Ticket Created
BOULDER-2042
Current and average cadence not updating for running activity
Hi,
A user of one of my DataFields raised this issue with me, I have subsequently observed the same thing on a different watch, different data field, different activity.
1. I have DataFields tracking all three of Activity.Info.currentCadence, Activity.Info.averageCadence and Activity.Info.maxCadence
2. On a number of occasions (not every time, but certainly quite frequently), averageCadence and maxCadence simply stop updating
3. I have checked in the .FIT file for one of the offending activities and the file appears to be closed correctly, but nonetheless closes after storing ridiculous averageCadence and maxCadence values of "1", despite recording currentCadence correctly.
This has been observed in Fenix Sapphire 6 and Forerunner 735xt - I haven't checked any other devices. It has also been observed on at least two different DataFields that I know of.
FYI, here is an example as observed in my Dialistic DataField over the course of an 18km run. (Red is heartrate, green is speed, blue is cadence. The small circles are "maxCadence", "maxSpeed" and "maxHeartrate" respectively, the coloured wedges in outer ring are "averageCadence", "averageSpeed" and "averageHeartrate". The dial hands are "currentCadence", "currentSpeed" and "currentHeartrate".) As you can see, although average and max update correctly for speed and heartrate, the cadence remains at a nonsense value.
G
Fenix 6 Sapphire showing wrong average and max for cadence
  • Has there been any update on this?
    At least one firmware upgrade since reported and same thing happened today.
  • Hi Subra,
    No, that is not the issue!
    Current, average and max cadence are all provided effectively by Garmin FootPod, Garmin HR-Run strap, Garmin HR-Tri strap or a number of other cadence sensors. Mostly, they provide good data. Sometimes, as in now, they malfunction. There _is_ an upper limit, but pretty sure that the engineers at Garmin are a bit more advanced than allowing an integer wrapping error to reset anything > 256 to 0!
    The issue here is that the max and average values, that usually work well, are simply not being set in this instance for reasons unknown.
    (But, yes, you are right that the minimum cadence is always zero.)
    G
  • Measuring running cadence with the device may be very hard, because not only the body is motion, but also the device at the arm. Therefore the running cadence contains some kind of noises which should be filtered out to remove the incorrect values.
    I use HRM and my av. run cadence is usually 170-180 spm and my max run cadence is mostly measured 256 spm. I think this max limit is defined in the system and all wrongly cadences that are above this limit are ignored to prevent that the wrong values falsify the av. cadence and current cadence. I'm sure all of my cadences >190 spm are wrong.
    On the other hand if starting a run, min cadence is always 0 spm. So what is meant with min cadence?
    This may be the reason why current and average cadences seems to be not updated. The updates are above or below a threshold and are filtered out.
  • The other device is a Fenix 5X running software version 19.10.0.0
