I know this issue has been raised before but with the new app I'm writing I'm trying to be a good citizen and to avoid all compiler warnings, so as the issue bothers me I'm raising it again. :)
It's simply impossible (I don't consider providing a command line parameter option to ignore warnings a valid option) to create a warning free app if you also want to support "older" devices
in particular in this specific app the warnings I'm seeing are:
WARNING: device name: soucefile: '$.Toybox.ActivityRecording.SPORT_TRAINING' is deprecated.
WARNING: device name: soucefile: '$.Toybox.Application.AppBase.getProperty' is deprecated.
WARNING: device name: sourcefile: '$.Toybox.Application.AppBase.setProperty' is deprecated.
Is it really not possible to make this warning context aware? Surely this should not be too hard?
Eg if you are building for a fenix 3 you know that:
- you can not use the Toybox.Activity.Sport types as they are only available as of api 3.2.0 and that you HAVE to reside to ActivityRecording types
- you can not use Storage.getValue or Properties.getValue as they are only available as of api 2.4.0 and that you HAVE to reside to getProperty
TL/DR make the deprecation warning context aware and only raise it when the preferred alternative is available to use
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
