Acknowledged
Crash with Simulator View Memory, SDK 4.0.6 on a MAC
Under Connect IQ 4.0.6 whenever I double-click the memory stats at the bottom of the simulator window or from the File menu, the simulator crashes producing an Apple problem report, as per below.  This does not occur with Connect IQ 4.0.5.
My environment is:
macOS v11.6 (macbook pro 2019)
VSCode v1.61.1
Connect IQ SDK 4.0.6
MonkeyC VSC Plugin 1.0.0
Java 1.8.0_271
Process: simulator [40681]
Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Identifier: com.garmin.connectiq.simulator
Version: 4.0.6 (4.0.6)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: simulator [40681]
User ID: 501
Date/Time: 2021-10-21 08:27:25.684 +1100
OS Version: macOS 11.6 (20G165)
Report Version: 12
Bridge OS Version: 5.5 (18P4759a)
Anonymous UUID: 361F5393-54D3-A759-0693-C98CA2F466EB
Sleep/Wake UUID: D63B8399-E05E-451D-82C1-D41DF94254CE
Time Awake Since Boot: 160000 seconds
Time Since Wake: 1600 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [40681]
VM Regions Near 0:
__TEXT 102be8000-103a74000 [ 14.5M] r-x/r-x SM=COW /Users/*/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Application Specific Information:
Performing @selector(clickedAction:) from sender wxNSMenuItem 0x6000033bea70
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.garmin.connectiq.simulator 0x00000001034f4b1b 0x102be8000 + 9489179
1 com.garmin.connectiq.simulator 0x000000010365ac89 0x102be8000 + 10955913
2 com.garmin.connectiq.simulator 0x000000010365ae7a 0x102be8000 + 10956410
3 com.garmin.connectiq.simulator 0x0000000102cade3e 0x102be8000 + 810558
4 com.garmin.connectiq.simulator 0x0000000102cad645 0x102be8000 + 808517
5 com.garmin.connectiq.simulator 0x000000010348218f 0x102be8000 + 9019791
6 com.garmin.connectiq.simulator 0x0000000103483662 0x102be8000 + 9025122
7 com.garmin.connectiq.simulator 0x00000001034837a1 0x102be8000 + 9025441
8 com.garmin.connectiq.simulator 0x0000000103483600 0x102be8000 + 9025024
9 com.garmin.connectiq.simulator 0x000000010368429c 0x102be8000 + 11125404
10 com.garmin.connectiq.simulator 0x0000000103483d1c 0x102be8000 + 9026844
11 com.garmin.connectiq.simulator 0x000000010363fdad 0x102be8000 + 10845613
12 com.garmin.connectiq.simulator 0x000000010363fc74 0x102be8000 + 10845300
13 com.garmin.connectiq.simulator 0x0000000103513ce9 0x102be8000 + 9616617
14 com.apple.AppKit 0x00007fff22f832bb -[NSApplication(NSResponder) sendAction:to:from:] + 288
15 com.apple.AppKit 0x00007fff23085cc9 -[NSMenuItem _corePerformAction] + 413
16 com.apple.AppKit 0x00007fff230859e8 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 95
17 com.apple.AppKit 0x00007fff230d2038 -[NSMenu performActionForItemAtIndex:] + 113
18 com.apple.AppKit 0x00007fff230d1fbe -[NSMenu _internalPerformActionForItemAtIndex:] + 82
19 com.apple.AppKit 0x00007fff230d1e05 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 101
20 com.apple.AppKit 0x00007fff230685d1 NSSLMMenuEventHandler + 1078
21 com.apple.HIToolbox 0x00007fff28779da1 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1362
22 com.apple.HIToolbox 0x00007fff287791c3 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 331
23 com.apple.HIToolbox 0x00007fff2878ea82 SendEventToEventTarget + 39
24 com.apple.HIToolbox 0x00007fff287ee747 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 368
25 com.apple.HIToolbox 0x00007fff28814291 SendMenuCommandWithContextAndModifiers + 45
26 com.apple.HIToolbox 0x00007fff2881423c SendMenuItemSelectedEvent + 348
27 com.apple.HIToolbox 0x00007fff2881408b FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
28 com.apple.HIToolbox 0x00007fff28814a92 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 613
29 com.apple.HIToolbox 0x00007fff2881479a _HandleMenuSelection2 + 462
30 com.apple.AppKit 0x00007fff22f1af6d _NSHandleCarbonMenuEvent + 215
31 com.apple.AppKit 0x00007fff22f1adda _DPSEventHandledByCarbon + 54
32 com.apple.AppKit 0x00007fff22d60ff7 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3078
33 com.apple.AppKit 0x00007fff22d52c69 -[NSApplication run] + 586
34 com.garmin.connectiq.simulator 0x000000010356d15a 0x102be8000 + 9982298
35 com.garmin.connectiq.simulator 0x000000010345e2ad 0x102be8000 + 8872621
36 com.garmin.connectiq.simulator 0x00000001033cc04e 0x102be8000 + 8273998
37 com.garmin.connectiq.simulator 0x000000010339e183 0x102be8000 + 8085891
38 com.garmin.connectiq.simulator 0x000000010352b0fa 0x102be8000 + 9711866
39 com.garmin.connectiq.simulator 0x0000000103402c78 0x102be8000 + 8498296
40 com.garmin.connectiq.simulator 0x0000000102c24b78 0x102be8000 + 248696
41 libdyld.dylib 0x00007fff2047ef3d start + 1
Thread 1:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff2042e2ba mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff2042e62c mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff2055b49f __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff20559b7f __CFRunLoopRun + 1328
4 com.apple.CoreFoundation 0x00007fff20558f8c CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22ee823a _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff204638fc _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff2045f443 thread_start + 15
Thread 2:: TSK bkgd
0 libsystem_kernel.dylib 0x00007fff20430cde __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff20463e49 _pthread_cond_wait + 1298
2 com.garmin.connectiq.simulator 0x000000010327aee9 0x102be8000 + 6893289
3 com.garmin.connectiq.simulator 0x0000000103279f8e 0x102be8000 + 6889358
4 libsystem_pthread.dylib 0x00007fff204638fc _pthread_start + 224
5 libsystem_pthread.dylib 0x00007fff2045f443 thread_start + 15
Thread 3:: NFM_Region_0
3 com.garmin.connectiq.simulator 0x00000001032ea093 0x102be8000 + 7348371
4 com.garmin.connectiq.simulator 0x0000000103279fbf 0x102be8000 + 6889407
5 libsystem_pthread.dylib 0x00007fff204638fc _pthread_start + 224
6 libsystem_pthread.dylib 0x00007fff2045f443 thread_start + 15
Thread 4:: IOPAppMain
3 com.garmin.connectiq.simulator 0x0000000103080a85 0x102be8000 + 4819589
4 com.garmin.connectiq.simulator 0x0000000103279fac 0x102be8000 + 6889388
Thread 5:: ant_main
1 libsystem_pthread.dylib 0x00007fff20463e7f _pthread_cond_wait + 1352
2 com.garmin.connectiq.simulator 0x0000000103279a40 0x102be8000 + 6888000
3 com.garmin.connectiq.simulator 0x000000010327aee9 0x102be8000 + 6893289
4 com.garmin.connectiq.simulator 0x000000010305ad05 0x102be8000 + 4664581
5 com.garmin.connectiq.simulator 0x0000000103279fac 0x102be8000 + 6889388
Thread 6:: GPS main
Thread 7:: SNS main
Thread 8:: fit activity
3 com.garmin.connectiq.simulator 0x00000001030bc3df 0x102be8000 + 5063647
Thread 9:: ftm main
4 com.garmin.connectiq.simulator 0x00000001030ca6ef 0x102be8000 + 5121775
Thread 10:: TVM main
3 com.garmin.connectiq.simulator 0x000000010322f485 0x102be8000 + 6583429
Thread 11:: TVM defrag
Thread 12:: parse main
3 com.garmin.connectiq.simulator 0x0000000102c0953b 0x102be8000 + 136507
Thread 13:: GPX archive trk
3 com.garmin.connectiq.simulator 0x00000001032fa8b5 0x102be8000 + 7415989
Thread 14:: mma sql bkg
Thread 15:: TLG main
4 com.garmin.connectiq.simulator 0x00000001032fa6da 0x102be8000 + 7415514
5 com.garmin.connectiq.simulator 0x0000000103279fbf 0x102be8000 + 6889407
Thread 16:: libcurl Async H
3 com.garmin.connectiq.simulator 0x000000010309b92a 0x102be8000 + 4929834
Thread 17:: Download Manage
3 com.garmin.connectiq.simulator 0x000000010309dd15 0x102be8000 + 4939029
Thread 18:: Shell main
0 libsystem_kernel.dylib 0x00007fff204349b2 __accept + 10
1 com.garmin.connectiq.simulator 0x00000001032f5b72 0x102be8000 + 7396210
2 com.garmin.connectiq.simulator 0x00000001032f2717 0x102be8000 + 7382807
3 com.garmin.connectiq.simulator 0x0000000103279fac 0x102be8000 + 6889388
Thread 19:
1 com.garmin.connectiq.simulator 0x0000000102cd68dc 0x102be8000 + 977116
2 com.garmin.connectiq.simulator 0x0000000102cbf8ad 0x102be8000 + 882861
3 com.garmin.connectiq.simulator 0x00000001034711fc 0x102be8000 + 8950268
4 com.garmin.connectiq.simulator 0x0000000103470c18 0x102be8000 + 8948760
Thread 20:: Shell handler
2 com.garmin.connectiq.simulator 0x0000000103279873 0x102be8000 + 6887539
3 com.garmin.connectiq.simulator 0x0000000102cd64b4 0x102be8000 + 976052
4 com.garmin.connectiq.simulator 0x00000001032f58da 0x102be8000 + 7395546
5 com.garmin.connectiq.simulator 0x00000001032f4daf 0x102be8000 + 7392687
6 com.garmin.connectiq.simulator 0x00000001032f3183 0x102be8000 + 7385475
7 com.garmin.connectiq.simulator 0x0000000103279fac 0x102be8000 + 6889388
8 libsystem_pthread.dylib 0x00007fff204638fc _pthread_start + 224
9 libsystem_pthread.dylib 0x00007fff2045f443 thread_start + 15
Thread 21:
0 libsystem_kernel.dylib 0x00007fff204317fa __recvfrom + 10
1 com.garmin.connectiq.simulator 0x00000001032f5fd1 0x102be8000 + 7397329
2 com.garmin.connectiq.simulator 0x00000001032f4e52 0x102be8000 + 7392850
3 com.garmin.connectiq.simulator 0x0000000102cd3baf 0x102be8000 + 965551
4 com.garmin.connectiq.simulator 0x0000000102cd766f 0x102be8000 + 980591
5 com.garmin.connectiq.simulator 0x00000001034711fc 0x102be8000 + 8950268
6 com.garmin.connectiq.simulator 0x0000000103470c18 0x102be8000 + 8948760
7 libsystem_pthread.dylib 0x00007fff204638fc _pthread_start + 224
8 libsystem_pthread.dylib 0x00007fff2045f443 thread_start + 15
Thread 22:
2 com.garmin.connectiq.simulator 0x000000010346e936 0x102be8000 + 8939830
3 com.garmin.connectiq.simulator 0x0000000102ce22a6 0x102be8000 + 1024678
4 com.garmin.connectiq.simulator 0x0000000102ce1e40 0x102be8000 + 1023552
5 com.garmin.connectiq.simulator 0x0000000102cd766f 0x102be8000 + 980591
6 com.garmin.connectiq.simulator 0x00000001034711fc 0x102be8000 + 8950268
7 com.garmin.connectiq.simulator 0x0000000103470c18 0x102be8000 + 8948760
Thread 23:
0 libsystem_pthread.dylib 0x00007fff2045f420 start_wqthread + 0
Thread 24:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fa1ecc2c1c0 rcx: 0x0000000000000000 rdx: 0x00007ffeed015d5c
rdi: 0x0000000000000000 rsi: 0x00007ffeed015d58 rbp: 0x00007ffeed015d40 rsp: 0x00007ffeed015d10
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x00000000000007fb r11: 0x00000000000000aa
r12: 0x0000600002ac2640 r13: 0x00007fa1ecc2c1c0 r14: 0x00007ffeed015d5c r15: 0x00007ffeed015d58
rip: 0x00000001034f4b1b rfl: 0x0000000000010213 cr2: 0x0000000000000000
Logical CPU: 10
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
ff 90 00 06 00 00 41 29-07 48 8b 7b 58 48 8b 07 ......A).H.{XH..
ff 90 10 06 00 00 41 29-06 b0 01 48 83 c4 08 5b ......A)...H...[
41 5c 41 5d 41 5e 41 5f-5d c3 66 2e 0f 1f 84 00 A\A]A^A_].f.....
00 00 00 00 90 55 48 89-e5 41 57 41 56 41 55 41 .....UH..AWAVAUA
54 53 50 48 89 fb 48 8b-87 d0 02 00 00 31 ff 48 TSPH..H......1.H
3b 05 37 85 67 00 49 89-d6 49 89 f7 48 0f 45 f8 ;.7.g.I..I..H.E.
[48]8b 07 48 8d 75 d0 48-8d 55 d4 ff 90 98 00 00 H..H.u.H.U...... <==
00 4d 85 ff 74 28 44 8b-6d d0 48 8b 03 48 89 df .M..t(D.m.H..H..
ff 90 00 06 00 00 49 89-c4 45 01 ec 48 8b 03 48 ......I..E..H..H
89 df ff 90 08 06 00 00-44 01 e0 41 89 07 4d 85 ........D..A..M.
f6 74 28 44 8b 65 d4 48-8b 03 48 89 df ff 90 10 .t(D.e.H..H.....
06 00 00 49 89 c7 45 01-e7 48 8b 03 48 89 df ff ...I..E..H..H...
Thread 0 last branch register state not available.
Binary Images:
0x102be8000 - 0x103a73fff +com.garmin.connectiq.simulator (4.0.6 - 4.0.6) <850AB564-845D-3A20-B086-499C58F3BADC> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
0x106d50000 - 0x106d5ffff libobjc-trampolines.dylib (824) <C1B6BD90-D6AA-388B-B692-D66D512630AA> /usr/lib/libobjc-trampolines.dylib
0x106fb6000 - 0x107051fff dyld (852.2) <0CC19410-FD43-39AE-A32A-50273F8303A4> /usr/lib/dyld
0x7fff2019b000 - 0x7fff2019cfff libsystem_blocks.dylib (79) <925E3B6D-184D-3E73-97B1-643C4ADB387A> /usr/lib/system/libsystem_blocks.dylib
0x7fff2019d000 - 0x7fff201d2fff libxpc.dylib (2038.120.1) <FFFB49D7-2CA6-3E1F-AE4E-5697B19B7D76> /usr/lib/system/libxpc.dylib
0x7fff201d3000 - 0x7fff201eafff libsystem_trace.dylib (1277.120.1) <7E800ECA-DFDB-3737-A3C5-FFDE37E65383> /usr/lib/system/libsystem_trace.dylib
0x7fff201eb000 - 0x7fff20288fff libcorecrypto.dylib (1000.140.4) <D211160D-E22F-3440-8054-1F5824519C7F> /usr/lib/system/libcorecrypto.dylib
0x7fff20289000 - 0x7fff202b5fff libsystem_malloc.dylib (317.140.5) <050E37E1-1458-3F80-BFA3-F1488570169D> /usr/lib/system/libsystem_malloc.dylib
0x7fff202b6000 - 0x7fff202fafff libdispatch.dylib (1271.120.2) <8144B0BD-90D2-3EAE-999F-AB0D14082088> /usr/lib/system/libdispatch.dylib
0x7fff202fb000 - 0x7fff20334fff libobjc.A.dylib (824) <8C7C49A1-4211-3E4C-BA3D-160D675EEE96> /usr/lib/libobjc.A.dylib
0x7fff20335000 - 0x7fff20337fff libsystem_featureflags.dylib (28.60.1) <E5C43AE3-19E7-3DAB-8B5D-D79A4B68B5C0> /usr/lib/system/libsystem_featureflags.dylib
0x7fff20338000 - 0x7fff203c0fff libsystem_c.dylib (1439.141.1) <3C273899-4CBE-32D5-BB31-7A449743204F> /usr/lib/system/libsystem_c.dylib
0x7fff203c1000 - 0x7fff20416fff libc++.1.dylib (905.6) <FD6DB1CB-B14B-3404-8BEB-B459C2F6C303> /usr/lib/libc++.1.dylib
0x7fff20417000 - 0x7fff2042cfff libc++abi.dylib (905.6) <D0CDDF98-1C04-300F-B685-4A4C59C04C42> /usr/lib/libc++abi.dylib
0x7fff2042d000 - 0x7fff2045cfff libsystem_kernel.dylib (7195.141.6) <78289AAE-61B5-339F-A485-8819BC2388F2> /usr/lib/system/libsystem_kernel.dylib
0x7fff2045d000 - 0x7fff20468fff libsystem_pthread.dylib (454.120.2) <1268FF2D-A513-3B51-BA65-AF2FF5789DDB> /usr/lib/system/libsystem_pthread.dylib
0x7fff20469000 - 0x7fff204a4fff libdyld.dylib (852.2) <3DE0178A-0AEE-3D08-AE19-6C6403F69BA1> /usr/lib/system/libdyld.dylib
0x7fff204a5000 - 0x7fff204aefff libsystem_platform.dylib (254.80.2) <EF52D569-09F5-32E1-B1B3-34E2CA55A017> /usr/lib/system/libsystem_platform.dylib
0x7fff204af000 - 0x7fff204dafff libsystem_info.dylib (542.40.3) <55B39B7F-957B-3D99-A8DF-7CA80D38155D> /usr/lib/system/libsystem_info.dylib
0x7fff204db000 - 0x7fff20978fff com.apple.CoreFoundation (6.9 - 1778.101) <8CF9D741-ADFF-3D5E-ACDE-DC342701EE0D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff20979000 - 0x7fff20baefff com.apple.LaunchServices (1122.44 - 1122.44) <C285E620-3D2F-3AD0-8A3D-BB1FC540FE44> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff20baf000 - 0x7fff20c83fff com.apple.gpusw.MetalTools (1.0 - 1) <C41024C5-01E7-3A66-A1F8-D7BC767260D8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff20c84000 - 0x7fff20ee0fff libBLAS.dylib (1336.140.1) <170AFA22-1234-3DE9-9D94-52B3BE18E34E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff20ee1000 - 0x7fff20f2efff com.apple.Lexicon-framework (1.0 - 86.2) <B7047A55-806D-3B32-A2D6-885D824E54A6> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff20f2f000 - 0x7fff20f9dfff libSparse.dylib (106) <1E68BF64-7432-3509-BC85-5DE95379E901> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff20f9e000 - 0x7fff2101bfff com.apple.SystemConfiguration (1.20 - 1.20) <8FEB39D4-ACD6-39F2-8D1B-A57CACD5628F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff2101c000 - 0x7fff21050fff libCRFSuite.dylib (50) <BCDD0ED1-D2F4-3556-B218-4420C7EA47D2> /usr/lib/libCRFSuite.dylib
0x7fff21051000 - 0x7fff21289fff libmecabra.dylib (929.10) <D780814D-2BB2-3D84-820E-12E4C23C590E> /usr/lib/libmecabra.dylib
0x7fff2128a000 - 0x7fff215e8fff com.apple.Foundation (6.9 - 1778.101) <7B7FB88B-01D3-38CE-8029-837DB094C545> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff215e9000 - 0x7fff216d1fff com.apple.LanguageModeling (1.0 - 247.3) <DBFAE8CF-36B2-30D8-9E82-6C412CD935B4> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff216d2000 - 0x7fff21808fff com.apple.CoreDisplay (237.4 - 237.4) <556BADE0-D3B0-309C-9740-7FEFBD052B6B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff21809000 - 0x7fff21a79fff com.apple.audio.AudioToolboxCore (1.0 - 1181.72) <5C3B84EE-B281-34C4-832F-78F00CC63B93> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff21a7a000 - 0x7fff21c5ffff com.apple.CoreText (677.6.0.2 - 677.6.0.2) <10E1382E-7949-3F4E-8B15-A4BD31A75E91> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff21c60000 - 0x7fff222f1fff com.apple.audio.CoreAudio (5.0 - 5.0) <5EEA9225-4837-37F3-9105-941A5743169F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff222f2000 - 0x7fff22649fff com.apple.security (7.0 - 59754.140.13) <A196C85A-DB28-3F5B-A415-5BE44AD81668> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff2264a000 - 0x7fff228a9fff libicucore.A.dylib (66112) <AC994BC1-F9CC-359C-A7B5-F2821EAEF650> /usr/lib/libicucore.A.dylib
0x7fff228aa000 - 0x7fff228b3fff libsystem_darwin.dylib (1439.141.1) <2C81A009-45BB-30D7-A4F7-4B2EEC691617> /usr/lib/system/libsystem_darwin.dylib
0x7fff228b4000 - 0x7fff22b9ffff com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <2C65E0D8-A9C7-31D8-A3D3-3AC1A91C80A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff22ba0000 - 0x7fff22bdefff com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <3FC6073F-78E4-3D3B-8765-50E50512C5EB> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff22bdf000 - 0x7fff22c19fff com.apple.CSStore (1122.44 - 1122.44) <C103DAAA-A966-359B-97F0-BA3BB56ECBF1> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff22c1a000 - 0x7fff22cc8fff com.apple.framework.IOKit (2.0.2 - 1845.120.6) <720D9AE1-79D6-3E77-8D7A-47F8F6681050> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff22cc9000 - 0x7fff22cd4fff libsystem_notify.dylib (279.40.4) <2E40EA4A-B124-3010-8379-1B4D7082A08F> /usr/lib/system/libsystem_notify.dylib
0x7fff22cd5000 - 0x7fff22d22fff libsandbox.1.dylib (1441.141.4) <C291C059-F7E4-3C20-BCBF-60F7011F0718> /usr/lib/libsandbox.1.dylib
0x7fff22d23000 - 0x7fff23a6efff com.apple.AppKit (6.9 - 2022.60.128) <02EC69A0-D634-341B-BE3D-840F496F5814> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff23a6f000 - 0x7fff23cbdfff com.apple.UIFoundation (1.0 - 728.9) <C2E04F0F-AEAA-3B77-9BBA-1CF628341A56> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff23cbe000 - 0x7fff23cd0fff com.apple.UniformTypeIdentifiers (637 - 637) <8FFD3B69-0840-34D6-83AD-7D521B1A2339> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
0x7fff23cd1000 - 0x7fff23e5bfff com.apple.desktopservices (1.21 - 1346.6.1) <F2C97567-5B56-3840-A384-2131E362083B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff2413b000 - 0x7fff247c1fff libnetwork.dylib (2288.140.7) <42825FCA-35A1-352F-AE68-19D8F695604B> /usr/lib/libnetwork.dylib
0x7fff247c2000 - 0x7fff24c60fff com.apple.CFNetwork (1240.0.4 - 1240.0.4) <E4BF9BFF-798B-33FF-B37D-6D8175CA708A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff24c61000 - 0x7fff24c6ffff libsystem_networkextension.dylib (1295.140.3) <83AA4425-2F1D-36EC-B77B-8D4F03CDDB68> /usr/lib/system/libsystem_networkextension.dylib
0x7fff24c70000 - 0x7fff24c70fff libenergytrace.dylib (22.100.1) <9E877E0A-5261-3F75-91A0-521423499AD0> /usr/lib/libenergytrace.dylib
0x7fff24c71000 - 0x7fff24ccdfff libMobileGestalt.dylib (978.140.1) <D1FF79C3-4B2F-32FB-BF25-9F0B9E160692> /usr/lib/libMobileGestalt.dylib
0x7fff24cce000 - 0x7fff24ce4fff libsystem_asl.dylib (385) <8D324D65-EE16-3A1A-BD39-ACB1B3050D1F> /usr/lib/system/libsystem_asl.dylib
0x7fff24ce5000 - 0x7fff24cfdfff com.apple.TCC (1.0 - 1) <18F48712-FFF0-3B30-B2C4-8A93AEF86A34> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff24cfe000 - 0x7fff25063fff com.apple.SkyLight (1.600.0 - 588.7) <5F88F814-A3DF-3446-8B35-F0CDD8C1B302> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff25064000 - 0x7fff256edfff com.apple.CoreGraphics (2.0 - 1463.17.3) <5EDF86BC-FFDE-3906-9674-142C113B34EF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff256ee000 - 0x7fff257e4fff com.apple.ColorSync (4.13.0 - 3473.4.3) <102C423C-E05F-317B-83AE-A2A6B77D653B> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff257e5000 - 0x7fff25840fff com.apple.HIServices (1.22 - 716) <B2D34F3F-0CEB-35F1-9B32-E0806CF3FC91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff25841000 - 0x7fff2587ffff libAWDSupport.dylib (951) <F10D0972-6D3C-325B-A977-48E0EC6B087D> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x7fff25880000 - 0x7fff258dcfff libprotobuf.dylib (4205) <25B06010-4F03-3B97-873E-94410285D572> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff258dd000 - 0x7fff258eefff libprotobuf-lite.dylib (4205) <035E309C-861F-393B-BB10-D8C42F63E6F6> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff258ef000 - 0x7fff25933fff com.apple.awd (1.0 - 951) <950DBA92-CC7B-3355-BAEE-083FFFBDF500> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff25be7000 - 0x7fff26006fff com.apple.CoreData (120 - 1048) <33DE1B26-D4C6-3939-B12E-88897660BB38> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff26007000 - 0x7fff2601cfff com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <AEDEFF64-CA8A-365C-900F-3107383F91D9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff2601d000 - 0x7fff261d0fff libsqlite3.dylib (321.3) <E7377C46-DA4F-3486-B935-0A35C3637215> /usr/lib/libsqlite3.dylib
0x7fff261d1000 - 0x7fff2624dfff com.apple.Accounts (113 - 113) <2AD45648-B327-313A-ACF2-846FB345A96E> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff2624e000 - 0x7fff26265fff com.apple.commonutilities (8.0 - 900) <98B456F4-8F4F-387B-B3BB-D3919295AE1D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff26266000 - 0x7fff262e5fff com.apple.BaseBoard (526 - 526) <F9D85C3A-D0D6-351B-A6EE-5416CB90179D> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff262e6000 - 0x7fff2632efff com.apple.RunningBoardServices (1.0 - 505.100.9) <2ED406CD-2253-33F0-B16A-694DB447CADC> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff2632f000 - 0x7fff263a3fff com.apple.AE (918.6 - 918.6) <C5130BB4-18E7-3804-A9D9-915D318426A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff263a4000 - 0x7fff263aafff libdns_services.dylib (1310.140.1) <22BE5030-2F48-3ED6-9DF8-9D102CEF33FF> /usr/lib/libdns_services.dylib
0x7fff263ab000 - 0x7fff263b2fff libsystem_symptoms.dylib (1431.140.1) <1B4D8837-C951-3B69-B079-85D477749E8B> /usr/lib/system/libsystem_symptoms.dylib
0x7fff263b3000 - 0x7fff2653efff com.apple.Network (1.0 - 1) <2155E1AA-2067-36CF-979E-2F96062D5CFE> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff2653f000 - 0x7fff2656efff com.apple.analyticsd (1.0 - 1) <0DF60ECD-742C-39D1-964A-48EC3DEA6319> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff2656f000 - 0x7fff26571fff libDiagnosticMessagesClient.dylib (112) <A7EC7265-E13C-3C98-81EE-3EFB5CC65AB0> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff26572000 - 0x7fff265befff com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <F709AE5E-AF80-3C9B-A3D3-B779164FBA95> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff265bf000 - 0x7fff26659fff com.apple.Metadata (10.7.0 - 2150.26) <D7CE41CA-DDE7-32BE-926C-0DC3048C5E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2665a000 - 0x7fff26660fff com.apple.DiskArbitration (2.7 - 2.7) <8DF059B4-BE32-3171-8CC4-C5FA189FA718> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff26661000 - 0x7fff26cc8fff com.apple.vImage (8.1 - 544.4) <E62F9E4F-9A1D-3004-B7F4-6F83F71144C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff26cc9000 - 0x7fff26fa6fff com.apple.QuartzCore (1.11 - 927.24) <88794856-F1F1-3D23-BDDB-0AE28A1D6D6E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff26fa7000 - 0x7fff26fe8fff libFontRegistry.dylib (309) <300F2208-7274-38F8-B88D-9237BA6B397E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff26fe9000 - 0x7fff27129fff com.apple.coreui (2.1 - 692.1) <BC5D8EAA-7CE8-35F3-8EAD-075B18D9606C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff2712a000 - 0x7fff27215fff com.apple.ViewBridge (553.1 - 553.1) <DF83EA6E-4DA9-3322-BE86-0B3207167451> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff27216000 - 0x7fff27221fff com.apple.PerformanceAnalysis (1.278.3 - 278.3) <6AF20F05-FF15-3174-A504-1AC16BA14729> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff27222000 - 0x7fff27231fff com.apple.OpenDirectory (11.6 - 230.40.1) <84B2D11F-E6C4-3C29-9A9A-939DB906E2F5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff27232000 - 0x7fff27251fff com.apple.CFOpenDirectory (11.6 - 230.40.1) <6BE3204F-2F86-34A7-AD79-4C88320F446F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff27252000 - 0x7fff2725efff com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <DC473A17-310F-3C16-B545-F75CE3F6D39D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2725f000 - 0x7fff27283fff com.apple.coreservices.SharedFileList (144 - 144) <A13B58B8-6D7A-3F1B-AFB5-E41E0A6B4B81> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff27284000 - 0x7fff27286fff libapp_launch_measurement.dylib (14.1) <511EC2A9-6059-3A7D-9D2A-741189922D02> /usr/lib/libapp_launch_measurement.dylib
0x7fff27287000 - 0x7fff272cefff com.apple.CoreAutoLayout (1.0 - 21.10.1) <18113C8E-B54E-3DD3-A1AD-2A5FD949CE66> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
0x7fff272cf000 - 0x7fff273b1fff libxml2.2.dylib (34.10) <DD2093F0-F9B7-3F30-B46D-B028CE15E2B1> /usr/lib/libxml2.2.dylib
0x7fff273b2000 - 0x7fff273fffff com.apple.CoreVideo (1.8 - 414.7) <EE991A40-DE38-3B13-891E-A51987D5CD70> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff27400000 - 0x7fff27402fff com.apple.loginsupport (1.0 - 1) <4C358D8E-4BB8-3DD8-8A72-11BD80607BDE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff27403000 - 0x7fff2742afff com.apple.aps.framework (4.0 - 4.0) <A76C4B82-24CD-3AF4-BADD-6135F6E7057A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff2742b000 - 0x7fff27446fff com.apple.UserManagement (1.0 - 1) <FB298359-31F5-3DDD-B928-604C4B1ED1F3> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff27447000 - 0x7fff275d8fff com.apple.cloudkit.CloudKit (990 - 990) <A4ADF4E3-AC2D-322B-B76C-BC249AB27395> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff279eb000 - 0x7fff2833cfff libwebrtc.dylib (7611.3.10.1.6) <CBCA9241-7714-378B-97C6-5D404C6284A7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff2833d000 - 0x7fff283b9fff com.apple.corelocation (2420.19.23 - 2420.19.23) <1BEB1A0D-4122-3F8C-AC1A-07A12C36C84F> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff283ba000 - 0x7fff283cafff libsystem_containermanager.dylib (318.100.4) <1139CD47-9CBA-356F-8694-1D00EB9F0C8F> /usr/lib/system/libsystem_containermanager.dylib
0x7fff283cb000 - 0x7fff283dcfff com.apple.IOSurface (290.8.1 - 290.8.1) <8B251196-DA38-38BF-8A91-45AC2B06014C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff283dd000 - 0x7fff283e6fff com.apple.IOAccelerator (442.9 - 442.9) <F2C3DC87-49D7-3A67-8E6D-12D75D98EFDD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff283e7000 - 0x7fff2850afff com.apple.Metal (244.303 - 244.303) <71B6039E-232E-3AD2-881F-DF8E73C75B99> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff2850b000 - 0x7fff28527fff com.apple.audio.caulk (1.0 - 70) <F6A09FF3-1DC7-302C-86E3-B2DD9B7130A9> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff28528000 - 0x7fff28612fff com.apple.CoreMedia (1.0 - 2780.10) <6A003180-F8AA-3DFA-B095-61D8E859FE3F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff28613000 - 0x7fff2876ffff libFontParser.dylib (305.6.0.4) <C3E552F6-72AD-3F3A-B217-E44A5C565240> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff28770000 - 0x7fff28a6bfff com.apple.HIToolbox (2.1.1 - 1062) <DEF01A0C-8B9D-359E-9FE7-B15D551888DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff28a6c000 - 0x7fff28a7ffff com.apple.framework.DFRFoundation (1.0 - 267) <EBFDDB28-7661-3B50-BC15-736C5DF05AB3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff28a80000 - 0x7fff28a83fff com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DD9E09C3-B658-3BD2-8229-E3E3C5D85552> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff28a84000 - 0x7fff28aadfff com.apple.CoreSVG (1.0 - 149) <C4DC952A-9373-33E5-8A98-F008986B0420> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff28aae000 - 0x7fff28ceafff com.apple.ImageIO (3.3.0 - 2130.7.3) <28C6A501-2548-3187-A13B-9F314280BBB8> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff28ceb000 - 0x7fff29066fff com.apple.CoreImage (16.3.0 - 1140.2) <3ED3F244-632C-383D-89B0-50F2E0FDBA40> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff29067000 - 0x7fff290cdfff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <C12F8828-6D1E-3820-BBF7-80EEA978AE9C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff290ce000 - 0x7fff290d1fff libsystem_configuration.dylib (1109.140.1) <02F3A5C9-6289-3012-8F5F-F1DB669ADB79> /usr/lib/system/libsystem_configuration.dylib
0x7fff290d2000 - 0x7fff290d6fff libsystem_sandbox.dylib (1441.141.4) <5471601B-5072-3E97-8926-804FF08DC4C0> /usr/lib/system/libsystem_sandbox.dylib
0x7fff290d7000 - 0x7fff290d8fff com.apple.AggregateDictionary (1.0 - 1) <B25A1764-0BBC-388B-8FB4-A8FBB8F51C10> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff290d9000 - 0x7fff290dcfff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4A803F86-CA61-3508-864A-302F032ADA70> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff290dd000 - 0x7fff290defff liblangid.dylib (136) <F4019132-A63D-3A38-A8DB-974C6F1311ED> /usr/lib/liblangid.dylib
0x7fff290df000 - 0x7fff29183fff com.apple.CoreNLP (1.0 - 245.2) <203C6AB9-5B07-3370-A056-DA1F2C8A8419> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff29184000 - 0x7fff2918afff com.apple.LinguisticData (1.0 - 399) <AB85B59F-3047-37EC-AB9E-835D87BACF73> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff2918b000 - 0x7fff29833fff libBNNS.dylib (288.100.5) <4BB7A1B7-D1F2-3DC3-BFC7-D57CBD892719> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff29834000 - 0x7fff29a06fff libvDSP.dylib (760.100.3) <DA809F3E-9391-3BE0-98C6-061CCACA809A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff29a07000 - 0x7fff29a18fff com.apple.CoreEmoji (1.0 - 128.4) <8DB42230-A624-3C13-80F8-EC2CE89C0699> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff29a19000 - 0x7fff29a23fff com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <195E20E7-33BD-3935-92ED-AA354180B7FA> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
0x7fff29a24000 - 0x7fff29af6fff com.apple.framework.CoreWLAN (16.0 - 1657) <0A58C97E-2ACD-3223-8585-FDA5DA4C38C5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff29af7000 - 0x7fff29cf8fff com.apple.CoreUtils (6.6 - 660.37) <0B1ED18A-B228-3840-A0F2-23AC2C37A6CA> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff29cf9000 - 0x7fff29d1bfff com.apple.MobileKeyBag (2.0 - 1.0) <19D8140C-CC92-35E8-AF78-B335567A7C24> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff29d1c000 - 0x7fff29d2cfff com.apple.AssertionServices (1.0 - 505.100.9) <850AE031-A3B3-30C0-81A1-71FBCE620BC1> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff29d2d000 - 0x7fff29db8fff com.apple.securityfoundation (6.0 - 55240.40.4) <A7D05091-B54C-317A-81FE-4B174C968C5A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff29db9000 - 0x7fff29dc2fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <98B365F9-8E0C-32C7-AC5A-FFB9A4A0B30A> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff29dc3000 - 0x7fff29dc7fff com.apple.xpc.ServiceManagement (1.0 - 1) <7D081389-0032-3521-A3D9-84B4667817FB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff29dc8000 - 0x7fff29dcafff libquarantine.dylib (119.40.2) <3244B57B-9FDF-373E-9F96-A7BAD7534F23> /usr/lib/system/libquarantine.dylib
0x7fff29dcb000 - 0x7fff29dd6fff libCheckFix.dylib (31) <AAB549BA-1738-33FD-BBC4-C34B5070C309> /usr/lib/libCheckFix.dylib
0x7fff29dd7000 - 0x7fff29deefff libcoretls.dylib (169.100.1) <FC2811AD-9D76-3403-B760-32A101D07638> /usr/lib/libcoretls.dylib
0x7fff29def000 - 0x7fff29dfffff libbsm.0.dylib (68.40.1) <61577B7F-2C06-365C-9039-E00B0B5258D0> /usr/lib/libbsm.0.dylib
0x7fff29e00000 - 0x7fff29e49fff libmecab.dylib (929.10) <D60C5095-3A5F-3284-9699-08C76DA29CBD> /usr/lib/libmecab.dylib
0x7fff29e4a000 - 0x7fff29e4ffff libgermantok.dylib (24) <6F2B01E8-6077-3B72-91F3-AB6D0FCB15D6> /usr/lib/libgermantok.dylib
0x7fff29e50000 - 0x7fff29e65fff libLinearAlgebra.dylib (1336.140.1) <A450756D-D3AC-342D-A802-ED6C554A494A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff29e66000 - 0x7fff2a084fff com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8AAFA6C5-1FBD-359A-8774-F1D1FBFCCFFE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff2a085000 - 0x7fff2a0d4fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <0C854684-1D62-35D1-83C1-9066DB158189> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff2a0d5000 - 0x7fff2a236fff com.apple.MLCompute (1.0 - 1) <9255AB44-3AB5-3F3F-8FA2-77FEA1C7C221> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
0x7fff2a237000 - 0x7fff2a26dfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <B7361691-334A-3A33-98E1-A9A623E5D26A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff2a26e000 - 0x7fff2a2c4fff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <706E8171-48B3-33A3-B55B-35B5F86F3043> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff2a2c5000 - 0x7fff2a355fff com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <3999E177-7A40-358A-BE89-1F20ADF13740> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff2a356000 - 0x7fff2a365fff com.apple.AppleFSCompression (125 - 1.0) <F7163A3A-C4F0-3169-9501-B9AAB8CAE9CD> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff2a366000 - 0x7fff2a372fff libbz2.1.0.dylib (44) <ECD22F5B-FD6C-39A5-884B-418C6B896263> /usr/lib/libbz2.1.0.dylib
0x7fff2a373000 - 0x7fff2a377fff libsystem_coreservices.dylib (127.1) <619CCB6D-226C-35BD-98FB-04A18FD54792> /usr/lib/system/libsystem_coreservices.dylib
0x7fff2a378000 - 0x7fff2a3a5fff com.apple.CoreServices.OSServices (1122.44 - 1122.44) <C547575F-985F-31B8-A61C-79D3A673B8D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2a3a6000 - 0x7fff2a4d5fff com.apple.AuthKit (1.0 - 1) <C72D7981-A3B6-3883-A14F-43485DF54FC4> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff2a574000 - 0x7fff2a586fff libz.1.dylib (76) <F805C1CB-1B80-33D0-994C-1D522D347A68> /usr/lib/libz.1.dylib
0x7fff2a587000 - 0x7fff2a5cefff libsystem_m.dylib (3186.100.3) <D61B56FE-649B-34A0-8446-25685B2BBBF2> /usr/lib/system/libsystem_m.dylib
0x7fff2a5cf000 - 0x7fff2a5cffff libcharset.1.dylib (59) <363A6C40-7446-3A72-B5EA-4731843CFE2F> /usr/lib/libcharset.1.dylib
0x7fff2a5d0000 - 0x7fff2a5d5fff libmacho.dylib (980) <A4F4D532-7824-3E4E-8FB6-45617415E7DD> /usr/lib/system/libmacho.dylib
0x7fff2a5d6000 - 0x7fff2a5f1fff libkxld.dylib (7195.141.6) <1121F83B-5D42-368B-B440-100418CD4B23> /usr/lib/system/libkxld.dylib
0x7fff2a5f2000 - 0x7fff2a5fdfff libcommonCrypto.dylib (60178.120.3) <CF1E0E70-9F6C-3FAF-82B2-D55F7C9EBB03> /usr/lib/system/libcommonCrypto.dylib
0x7fff2a5fe000 - 0x7fff2a608fff libunwind.dylib (201) <4602E909-C71A-3006-8140-BE616DA241EE> /usr/lib/system/libunwind.dylib
0x7fff2a609000 - 0x7fff2a610fff liboah.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/liboah.dylib
0x7fff2a611000 - 0x7fff2a61bfff libcopyfile.dylib (173.40.2) <B0F35A80-D5E3-33DD-A47D-ACBFE1300523> /usr/lib/system/libcopyfile.dylib
0x7fff2a61c000 - 0x7fff2a623fff libcompiler_rt.dylib (102.2) <1C049207-1719-39AC-A2A9-6E5BE28AA138> /usr/lib/system/libcompiler_rt.dylib
0x7fff2a624000 - 0x7fff2a626fff libsystem_collections.dylib (1439.141.1) <F2D775D9-AAEF-371F-AA54-CFB882B9B430> /usr/lib/system/libsystem_collections.dylib
0x7fff2a627000 - 0x7fff2a629fff libsystem_secinit.dylib (87.60.1) <EB4516ED-1F8B-3E8A-8C4B-B209A33DCCEF> /usr/lib/system/libsystem_secinit.dylib
0x7fff2a62a000 - 0x7fff2a62cfff libremovefile.dylib (49.120.1) <1AEE3D84-32F9-35FB-8036-B178C9E27D20> /usr/lib/system/libremovefile.dylib
0x7fff2a62d000 - 0x7fff2a62dfff libkeymgr.dylib (31) <698AF6EE-08BB-36CF-B7AD-9EC16E36FA0B> /usr/lib/system/libkeymgr.dylib
0x7fff2a62e000 - 0x7fff2a635fff libsystem_dnssd.dylib (1310.140.1) <0685BDB0-9A98-3ADD-B95A-11F221FD80D7> /usr/lib/system/libsystem_dnssd.dylib
0x7fff2a636000 - 0x7fff2a63bfff libcache.dylib (83) <B51FAB34-AA9C-38C5-95F1-E5E54B21EA67> /usr/lib/system/libcache.dylib
0x7fff2a63c000 - 0x7fff2a63dfff libSystem.B.dylib (1292.120.1) <DBD0A184-CD98-3225-8E9B-D5BFE0D30562> /usr/lib/libSystem.B.dylib
0x7fff2a63e000 - 0x7fff2a641fff libfakelink.dylib (3) <BE0E6C60-675A-3739-A47A-67C650B1F790> /usr/lib/libfakelink.dylib
0x7fff2a642000 - 0x7fff2a642fff com.apple.SoftLinking (1.0 - 1) <9E4B6591-74E3-3B36-91C4-851FAA567DAA> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
0x7fff2a643000 - 0x7fff2a67afff libpcap.A.dylib (98.100.3) <6DD23455-C0CA-313E-89B5-A45F8CD71C20> /usr/lib/libpcap.A.dylib
0x7fff2a67b000 - 0x7fff2a76bfff libiconv.2.dylib (59) <90F749E2-9D2D-3323-A018-31A1F95221A1> /usr/lib/libiconv.2.dylib
0x7fff2a76c000 - 0x7fff2a77dfff libcmph.dylib (8) <17871D7D-49C2-3343-AC30-C40E3AD5B2B6> /usr/lib/libcmph.dylib
0x7fff2a77e000 - 0x7fff2a7effff libarchive.2.dylib (83.100.2) <5AF9560E-5683-33A5-8D60-A469193B94E3> /usr/lib/libarchive.2.dylib
0x7fff2a7f0000 - 0x7fff2a857fff com.apple.SearchKit (1.4.1 - 1.4.1) <A45AE5BD-9242-351E-B621-3EB50F66AB30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2a858000 - 0x7fff2a859fff libThaiTokenizer.dylib (3) <7B40AC51-B945-3AF0-B349-5818050D37FB> /usr/lib/libThaiTokenizer.dylib
0x7fff2a85a000 - 0x7fff2a87cfff com.apple.applesauce (1.0 - 16.28) <7D011403-38CD-37DA-B2C2-00D2D2273422> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff2a87d000 - 0x7fff2a894fff libapple_nghttp2.dylib (1.41) <E3FCBDB9-6671-3368-B371-B9CAC9BB1B45> /usr/lib/libapple_nghttp2.dylib
0x7fff2a895000 - 0x7fff2a8abfff libSparseBLAS.dylib (1336.140.1) <78762464-084C-3743-BC56-A2AF5D010909> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2a8ac000 - 0x7fff2a8adfff com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <BD2B6B2B-E116-3B97-A25F-71B4AC7B2BA6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff2a8ae000 - 0x7fff2a8b2fff libpam.2.dylib (28.40.1) <E73D1903-42B9-3FF9-AE5D-482672F015AC> /usr/lib/libpam.2.dylib
0x7fff2a8b3000 - 0x7fff2a8d2fff libcompression.dylib (96.120.1) <CFE780B4-AFB0-327C-BB68-A5565AA7C630> /usr/lib/libcompression.dylib
0x7fff2a8d3000 - 0x7fff2a8d8fff libQuadrature.dylib (7) <9668C241-61D5-3AE9-9856-708ACDC27F12> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2a8d9000 - 0x7fff2ac76fff libLAPACK.dylib (1336.140.1) <8B968A9A-8263-3639-A740-636387467C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2ac77000 - 0x7fff2acc6fff com.apple.DictionaryServices (1.2 - 341) <617030DF-769F-3CE0-869F-7F5B9B5A3784> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2acc7000 - 0x7fff2acdffff liblzma.5.dylib (16) <6DE3F2AA-7140-3F6D-AD12-0DBA19BBBD54> /usr/lib/liblzma.5.dylib
0x7fff2ace0000 - 0x7fff2ace1fff libcoretls_cfhelpers.dylib (169.100.1) <0CF72D7A-0A39-3683-82ED-29A09761D6FF> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff2ace2000 - 0x7fff2adddfff com.apple.APFS (1677.141.2 - 1677.141.2) <F42A21D0-F8CE-3DDA-ACE6-C0AC9EE2FA6C> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff2adde000 - 0x7fff2adebfff libxar.1.dylib (452) <0B0B68CC-D627-3BDC-AE01-007C6AD8E97B> /usr/lib/libxar.1.dylib
0x7fff2adec000 - 0x7fff2adeffff libutil.dylib (58.40.2) <0EA3237C-B6E6-351B-AE27-8975D88602D6> /usr/lib/libutil.dylib
0x7fff2adf0000 - 0x7fff2ae18fff libxslt.1.dylib (17.6) <300C3D2D-19B1-3D8E-B212-1D2EB6C8B80A> /usr/lib/libxslt.1.dylib
0x7fff2ae19000 - 0x7fff2ae23fff libChineseTokenizer.dylib (37.1) <B4314553-EF8B-3CD4-A7D8-76CD7FC7142D> /usr/lib/libChineseTokenizer.dylib
0x7fff2ae24000 - 0x7fff2aee1fff libvMisc.dylib (760.100.3) <B8F30684-94D1-3A53-80BF-C78F424594AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2aee2000 - 0x7fff2af79fff libate.dylib (3.0.6) <FA881406-28F3-33BD-B75D-40389CE2ADD1> /usr/lib/libate.dylib
0x7fff2af7a000 - 0x7fff2af81fff libIOReport.dylib (64.100.1) <4D638FAC-2FD8-359C-8159-1ED37CBB5704> /usr/lib/libIOReport.dylib
0x7fff2af82000 - 0x7fff2af95fff com.apple.CrashReporterSupport (10.13 - 15053.1) <B879B52A-5A65-3CB3-B271-15A032853A35> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff2b083000 - 0x7fff2b08afff libMatch.1.dylib (38) <85F66EF8-FC5E-385C-AF8F-79532C2AC988> /usr/lib/libMatch.1.dylib
0x7fff2b08b000 - 0x7fff2b116fff libCoreStorage.dylib (554.140.2) <249F3E03-6C96-3E20-999A-BBFE36AADECA> /usr/lib/libCoreStorage.dylib
0x7fff2b117000 - 0x7fff2b16afff com.apple.AppleVAFramework (6.1.3 - 6.1.3) <2CDA1194-F435-3B9C-94A2-220E26E40DE6> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff2b16b000 - 0x7fff2b184fff libexpat.1.dylib (26.141.1) <84DC54E5-9E75-3F64-9D7F-3CA641674ED8> /usr/lib/libexpat.1.dylib
0x7fff2b185000 - 0x7fff2b18efff libheimdal-asn1.dylib (597.140.2) <8D7B3A0D-A699-3947-9E8C-EEA4B4AD6408> /usr/lib/libheimdal-asn1.dylib
0x7fff2b18f000 - 0x7fff2b1a3fff com.apple.IconFoundation (479.4 - 479.4) <6ED33568-2A1D-3918-9D32-D1E102002E48> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
0x7fff2b1a4000 - 0x7fff2b210fff com.apple.IconServices (479.4 - 479.4) <D94D5AF3-6EF6-30D8-A7F8-58A1A3E5641B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff2b211000 - 0x7fff2b2affff com.apple.MediaExperience (1.0 - 1) <245932F7-E76A-37A7-A033-7BB62F8ED190> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff2b2b0000 - 0x7fff2b2d8fff com.apple.persistentconnection (1.0 - 1.0) <90FBA2DD-E91A-3A9F-80C5-8F94950136A4> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff2b2d9000 - 0x7fff2b2e7fff com.apple.GraphVisualizer (1.0 - 100.1) <9538C368-5703-367B-ADAE-20EC5C3C5C41> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff2b2e8000 - 0x7fff2b703fff com.apple.vision.FaceCore (4.3.2 - 4.3.2) <86110F21-96FE-325C-8D55-9385690C2386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff2b704000 - 0x7fff2b74bfff com.apple.OTSVG (1.0 - 677.6.0.2) <34AD6D57-71B8-3859-94AF-DB856D8FD6BA> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff2b74c000 - 0x7fff2b752fff com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <AD03039F-3D12-31FE-A497-EC4A87097683> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
0x7fff2b753000 - 0x7fff2b765fff libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <B4F0CDA6-0332-3AB9-A0FB-8CD6EE316D30> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff2b766000 - 0x7fff2b768fff libspindump.dylib (295.2) <8DE7E414-DCEC-30B8-87DC-511D362D49F3> /usr/lib/libspindump.dylib
0x7fff2b769000 - 0x7fff2b829fff com.apple.Heimdal (4.0 - 2.0) <30D71BC9-C18F-35C7-B7E1-88E645D4D329> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff2b82a000 - 0x7fff2b844fff com.apple.login (3.0 - 3.0) <0690C64C-DE8C-3AA2-A4A5-BE3EFC3BDC62> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff2b9c9000 - 0x7fff2ba05fff com.apple.bom (14.0 - 235) <E428566D-DFA2-33AC-AF3B-C68530D52522> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff2ba06000 - 0x7fff2ba4ffff com.apple.AppleJPEG (1.0 - 1) <15DCB33B-EB52-38A2-B02F-EC235DC85B52> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff2ba50000 - 0x7fff2bb2ffff libJP2.dylib (2130.7.3) <20747AB5-CFA0-3C7A-BE41-BF4B54FD2038> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff2bb30000 - 0x7fff2bb33fff com.apple.WatchdogClient.framework (1.0 - 98.120.2) <0A097C25-405B-38CD-B6E2-57F51AD77AF0> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff2bb34000 - 0x7fff2bb6afff com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <0DF955E2-E57C-3C1B-96BD-5B81DAD43BC7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff2bb6b000 - 0x7fff2bcc9fff com.apple.VideoToolbox (1.0 - 2780.10) <4FF9A4C0-FFB4-3F68-9A84-949B4DB0DB7A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff2bcca000 - 0x7fff2bcfdfff libAudioToolboxUtility.dylib (1181.72) <9D9EA545-924D-342A-BF27-C19887850F05> /usr/lib/libAudioToolboxUtility.dylib
0x7fff2bcfe000 - 0x7fff2bd1efff libPng.dylib (2130.7.3) <29756FE6-34E9-3760-9B70-9FF6648BE7CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff2bd1f000 - 0x7fff2bd7efff libTIFF.dylib (2130.7.3) <692B9470-8F28-3C98-9C6A-DAE79FE0136F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff2bd7f000 - 0x7fff2bd9bfff com.apple.IOPresentment (58 - 37) <A86E6181-E216-3691-A7FF-0264A927C8CC> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff2bd9c000 - 0x7fff2bda3fff com.apple.GPUWrangler (6.3.5 - 6.3.5) <CC101DAE-349B-3C72-9554-6F569364841E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff2bda4000 - 0x7fff2bda7fff libRadiance.dylib (2130.7.3) <1A759A2B-28E8-32C4-940D-BE0239558098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff2bda8000 - 0x7fff2bdadfff com.apple.DSExternalDisplay (3.1 - 380) <3FD5886F-5EDD-313D-9783-FF899E5F2650> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff2bdae000 - 0x7fff2bdd2fff libJPEG.dylib (2130.7.3) <C0903C97-523A-3822-ABE4-D1047D6785DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff2bdd3000 - 0x7fff2be02fff com.apple.ATSUI (1.0 - 1) <F9BEFF92-E409-35B6-89CB-0F221D804D3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2be03000 - 0x7fff2be07fff libGIF.dylib (2130.7.3) <E92A145C-2B76-39D1-B481-B7C95ACBF989> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff2be08000 - 0x7fff2be11fff com.apple.CMCaptureCore (1.0 - 82.6) <E0EAD649-4C7A-384E-999B-4D82AA9CDA52> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
0x7fff2be12000 - 0x7fff2be59fff com.apple.print.framework.PrintCore (16.1 - 531.1) <035969B9-3323-3AF4-AC4C-1D5B941C7C62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2be5a000 - 0x7fff2bf27fff com.apple.TextureIO (3.10.9 - 3.10.9) <4B778275-5F2D-36DA-A6AD-14C8E516E197> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff2bf28000 - 0x7fff2bf30fff com.apple.InternationalSupport (1.0 - 61.1) <56A6D4F8-FF5B-3F34-BD1A-249414F182E9> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff2bf31000 - 0x7fff2bfabfff com.apple.datadetectorscore (8.0 - 674) <CDA8DABD-62A3-3E1C-9A76-B00E1E950254> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff2bfac000 - 0x7fff2c009fff com.apple.UserActivity (439 - 439) <C272F369-1086-317C-A4CF-AE2E1EC4FFB4> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
0x7fff2cbe7000 - 0x7fff2cc4dfff com.apple.imfoundation (10.0 - 1000) <1D902049-CAD5-3DE0-AE4A-9AACEBB586BE> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff2cc4e000 - 0x7fff2cc76fff com.apple.locationsupport (2420.19.23 - 2420.19.23) <9A015D62-2143-3199-AD14-ECA953A728D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff2cc77000 - 0x7fff2cca8fff libSessionUtility.dylib (76.69) <400DF595-A30C-3AD3-A8BA-25260299ACE6> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff2cca9000 - 0x7fff2cdddfff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <93226BB9-165F-3A42-8EE3-9670394C4DC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2cdde000 - 0x7fff2ce43fff com.apple.audio.AudioSession (1.0 - 76.69) <ADC1C8FC-A444-3F15-A396-B4AB688BB326> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff2ce44000 - 0x7fff2ce56fff libAudioStatistics.dylib (27.64) <74E8B615-03FE-327B-A8FB-EAC5EF117414> /usr/lib/libAudioStatistics.dylib
0x7fff2ce57000 - 0x7fff2ce66fff com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <CE36276F-23DD-32A3-9863-D3A5DDE5965E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2ce67000 - 0x7fff2ced3fff com.apple.ApplicationServices.ATS (377 - 516) <6E601872-2340-3675-9B6F-0C1DB991C54E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2ced4000 - 0x7fff2ceecfff libresolv.9.dylib (68) <86A4BABF-3EFC-3113-BE8A-2D1AAAEF0194> /usr/lib/libresolv.9.dylib
0x7fff2cf6d000 - 0x7fff2cfa0fff com.apple.securityinterface (10.0 - 55149.120.1) <10A7DFC1-8C46-382C-AEF0-89B151767F50> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff2d01f000 - 0x7fff2d0fefff libSMC.dylib (20) <CF88A94C-B5EE-306F-96A3-1442BA061C46> /usr/lib/libSMC.dylib
0x7fff2d0ff000 - 0x7fff2d15efff libcups.2.dylib (494.3) <2CE9752F-8763-3456-83CF-E4BCFB731153> /usr/lib/libcups.2.dylib
0x7fff2d15f000 - 0x7fff2d16efff com.apple.LangAnalysis (1.7.0 - 254) <AB67008E-5986-3974-B986-FDBFAC018CAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2d16f000 - 0x7fff2d179fff com.apple.NetAuth (6.2 - 6.2) <B5806BA7-9A6E-37A0-9AB9-6EC2D61844AC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff2d17a000 - 0x7fff2d181fff com.apple.ColorSyncLegacy (4.13.0 - 1) <86D9E9C9-C631-371E-824E-A203FE9E560A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2d182000 - 0x7fff2d18dfff com.apple.QD (4.0 - 416) <1D8792FC-4A76-3B4F-82CF-3889C05768FE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2d18e000 - 0x7fff2d7e2fff com.apple.audio.AudioResourceArbitration (1.0 - 1) <C97CD66B-8267-3C39-B025-789864237928> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff2d7e3000 - 0x7fff2d7eefff com.apple.perfdata (1.0 - 67.40.1) <10E2B0C5-83A4-368A-B972-7AFA40D5338C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
0x7fff2d7ef000 - 0x7fff2d7fdfff libperfcheck.dylib (41) <A2D0E1A8-A98F-3DAA-B9FC-C033FC4CD9E0> /usr/lib/libperfcheck.dylib
0x7fff2d7fe000 - 0x7fff2d80dfff com.apple.Kerberos (3.0 - 1) <0074E20F-E7D8-31F5-AF41-0D7BF370CD50> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff2d80e000 - 0x7fff2d85efff com.apple.GSS (4.0 - 2.0) <D546E52C-295F-3CCD-9925-03632FE72ECB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff2d85f000 - 0x7fff2d86ffff com.apple.CommonAuth (4.0 - 2.0) <DF20551B-1514-39B3-A52E-681A2E5F0D1C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff2d8c5000 - 0x7fff2d8e4fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <C48DA26A-6A69-3497-B94D-43332354162B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff2d8e5000 - 0x7fff2d8edfff com.apple.CorePhoneNumbers (1.0 - 1) <9F49D632-C5F4-37F5-A2A8-2830A7560138> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff2d8ee000 - 0x7fff2d977fff libTelephonyUtilDynamic.dylib (5359.1) <DDF9B2A1-D071-3180-9BC6-A143D6D9E713> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff2da40000 - 0x7fff2da40fff liblaunch.dylib (2038.120.1) <4A353070-A560-3A98-8869-28C92435C6B2> /usr/lib/system/liblaunch.dylib
0x7fff2dd39000 - 0x7fff2dfc4fff com.apple.NetworkExtension (1.0 - 1) <727B66BE-EED5-324A-8FDC-14E91844B92E> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff2dfc5000 - 0x7fff2e0c6fff com.apple.ids (10.0 - 1000) <F30AC7B8-FACA-3B37-914D-C7AFA47A9DAE> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff2e0c7000 - 0x7fff2e221fff com.apple.idsfoundation (10.0 - 1000) <3EAAA079-B3EE-3A12-B181-3267029FB4B0> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff2e222000 - 0x7fff2e36dfff com.apple.Sharing (1630 - 1630) <CE657A48-7BDD-34D7-9CBC-B1D6AD94B2B2> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff2e36e000 - 0x7fff2e48ffff com.apple.Bluetooth (8.0.5 - 8.0.5d7) <D011494A-287B-3487-B817-2329843C2486> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff2e4a9000 - 0x7fff2e502fff com.apple.ProtectedCloudStorage (1.0 - 1) <EA0958A6-8296-3E23-81BE-297473A6E17E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff2e762000 - 0x7fff2fc5dfff com.apple.GeoServices (1.0 - 1757.26.6.2.2) <1A271F08-3D05-36BF-A136-7D48B4418CD6> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff2fc6a000 - 0x7fff2fc91fff com.apple.RemoteViewServices (2.0 - 163) <7DBF2A51-CE8E-352E-9426-B83DC370ADDD> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff2fc92000 - 0x7fff2fca1fff com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <076E6A5F-4FEE-378B-9DCD-AFFA1348C64F> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff2fca2000 - 0x7fff2fca9fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <DB80BAB9-5E83-32DB-A424-05BB19044665> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2fed7000 - 0x7fff2fed7fff libsystem_product_info_filter.dylib (8.40.1) <78928329-DD98-3799-989D-870DF92FE8D5> /usr/lib/system/libsystem_product_info_filter.dylib
0x7fff2ff4f000 - 0x7fff2ff66fff libnetworkextension.dylib (1295.140.3) <70743C15-3A7D-308C-9238-7E20FBF73199> /usr/lib/libnetworkextension.dylib
0x7fff2ffaf000 - 0x7fff2ffaffff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <CDB56324-715E-3223-903F-EEC1D4E57F14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2ffd5000 - 0x7fff2ffd5fff com.apple.CoreServices (1122.44 - 1122.44) <104E1757-7D8A-32D3-9B38-B23B1A8EAB17> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff30191000 - 0x7fff30191fff com.apple.Accelerate (1.11 - Accelerate 1.11) <28463942-495F-3231-9348-32ABC601A1F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff301d2000 - 0x7fff301ddfff com.apple.MediaAccessibility (1.0 - 130) <677557AF-6AC1-3860-B7C4-772B8DA9957B> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff301fe000 - 0x7fff30202fff com.apple.AppleSRP (5.0 - 1) <A8B167C6-9E49-3ED9-AD87-36BEA98F6E20> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff30203000 - 0x7fff3020efff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <6873367E-2879-3C96-A766-AD6DFD69F36A> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff309d3000 - 0x7fff30a38fff com.apple.CoreBluetooth (1.0 - 1) <32288DE3-BD59-35A6-9165-73176E074499> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff30a39000 - 0x7fff30a42fff com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <9A1589E7-0B3A-3DC5-967C-7A3D4C14ED1E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff30a56000 - 0x7fff30a62fff com.apple.AppleIDAuthSupport (1.0 - 1) <C391F5AD-7903-31AF-8608-7826C0EFB3C5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff30a63000 - 0x7fff30b0bfff com.apple.DiscRecording (9.0.3 - 9030.4.5) <08A9AAA6-7057-3105-BDE1-DC7270C38774> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff30b0c000 - 0x7fff30b3ffff com.apple.MediaKit (16 - 927.40.2) <86B948D3-5757-37A7-B2DA-F7C50778B108> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff30b40000 - 0x7fff30c2bfff com.apple.DiskManagement (14.0 - 1733.140.2) <CF6680B9-9799-3DE8-A600-094260672A4F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff31019000 - 0x7fff31168fff com.apple.FileProvider (349.4.3 - 349.4.3) <E07C8909-299C-3696-BD84-5CF42EE64EE4> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff31169000 - 0x7fff3118bfff com.apple.GenerationalStorage (2.0 - 323) <9E36AF92-10E2-382B-A07C-4E3270448690> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff31ac7000 - 0x7fff31b02fff com.apple.DebugSymbols (195.1 - 195.1) <7D2E32A0-DB93-36EE-AE9C-7974708CF4FC> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff31b03000 - 0x7fff31bb8fff com.apple.CoreSymbolication (12.5 - 64544.81.1) <7215543C-E3B6-30A0-8B21-7FBDFB10F198> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff31bb9000 - 0x7fff31bc2fff com.apple.CoreTime (284.0.4) <DAEEF1D8-1C34-37AC-9691-C4540C92E9F9> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
0x7fff32ac7000 - 0x7fff32b2afff com.apple.framework.Apple80211 (17.0 - 1728) <D89EA57A-D351-3BD1-A470-505C6D8BF4D6> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff32b2b000 - 0x7fff32c7cfff com.apple.CoreWiFi (3.0 - 341) <0FE4018E-E199-3923-A56D-430E40F5EEB7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff32eb6000 - 0x7fff32eecfff com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <FE03407F-3251-30BD-AA64-8DE2940C0F57> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff32eed000 - 0x7fff32efcfff com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <8F0CFA90-78B8-3305-BCD3-6C28B7838CE0> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff32f5a000 - 0x7fff32f5dfff com.apple.help (1.3.8 - 71) <CF14979A-CA27-32D1-A3E8-D99AD6C91464> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff32f5e000 - 0x7fff32f65fff com.apple.EFILogin (2.0 - 2) <77A5D3D5-3B8D-3B5D-A1BD-A7614C86AF67> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff32f66000 - 0x7fff32f71fff libcsfde.dylib (554.140.2) <8B6A31B3-9421-3BAE-882B-8BEF5217E251> /usr/lib/libcsfde.dylib
0x7fff331b0000 - 0x7fff331b0fff com.apple.ApplicationServices (48 - 50) <52BB5EB6-2C1B-34F9-8665-F50DD078E71B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff333b2000 - 0x7fff33409fff com.apple.CorePrediction (1.0 - 1) <0858EE22-68F8-31C9-88A2-B94D225CEE9E> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff334c5000 - 0x7fff334c5fff libHeimdalProxy.dylib (79) <A1B83B1E-006D-38A8-8878-FD6ECBBB9B1B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff33578000 - 0x7fff33578fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <0A5BB3A7-D9DC-346C-9FBB-FB075194E7AC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff33620000 - 0x7fff33625fff com.apple.PushKit (1.0 - 1) <02EC6449-963F-376C-BE24-F9CC8083ABD3> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff33626000 - 0x7fff33659fff com.apple.C2 (1.3 - 573) <1D8BCCDC-EFB0-3DF8-93A4-4D18388D7C11> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff34548000 - 0x7fff34598fff com.apple.ChunkingLibrary (334.1 - 334.1) <2CD91198-1354-357F-8858-D58244526C15> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff34c4b000 - 0x7fff34df1fff com.apple.WebKitLegacy (16611 - 16611.3.10.1.6) <D06037B8-003A-36DA-992F-62B478338C33> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff34df2000 - 0x7fff34df4fff com.apple.ConstantClasses (1.0 - 1) <7821839C-0DE2-32F2-B19E-76C5A8541CE7> /System/Library/PrivateFrameworks/ConstantClasses.framework/Versions/A/ConstantClasses
0x7fff34fa8000 - 0x7fff34fabfff com.apple.Cocoa (6.11 - 23) <237F7F6E-E7D1-363A-92AF-32B564728891> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff360d6000 - 0x7fff3636afff libAWDSupportFramework.dylib (4205) <879C09AE-5344-3B02-A93F-8B3C46B39F17> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff363de000 - 0x7fff3640efff libtidy.A.dylib (18.2) <1AF8A622-91F8-3193-BA3D-CB1A799565A8> /usr/lib/libtidy.A.dylib
0x7fff36430000 - 0x7fff36443fff com.apple.Engram (1.0 - 1) <AED2FFE9-3841-33B1-B552-A75B17A20A3A> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff36444000 - 0x7fff36467fff com.apple.openscripting (1.7 - 190) <A2516A00-ECC2-31F2-9157-90AF9A4C6F56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff36468000 - 0x7fff3646bfff com.apple.securityhi (9.0 - 55008) <DDAD2F6D-2105-370E-9C96-63ABF95ABF00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3646c000 - 0x7fff3646ffff com.apple.ink.framework (10.15 - 227) <6177BDED-F304-3EAD-B72E-23A050856753> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff36470000 - 0x7fff36473fff com.apple.CommonPanels (1.2.6 - 101) <E6BB8219-34DB-3A11-A3C2-B17AD8E42414> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff36474000 - 0x7fff3647bfff com.apple.ImageCapture (1711.5.2 - 1711.5.2) <E3871995-745C-35A8-8B48-647DAAF046E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3647c000 - 0x7fff3766cfff com.apple.JavaScriptCore (16611 - 16611.3.10.1.6) <E1A54760-8F75-3A78-89F7-232D9EC162E8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff38be9000 - 0x7fff38be9fff com.apple.marco (10.0 - 1000) <6E3E4EC3-3DD4-332D-8D0F-DC0F946269CB> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff3929d000 - 0x7fff392a4fff com.apple.URLFormatting (146 - 146.22) <05567C81-E57E-3201-8DB5-9DC03762E7E7> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff392a5000 - 0x7fff392b3fff com.apple.accessibility.AXCoreUtilities (1.0 - 1) <FF5E6B22-0BE8-36A1-90CB-44087715CCCB> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff392b4000 - 0x7fff392cbfff libAccessibility.dylib (2885.49) <0F94A4D4-E4D0-3968-95AF-9A123C5A699E> /usr/lib/libAccessibility.dylib
0x7fff392cc000 - 0x7fff3ba16fff com.apple.WebCore (16611 - 16611.3.10.1.6) <20CBDB85-8A66-3999-9C7C-45403F05958D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff3bff4000 - 0x7fff3c042fff com.apple.Safari.SafeBrowsing (16611 - 16611.3.10.1.6) <5513EB53-B539-3D8D-801D-E64175D3A03C> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff3c043000 - 0x7fff3c822fff com.apple.WebKit (16611 - 16611.3.10.1.6) <C2B252E6-5870-3B58-B918-03F8307F0729> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff3c9d5000 - 0x7fff3c9d8fff com.apple.print.framework.Print (15 - 271) <29E7EB03-0307-35D9-B56F-B9DCB5C5A4E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3c9d9000 - 0x7fff3c9dcfff com.apple.Carbon (160 - 164) <B86E3835-F4BE-3DCA-88C7-CEA01227DF58> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3cc8f000 - 0x7fff3ccaefff com.apple.private.SystemPolicy (1.0 - 1) <8BC55621-1E45-33B3-BCD6-C59F1F390695> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
0x7fff3cdfb000 - 0x7fff3ce51fff com.apple.AccessibilitySharedSupport (1.0 - 1) <6B0C8DD8-3606-3F13-AD29-D1EC83B8459C> /System/Library/PrivateFrameworks/AccessibilitySharedSupport.framework/Versions/A/AccessibilitySharedSupport
0x7fff3ce52000 - 0x7fff3ce6ffff com.apple.sidecar-core (1.0 - 231) <D0C9A506-6BF0-3D13-9D10-489BF305CB79> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff3d286000 - 0x7fff3d28afff com.apple.CoreOptimization (1.0 - 1) <65BA73C7-2DEA-3AA9-B59D-750B505B54EA> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff3d5cc000 - 0x7fff3d5d7fff com.apple.MallocStackLogging (1.0 - 1) <DF41452E-DA3E-3F74-9354-6F82BE363DB8> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
0x7fff3d5ec000 - 0x7fff3d5fefff libmis.dylib (274.140.2) <570E2D9A-BC76-37F7-8CFC-E18AD5E81CE0> /usr/lib/libmis.dylib
0x7fff3dafe000 - 0x7fff3db0ffff com.apple.sidecar-ui (1.0 - 231) <363E669A-2E00-3EAB-A7F1-E85836913057> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff3db1b000 - 0x7fff3db1efff com.apple.WebInspectorUI (16611 - 16611.3.10.1.6) <D8D7C00F-BE02-3C77-9603-0ECB13AB881D> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
0x7fff3fc73000 - 0x7fff3fcf0fff com.apple.TextInput (1.0 - 1.0) <282E6B77-4CDF-39A6-8ED3-288E35F7881A> /System/Library/PrivateFrameworks/TextInput.framework/Versions/A/TextInput
0x7fff40a34000 - 0x7fff40a3ffff com.apple.CaptiveNetworkSupport (13.0 - 1) <B7F41903-09D2-3BED-A223-7D28603816E9> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/Versions/A/CaptiveNetwork
0x7fff412b3000 - 0x7fff412d1fff libCGInterfaces.dylib (544.4) <05A5B7E9-C79A-3FEA-AD6C-72FE168004C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff479dc000 - 0x7fff47a1cfff com.apple.osanalytics.OSAnalytics (1.0 - 1) <19C9EC00-4A56-303C-9C22-47AF6222F1AF> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
0x7fff51652000 - 0x7fff5167ffff com.apple.HelpData (2.3 - 201) <C363EE82-8CD2-3D4A-8716-78304D2FDE2B> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff51680000 - 0x7fff5169afff com.apple.shortcut (2.16 - 118) <3520B72B-0EE2-3D7C-8A7A-DEB402A38867> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff5169b000 - 0x7fff5173afff com.apple.Symbolication (12.5 - 64544.70.1) <262C27E9-D575-3209-8403-C314C534D1B0> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff6bb36000 - 0x7fff6bb3cfff libCoreFSCache.dylib (200.11) <3C96E791-3964-32EA-A84A-00DF3455B43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff6bb3d000 - 0x7fff6bb41fff libCoreVMClient.dylib (200.11) <966F49F6-D2D5-3ACB-9CFD-9F8D3C8C82F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff6bb42000 - 0x7fff6bb51fff com.apple.opengl (18.5.9 - 18.5.9) <5C26B170-E22B-3AAD-BA33-61304FFA70B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff6bb52000 - 0x7fff6bb54fff libCVMSPluginSupport.dylib (18.5.9) <435F258D-95B5-3015-BDAC-4B8EF8E89F1E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff6bb55000 - 0x7fff6bb5dfff libGFXShared.dylib (18.5.9) <851E0956-A16E-3F5D-B3BE-37B56C2BAA04> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff6bb5e000 - 0x7fff6bb91fff libGLImage.dylib (18.5.9) <687EBB15-1AB3-3815-A69D-58527655A92D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff6bb92000 - 0x7fff6bbcefff libGLU.dylib (18.5.9) <29B7802C-F6E4-3DF1-B5D6-07B29C6D02B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff6bd63000 - 0x7fff6bd6dfff libGL.dylib (18.5.9) <8A4ED04C-9171-3CE2-A52A-E7C4D76A6EDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff6d1ad000 - 0x7fff6d205fff com.apple.opencl (4.6 - 4.6) <713206B3-A335-3AC5-B342-4CE16BDF69F4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff6f532000 - 0x7fff6f53cfff com.apple.AccessibilityBundles (1.0 - 174) <1C1919E2-6737-39FF-A494-944BAAC36F19> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff779e1000 - 0x7fff779e8fff libRosetta.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/libRosetta.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=818.1M resident=0K(0%) swapped_out_or_unallocated=818.1M(100%)
Writable regions: Total=2.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.4G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 768K 6
Activity Tracing 256K 1
CG backing stores 3792K 6
CG image 4036K 25
CG raster data 980K 1
CoreAnimation 39.5M 14
CoreGraphics 12K 2
CoreUI image data 916K 9
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 467.3M 103
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 1.5G 13 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.1M 25
Stack 20.2M 28
VM_ALLOCATE 100K 23
__DATA 16.2M 342
__DATA_CONST 19.1M 203
__DATA_DIRTY 889K 127
__FONT_DATA 4K 1
__LINKEDIT 502.1M 7
__OBJC_RO 70.3M 1
__OBJC_RW 2496K 2
__TEXT 316.1M 348
__UNICODE 588K 1
mapped file 251.4M 31
shared memory 756K 15
TOTAL 3.6G 1347
TOTAL, minus reserved VM space 1.7G 1347
Model: MacBookPro15,1, BootROM 1554.140.20.0.0 (iBridge: 18.16.14759.0.1,0), 8 processors, 8-Core Intel Core i9, 2.3 GHz, 32 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro560XItem, Radeon Pro 560X, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Aug 10 2021 19:55:28 version 9.30.444.18.32.5.71 FWID 01-93db3422
Bluetooth: Version 8.0.5d7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.1 Bus
USB Device: AirPod Case
USB Device: Apple T2 Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 47.5
