 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "logWritingSignature" : "d3529234e4d04857ebd84959663bb8ec589da3bd",
  "bug_type" : "309",
  "roots_installed" : 0,
  "trmStatus" : 1,
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "67181b10c68c361a728c7cfa",
      "factorPackIds" : [
      "deploymentId" : 240000005
      "rolloutId" : "64c025b28b7f0e739e4fbe58",
      "factorPackIds" : [
        "657ba0a39ec5da283662e9d2"
      "deploymentId" : 240000041
  "experiments" : [
Reproduces both after onConnectedStateChanged(CONNECTED) (e.g. a heart-rate strap) and on the pre-CONNECTED pairDevice handle (e.g. a GoPro).
