Ticket Created
BOULDER-2042
Current and average cadence not updating for running activity
Hi,
A user of one of my DataFields raised this issue with me, I have subsequently observed the same thing on a different watch, different data field, different activity.
1. I have DataFields tracking all three of Activity.Info.currentCadence, Activity.Info.averageCadence and Activity.Info.maxCadence
2. On a number of occasions (not every time, but certainly quite frequently), averageCadence and maxCadence simply stop updating
3. I have checked in the .FIT file for one of the offending activities and the file appears to be closed correctly, but nonetheless closes after storing ridiculous averageCadence and maxCadence values of "1", despite recording currentCadence correctly.
This has been observed in Fenix Sapphire 6 and Forerunner 735xt - I haven't checked any other devices. It has also been observed on at least two different DataFields that I know of.
FYI, here is an example as observed in my Dialistic DataField over the course of an 18km run. (Red is heartrate, green is speed, blue is cadence. The small circles are "maxCadence", "maxSpeed" and "maxHeartrate" respectively, the coloured wedges in outer ring are "averageCadence", "averageSpeed" and "averageHeartrate". The dial hands are "currentCadence", "currentSpeed" and "currentHeartrate".) As you can see, although average and max update correctly for speed and heartrate, the cadence remains at a nonsense value.
G
Fenix 6 Sapphire showing wrong average and max for cadence
  • One things that's not clear in the doc is what cadence is.  There's step cadence (each step) and cycling (each rotation).
    Based on sports, you may have to do a bit more than just display the value.  Here's code from my hiking app.  Convert rotations into steps.  If this needs to be done can vary by sport.
    			if(actInfo.averageCadence!=null) {
    				lastAvgCadence=(actInfo.averageCadence*2).format("%d")+" spm";
    			if(actInfo.maxCadence!=null) {
    				lastMaxCadence=(actInfo.maxCadence*2).format("%d")+" spm";
