Acknowledged
CIQQA-3881
Critical: WatchUi.getCurrentView Causing Invalid Value and Unhandled Exception Errors
My users have been experiencing crashes that appear to be related to calls to WatchUi.getCurrentView(). Specifically, Invalid Value and Unhandled Exception errors occur when accessing the array returned by this call, and Unexpected Type errors are raised when checking the result with instanceof.
After identifying this as a potential source of the issue, I introduced a wrapper function, getCurrentViewSafe(). In this function, I decomposed the call to WatchUi.getCurrentView() into multiple steps, validating each intermediate result and verifying types before accessing them. Despite these precautions, the app continues to crash at different points within this function.
The issue seems to be concentrated on newer devices. I have not encountered it myself on my Epix Pro Gen 2. Reported affected devices include Vivoactive 6, Fenix 8, Fenix 8 Pro, Venu 4, and Forerunner 970.
The complete source file is available here:
https://github.com/openhab/openhab-garmin/blob/Release-v1.1.3/source/user-interface/view-handling/ViewHandler.mc
An example of the relevant code is shown below, along with the corresponding errors as displayed in the ERA viewer:
52: var cwArray = WatchUi.getCurrentView() as Object;
53:
54: if( ! (cwArray instanceof Array ) ) {
55:     throw new GeneralException( "cwArray not an Array" );
56: }
57: if( cwArray.size() != 2 ) {
58:    throw new GeneralException( "cwArray.size = " + cwArray.size() );
59 }
60:
61: var view = cwArray[0];
Although I verify that the returned value is a valid array and perform the necessary type checks beforehand, accessing it in line 61 can still trigger the following error:
Error Name: Invalid Value
Occurrences: 1
First Occurrence: 2026-02-20
Last Occurrence: 2026-02-20
Devices:
    vívoactive® 6: 16.28
App Versions: v1.1.3
Languages: deu
Backtrace:
    ViewHandler.getCurrentViewSafe:61
    CustomBehaviorDelegate.onTap:38
Occurrences: 3
Last Occurrence: 2026-02-21
Devices:
    Venu® 4 45mm / D2Tm Air X15: 16.28
Languages: deu
Backtrace:
    ErrorView.isShowing:50
    SitemapRequestTasks.invoke:188
    AsyncTaskQueue.executeTasks:119
The code continues as follows:
62: if( view != null && ! ( view instanceof WatchUi.View ) ) {
63:     throw new GeneralException( "cwArray[0] not a View" );
64: }
65:
Line 62 also frequently fails with an Unexpected Type error:
Error Name: Unexpected Type Error
Occurrences: 1
Devices:
Languages: deu
Backtrace:
    ViewHandler.getCurrentViewSafe:62
    ExceptionHandler.handleException:111
    SitemapRequest.handleException:114
    SitemapRequest.onReceive:190
    SitemapRequest.makeRequest:145
    SitemapRequest.start:253
    OHApp.getInitialView:53
Occurrences: 41
First Occurrence: 2026-02-18
Last Occurrence: 2026-02-24
Devices:
    fēnix® 8 Pro 47mm / 51mm / MicroLED / quatix® 8 Pro 47mm / 51mm: 21.25
    fēnix® 8 47mm / 51mm / tactix® 8 47mm / 51mm / quatix® 8 47mm / 51mm: 21.25
Languages: deu, pol
Backtrace:
Occurrences: 2
First Occurrence: 2026-02-23
Devices:
Languages: deu
Backtrace:
Occurrences: 20
First Occurrence: 2026-02-03
Devices:
    Venu® X1: 16.28
    Forerunner® 970: 16.28
    Edge® 1040 / 1040 Solar: 30.15
Languages: deu, fre, pol
Backtrace:
    BasePageMenuInitializationTasks.invoke:89
Occurrences: 2
First Occurrence: 2026-02-24
Devices:
Languages: rus
Backtrace:
    ErrorView.<globals/ErrorView/<statics>/<>get>:40
    ErrorView.createOrUpdate:26
    OHApp.getInitialView:76
The code then proceeds to access the array:
66: var delegate = cwArray[1];
67: if( delegate != null &&
68:         ! ( delegate instanceof WatchUi.BehaviorDelegate
69:             || delegate instanceof WatchUi.InputDelegate
70:             || delegate instanceof WatchUi.ConfirmationDelegate
71:             || delegate instanceof WatchUi.MenuInputDelegate
72:             // || delegate instanceof WatchUi.NumberPickerDelegate
73:             || delegate instanceof WatchUi.PickerDelegate
74:             || delegate instanceof WatchUi.TextPickerDelegate
75:             || delegate instanceof WatchUi.WatchFaceDelegate
76:             || delegate instanceof WatchUi.Menu2InputDelegate
77:             || delegate instanceof WatchUi.ViewLoopDelegate )
78: ) {
79:     throw new GeneralException( "cwArray[1] not an input delegate" );
80: }
Again, numerous Invalid Value errors occur when accessing the array in line 66, along with Unexpected Type errors when using instanceof.
Occurrences: 1
Last Occurrence: 2026-02-18
Devices:
Languages: deu
Backtrace:
    ViewHandler.getCurrentViewSafe:66
Error Name: Unhandled Exception
Occurrences: 6
First Occurrence: 2026-02-16
Devices:
    Venu® X1: 16.28
Languages: deu, pol
Backtrace:
    AsyncTaskQueue.executeTasks:139
Occurrences: 1
First Occurrence: 2026-02-19
Last Occurrence: 2026-02-19
Devices:
Languages: deu
Backtrace:
Occurrences: 2
Devices:
Languages: deu
Backtrace:
    ViewHandler.getCurrentViewSafe:67
Occurrences: 2
Last Occurrence: 2026-02-23
Devices:
Languages: deu
Backtrace:
Occurrences: 5
Devices:
Backtrace:
The function then returns the array:
81:
82: return cwArray as [ WatchUi.View or Null, WatchUi.InputDelegates or Null ];
In some cases, this has also resulted in Unhandled Exception errors.
Occurrences: 5
Last Occurrence: 2026-02-22
Devices:
Languages: deu
Backtrace:
    ViewHandler.getCurrentViewSafe:82
  • I'm just looking at this again... trying to track if a ProgressBar is still the current view without using another tracking variable.
    When I look at (in the Sim debugger) the object type from getCurrentView() [0] I get an instanceof ProgressBar - indeed implying that the return is a ViewS and not View.
    But it makes the using the strict compiler unhappy.
  • Looks like the workaround with a custom view stack actually does the trick. First feedback from users says the issue isn’t happening anymore.
    To me, that confirms the problem is in WatchUi.getCurrentView itself, not in the view classes.
    github.com/.../ViewStack.mc
  • Also in my case, proper try/catch blocks are in place. Most calls occur well after onShow(). In fact, I also call it during initialization, when no view is present on the view stack, and it has never crashed in that situation. The crashes have only occurred in cases where there was definitely a view on the stack.
    As an initial workaround, I implemented my own view stack and retrieve the current view from there instead. I am now waiting for user feedback to determine whether this resolves the issue. Unfortunately, I do not have access to an affected device to test it myself.
  • Interesting thoughts. I checked in my case, it's in compute of a datafield. I use it when I need to call DataField.showAlert and I check if maybe it's already the top view (in that case I update it instead of showAlert)
    According to the log in the simulator the order of the calls is: onLayout, onShow, compute, onUpdate. So it looks like it should be OK, but maybe in the few occasions when this error happens it's really in the 1st compute? Though since even that is supposed to be after onShow, it should theoretically be OK.
    try/catch doesn't help, I already have it. Although I wouldn't know what is the caught exception, but I wouldn't see the Invalid Value in ERA.
    Delay: good idea. Unfortunately since this is a datafield, I have no timer, so I could only use the next compute cycle. Maybe I'll try, but I am a bit skeptical.....  Actually I already kind of have this in my code, 'cause this code can be reached only after 5 seconds, that is 5 compute calls.
    But maybe this can happen when the field is not visible (i.e it's on another page)?
  • The getCurrentView() crash with "invalid value" and unhandled exceptions is hitting a lot of us since the latest SDK/firmware combo. It seems to trigger mostly when called too early in the view lifecycle (like in initialize() or onShow() before the view is fully pushed) or when the view stack is in a weird state after a pop/push sequence.
    Quick things that helped some people dodge it:
    • Wrap the call in a try-catch and log the exception details.
    • Delay it slightly with a small timer (100-200 ms) after onShow().
    • Avoid calling it from background services or glance complications that might run when no view is active.
    If you're on a Fenix 8 or Epix Pro, test on simulator vs device too—sim sometimes masks the issue. Garmin usually fixes these in the next SDK drop, but posting your minimal repro code in the thread helps them prioritize. Hope it gets patched soon.
