Hello,
I am the developer of RadioRanger, a published Connect IQ Device App.
App ID: b45a8337-4c42-4fc6-8b2a-0250c6ec514b
Current version: 2.0.0
Connect IQ SDK: 9.2.0
I am reporting what appears to be a device compatibility mapping issue affecting Descent Mk2 / Mk2i.
My manifest explicitly contains:
<iq:product id="descentmk2"/>
with:
minApiLevel="3.4.0"
The SDK 9.2.0 device definition for descentmk2 reports:
displayName: Descent Mk2 / Mk2ideviceGroup: API level 3.4
It also contains both hardware part numbers:
006-B3258-00 — Connect IQ 3.4.5006-B3702-00 — Connect IQ 3.4.5
Therefore both variants satisfy the application's minimum API level.
The application exports successfully:
46 OUT OF 46 DEVICES BUILTBUILD SUCCESSFUL
There are no export warnings.
When version 2.0.0 is uploaded, the Connect IQ upload validator reports:
Status: VerifiedSignature: Verified
and Descent MK2 appears in the Compatible Devices list.
However, after Store processing, Descent Mk2 / Mk2i is missing from the Store compatible-device list.
This creates a reproducible discrepancy:
SDK 9.2.0: Descent Mk2 / Mk2i supported
Manifest: descentmk2 included
Minimum API: satisfied by both part numbers
Export: successful
Upload validation: Descent MK2 compatible
Store listing: Descent Mk2 / Mk2i removed
Could you please check the Connect IQ Store device mapping for the descentmk2 target, particularly part numbers 006-B3258-00 and 006-B3702-00?
Please note that descentmk2 is the SDK device ID for both Descent Mk2 and Mk2i; there is no separate descentmk2i target in SDK 9.2.0.
Thank you.
