Acknowledged
Connect IQ simulator 7.4.3 crashes frequently on Mac
Translated Report (Full Report Below)
Process: simulator [25524]
Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
Identifier: com.garmin.connectiq.simulator
Version: 7.4.3 (7.4.3)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-02-28 18:18:22.5964 +0100
OS Version: macOS 15.3.1 (24D70)
Report Version: 12
Anonymous UUID: 277CCC3B-2E88-EAA7-7D3F-B4E208A73F60
Sleep/Wake UUID: 1F35A1A6-C913-47F9-8482-08E716F0A450
Time Awake Since Boot: 400000 seconds
Time Since Wake: 5610 seconds
System Integrity Protection: enabled
Crashed Thread: 11 TVM main
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0xfc9d0020d9180118 -> 0xffff8020d9180118 (possible pointer authentication failure)
Exception Codes: 0x0000000000000001, 0xfc9d0020d9180118
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [25524]
VM Region Info: 0xffff8020d9180118 is not in any region. Bytes after previous region: 18446602996264698137
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
owned unmapped memory unmapped-unmapped [ 1312K] rw-/rw- SM=PRV owned physical footprint (unmapped)
UNUSED SPACE AT END
Thread 0:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x1809da1f0 objc_autorelease + 32
1 AppKit 0x184a0c66c -[NSMenuItem dealloc] + 40
2 simulator 0x1017a0170 0x100d08000 + 11108720
3 simulator 0x1017481e4 0x100d08000 + 10748388
4 simulator 0x101854b58 0x100d08000 + 11848536
5 simulator 0x100dc9658 0x100d08000 + 792152
6 simulator 0x100db48a8 0x100d08000 + 706728
7 simulator 0x1016cc804 0x100d08000 + 10242052
8 simulator 0x1016cdd58 0x100d08000 + 10247512
9 simulator 0x1016cdee4 0x100d08000 + 10247908
10 simulator 0x1016cdc8c 0x100d08000 + 10247308
11 simulator 0x1016cd8b0 0x100d08000 + 10246320
12 simulator 0x1016030c4 0x100d08000 + 9416900
13 simulator 0x1016add00 0x100d08000 + 10116352
14 CoreFoundation 0x180e8bbe8 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 36
15 CoreFoundation 0x180e8bad4 __CFRunLoopDoObservers + 552
16 CoreFoundation 0x180e8b104 __CFRunLoopRun + 788
17 CoreFoundation 0x180e8a734 CFRunLoopRunSpecific + 588
18 HIToolbox 0x18c3f9530 RunCurrentEventLoopInMode + 292
19 HIToolbox 0x18c3ff17c ReceiveNextEventCommon + 216
20 HIToolbox 0x18c3ff508 _BlockUntilNextEventMatchingListInModeWithFilter + 76
21 AppKit 0x184a02848 _DPSNextEvent + 660
22 AppKit 0x185368c24 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688
23 AppKit 0x1849f5874 -[NSApplication run] + 480
24 simulator 0x101799a04 0x100d08000 + 11082244
25 simulator 0x1016ae690 0x100d08000 + 10118800
26 simulator 0x10162e4a0 0x100d08000 + 9594016
27 simulator 0x1016025cc 0x100d08000 + 9414092
28 simulator 0x10175b04c 0x100d08000 + 10825804
29 simulator 0x10165c354 0x100d08000 + 9782100
30 simulator 0x100d472c8 0x100d08000 + 258760
31 dyld 0x180a24274 start + 2840
Thread 1:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x180d62f54 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x180d75604 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x180d6baf8 mach_msg_overwrite + 480
3 libsystem_kernel.dylib 0x180d6329c mach_msg + 24
4 CoreFoundation 0x180e8ca4c __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x180e8b2ac __CFRunLoopRun + 1212
6 CoreFoundation 0x180e8a734 CFRunLoopRunSpecific + 588
7 AppKit 0x184b27278 _NSEventThread + 148
8 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
9 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 2:: TSK bkgd
0 libsystem_kernel.dylib 0x180d666ec __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x180da4894 _pthread_cond_wait + 1204
2 simulator 0x1014d1ad8 0x100d08000 + 8166104
3 simulator 0x1014d0d4c 0x100d08000 + 8162636
4 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
5 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 3:: NFM_Region_0
3 simulator 0x10154d28c 0x100d08000 + 8671884
4 simulator 0x1014d0d80 0x100d08000 + 8162688
5 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
6 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 4:: Cache Mngr
2 simulator 0x1014d05f4 0x100d08000 + 8160756
3 simulator 0x1014d89f4 0x100d08000 + 8194548
4 simulator 0x101505cac 0x100d08000 + 8379564
5 simulator 0x1015026b0 0x100d08000 + 8365744
6 simulator 0x1014d0d80 0x100d08000 + 8162688
7 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
8 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 5:: IOPAppMain
3 simulator 0x101251e1c 0x100d08000 + 5545500
4 simulator 0x1014d0d68 0x100d08000 + 8162664
Thread 6:: ant_main
1 libsystem_pthread.dylib 0x180da48c0 _pthread_cond_wait + 1248
2 simulator 0x1014d0844 0x100d08000 + 8161348
3 simulator 0x1014d1ad8 0x100d08000 + 8166104
4 simulator 0x1012235d8 0x100d08000 + 5354968
5 simulator 0x1014d0d68 0x100d08000 + 8162664
6 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
7 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 7:: GPS main
Thread 8:: SNS main
Thread 9:: fit activity
3 simulator 0x101290244 0x100d08000 + 5800516
Thread 10:: ftm main
4 simulator 0x10129f32c 0x100d08000 + 5862188
Thread 11 Crashed:: TVM main
0 simulator 0x1016c4204 0x100d08000 + 10207748
1 simulator 0x100e4d51c 0x100d08000 + 1332508
2 simulator 0x1014d9014 0x100d08000 + 8196116
3 simulator 0x101477148 0x100d08000 + 7795016
Thread 12:: TVM defrag
Thread 13:: parse main
4 simulator 0x100d2748c 0x100d08000 + 128140
Thread 14:: GPX archive trk
3 simulator 0x10156047c 0x100d08000 + 8750204
Thread 15:: URM Main
3 simulator 0x101274c28 0x100d08000 + 5688360
Thread 16:: mma sql bkg
Thread 17:: TLG main
4 simulator 0x101560240 0x100d08000 + 8749632
5 simulator 0x1014d0d80 0x100d08000 + 8162688
Thread 18:: libcurl Async H
3 simulator 0x10126d224 0x100d08000 + 5657124
Thread 19:: Download Manage
3 simulator 0x10126fda0 0x100d08000 + 5668256
Thread 20:: Shell main
0 libsystem_kernel.dylib 0x180d6b804 __accept + 8
1 simulator 0x101558c90 0x100d08000 + 8719504
2 simulator 0x101555eb4 0x100d08000 + 8707764
3 simulator 0x1014d0d68 0x100d08000 + 8162664
Thread 21:
2 libc++.1.dylib 0x180cda578 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 28
3 simulator 0x100dd0498 0x100d08000 + 820376
4 simulator 0x100dd035c 0x100d08000 + 820060
5 simulator 0x100dd0208 0x100d08000 + 819720
Thread 22:
1 simulator 0x100e31f08 0x100d08000 + 1220360
2 simulator 0x100e05174 0x100d08000 + 1036660
3 simulator 0x1016be84c 0x100d08000 + 10184780
Thread 23:: WebCore: Scrolling
7 CoreFoundation 0x180f059d0 CFRunLoopRun + 64
8 JavaScriptCore 0x19f079ae8 WTF::Detail::CallableWrapper<WTF::RunLoop::create(WTF::ASCIILiteral, WTF::ThreadType, WTF::Thread::QOS)::$_0, void>::call() + 52
9 JavaScriptCore 0x19f0ae84c WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 244
10 JavaScriptCore 0x19eedbb68 WTF::wtfThreadEntryPoint(void*) + 16
11 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
12 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 24:
0 libsystem_pthread.dylib 0x180d9f0e8 start_wqthread + 0
Thread 25:
Thread 26:
Thread 27:: Shell handler
3 simulator 0x100e313b4 0x100d08000 + 1217460
4 simulator 0x1015589c8 0x100d08000 + 8718792
5 simulator 0x101558048 0x100d08000 + 8716360
6 simulator 0x1015568b0 0x100d08000 + 8710320
7 simulator 0x1014d0d68 0x100d08000 + 8162664
Thread 28:
0 libsystem_kernel.dylib 0x180d67478 __recvfrom + 8
1 simulator 0x10155907c 0x100d08000 + 8720508
2 simulator 0x101558108 0x100d08000 + 8716552
3 simulator 0x100e2e7a0 0x100d08000 + 1206176
4 simulator 0x100e3603c 0x100d08000 + 1237052
5 simulator 0x1016be84c 0x100d08000 + 10184780
Thread 29:: JavaScriptCore libpas scavenger
2 JavaScriptCore 0x1a0514a20 scavenger_thread_main + 1328
3 libsystem_pthread.dylib 0x180da42e4 _pthread_start + 136
4 libsystem_pthread.dylib 0x180d9f0fc thread_start + 8
Thread 11 crashed with ARM Thread State (64-bit):
x0: 0xfc9d0020d9180118 x1: 0x0000000128f4c7a0 x2: 0x0000000000000001 x3: 0x0000000000000001
x4: 0x0000000000000000 x5: 0x00000000000100a8 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x1a4d5e68b0a5006f x9: 0x1a4d5e68b0a5006f x10: 0x0000000000000486 x11: 0x00000000002c0000
x12: 0x0000000000040000 x13: 0x0000000128f04080 x14: 0x0000000000004872 x15: 0x0000000000000000
x16: 0xd7960001021a8080 x17: 0x0000000000000000 x18: 0x0000000000000000 x19: 0xfc9d0020d9180118
x20: 0xfc9d0020d9180030 x21: 0x000000013c845a90 x22: 0x0000000000000100 x23: 0x0000000101e8e050
x24: 0x0000000101fc5cc8 x25: 0x0000000000000004 x26: 0x0000000101fc5000 x27: 0x0000000101f1f000
x28: 0x0000000000000000 fp: 0x000000016f9b2e70 lr: 0x0000000100e4d51c
sp: 0x000000016f9b2e60 pc: 0x00000001016c4204 cpsr: 0x60001000
far: 0xfc9d0020d9180118 esr: 0x92000004 (Data Abort) byte read Translation fault
Binary Images:
0x100d08000 - 0x101d67fff com.garmin.connectiq.simulator (7.4.3) <25e26045-70fb-33d3-bb8b-ac5b2063b202> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
0x102480000 - 0x10248bfff libobjc-trampolines.dylib (*) <3d687e9b-e092-3632-bc1d-74b19d492de0> /usr/lib/libobjc-trampolines.dylib
0x113b3c000 - 0x1141dffff com.apple.AGXMetal13-3 (324.6) <4127f44c-9853-3b87-b300-dc4614ed8bcc> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
0x115500000 - 0x115567fff com.apple.AppleMetalOpenGLRenderer (1.0) <a969aeaf-d20c-3296-b195-742e2b280d5e> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
0x11afe4000 - 0x11b8d3fff com.apple.audio.codecs.Components (7.0) <383b5b29-4e54-35da-a59f-a19118dfbf03> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x1809cc000 - 0x180a1dca3 libobjc.A.dylib (*) <b2882096-462b-3878-be2a-410f7b1a27fd> /usr/lib/libobjc.A.dylib
0x1849c7000 - 0x185e03fff com.apple.AppKit (6.9) <b88a44c1-d617-33dc-90ed-b6ab417c428e> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x180e0f000 - 0x181303fff com.apple.CoreFoundation (6.9) <190e6a36-fcaa-3ea3-94bb-7009c44653da> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x18c2ee000 - 0x18c5f5fff com.apple.HIToolbox (2.1.1) <950f1236-acaf-379d-819f-6c6b0b5deabd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x180a1e000 - 0x180a9ff3f dyld (*) <398a133c-9bcb-317f-a064-a40d3cea3c0f> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x180d62000 - 0x180d9cff7 libsystem_kernel.dylib (*) <eee9d0d3-dffc-37cb-9ced-b27cd0286d8c> /usr/lib/system/libsystem_kernel.dylib
0x180d9d000 - 0x180da9fff libsystem_pthread.dylib (*) <642faf7a-874e-37e6-8aba-2b0cc09a3025> /usr/lib/system/libsystem_pthread.dylib
0x180cb9000 - 0x180d46ffb libc++.1.dylib (*) <bbab286c-2e51-3d64-9ae3-a4102935fe32> /usr/lib/libc++.1.dylib
0x180bab000 - 0x180becfff libsystem_malloc.dylib (*) <1480b446-99f7-3757-9d4e-5ba3014a2726> /usr/lib/system/libsystem_malloc.dylib
0x19eed5000 - 0x1a0702fbf com.apple.JavaScriptCore (20620) <f61ed267-6231-3865-b890-881c8186dd0c> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)
Writable regions: Total=5.5G written=899K(0%) resident=899K(0%) swapped_out=0K(0%) unallocated=5.5G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG image 1168K 32
CG raster data 2880K 6
ColorSync 704K 36
CoreAnimation 1824K 59
CoreGraphics 48K 3
CoreImage 16K 1
CoreUI image data 4048K 32
Dispatch continuations 64.0M 1
Foundation 48K 2
Kernel Alloc Once 32K 1
MALLOC 1.2G 182
MALLOC guard page 288K 18
STACK GUARD 56.5M 30
Stack 23.9M 47
VM_ALLOCATE 135.4M 419
VM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)
WebKit Malloc 192.1M 5
__AUTH 5722K 698
__AUTH_CONST 73.2M 947
__CTF 824 1
__DATA 28.6M 929
__DATA_CONST 25.4M 957
__DATA_DIRTY 2787K 344
__FONT_DATA 2352 1
__GLSLBUILTINS 5174K 1
__INFO_FILTER 8 1
__LINKEDIT 610.8M 6
__OBJC_RW 2374K 1
__TEXT 1.1G 979
__TPRO_CONST 272K 2
mapped file 350.6M 65
owned unmapped memory 1312K 1
page table in kernel 899K 1
shared memory 896K 15
TOTAL 7.7G 5826
TOTAL, minus reserved VM space 3.9G 5826
Full Report
{"app_name":"simulator","timestamp":"2025-02-28 18:18:26.00 +0100","app_version":"7.4.3","slice_uuid":"25e26045-70fb-33d3-bb8b-ac5b2063b202","build_version":"7.4.3","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.3.1 (24D70)","roots_installed":0,"name":"simulator","incident_id":"2F6E4442-3987-4F1C-A068-3A5B70145C69"}
"uptime" : 400000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir10,1",
"coalitionID" : 843,
"osVersion" : {
"train" : "macOS 15.3.1",
"build" : "24D70",
"releaseType" : "User"
"captureTime" : "2025-02-28 18:18:22.5964 +0100",
"codeSigningMonitor" : 1,
"incident" : "2F6E4442-3987-4F1C-A068-3A5B70145C69",
"pid" : 25524,
"translated" : false,
"cpuType" : "ARM-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2025-02-28 11:30:08.7426 +0100",
"procStartAbsTime" : 9215883785263,
"procExitAbsTime" : 9713387443455,
"procName" : "simulator",
"procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"bundleInfo" : {"CFBundleShortVersionString":"7.4.3","CFBundleVersion":"7.4.3","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
"storeInfo" : {"deviceIdentifierForVendor":"8328F350-2F45-5923-BD5F-2C5ABB306647","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.garmin.connectiq.simulator",
"crashReporterKey" : "277CCC3B-2E88-EAA7-7D3F-B4E208A73F60",
"codeSigningID" : "com.garmin.connectiq.simulator",
"codeSigningTeamID" : "72ES32VZUA",
"codeSigningFlags" : 570503953,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"instructionByteStream" : {"beforePC":"YAAAtOvd\/5csJAuU4AMTqv17Qan0T8KowANf1vRPvqn9ewGp\/UMAkQ==","atPC":"EwBA+TMCALRoRkC5CAEANWgiAZEU\/d\/IVCcLlJ8CAOthAABUQACAUg=="},
"bootSessionUUID" : "0ABE1A4D-B425-48E7-A9BC-1265FFF9416A",
"wakeTime" : 5610,
"sleepWakeUUID" : "1F35A1A6-C913-47F9-8482-08E716F0A450",
"sip" : "enabled",
"vmRegionInfo" : "0xffff8020d9180118 is not in any region. Bytes after previous region: 18446602996264698137 \n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n owned unmapped memory unmapped-unmapped [ 1312K] rw-\/rw- SM=PRV owned physical footprint (unmapped)\n---> \n UNUSED SPACE AT END",
"exception" : {"codes":"0x0000000000000001, 0xfc9d0020d9180118","rawCodes":[1,-244038663726956264],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0xfc9d0020d9180118 -> 0xffff8020d9180118 (possible pointer authentication failure)"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":25524},
"vmregioninfo" : "0xffff8020d9180118 is not in any region. Bytes after previous region: 18446602996264698137 \n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n owned unmapped memory unmapped-unmapped [ 1312K] rw-\/rw- SM=PRV owned physical footprint (unmapped)\n---> \n UNUSED SPACE AT END",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 11,
"threads" : [{"id":24130649,"threadState":{"x":[{"value":5235373008},{"value":8404390693},{"value":0},{"value":28},{"value":4692513632},{"value":3},{"value":2},{"value":6158231368},{"value":0},{"value":8404390693},{"value":7677300637},{"value":127},{"value":37},{"value":5310166592},{"value":4326959293},{"value":4326959288},{"value":6452781520,"symbolLocation":0,"symbol":"objc_autorelease"},{"value":8369713160},{"value":0},{"value":5235373008},{"value":4620057616},{"value":4620056688},{"value":6158240112},{"value":6158243848},{"value":4327893032},{"value":4327893031},{"value":4327893030},{"value":4327011376,"symbolLocation":8,"symbol":"guard variable for wxAnyValueTypeImpl<wxVariant>::sm_instance"},{"value":4327992280}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6520096364},"cpsr":{"value":536875008},"fp":{"value":6158234272},"sp":{"value":6158234240},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":6452781552},"far":{"value":5235373008}},"queue":"com.apple.main-thread","frames":[{"imageOffset":57840,"symbol":"objc_autorelease","symbolLocation":32,"imageIndex":5},{"imageOffset":284268,"symbol":"-[NSMenuItem dealloc]","symbolLocation":40,"imageIndex":6},{"imageOffset":11108720,"imageIndex":0},{"imageOffset":10748388,"imageIndex":0},{"imageOffset":11848536,"imageIndex":0},{"imageOffset":792152,"imageIndex":0},{"imageOffset":706728,"imageIndex":0},{"imageOffset":10242052,"imageIndex":0},{"imageOffset":10247512,"imageIndex":0},{"imageOffset":10247908,"imageIndex":0},{"imageOffset":10247308,"imageIndex":0},{"imageOffset":10246320,"imageIndex":0},{"imageOffset":9416900,"imageIndex":0},{"imageOffset":10116352,"imageIndex":0},{"imageOffset":510952,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__","symbolLocation":36,"imageIndex":7},{"imageOffset":510676,"symbol":"__CFRunLoopDoObservers","symbolLocation":552,"imageIndex":7},{"imageOffset":508164,"symbol":"__CFRunLoopRun","symbolLocation":788,"imageIndex":7},{"imageOffset":505652,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":7},{"imageOffset":1094960,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":8},{"imageOffset":1118588,"symbol":"ReceiveNextEventCommon","symbolLocation":216,"imageIndex":8},{"imageOffset":1119496,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":8},{"imageOffset":243784,"symbol":"_DPSNextEvent","symbolLocation":660,"imageIndex":6},{"imageOffset":10099748,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":688,"imageIndex":6},{"imageOffset":190580,"symbol":"-[NSApplication run]","symbolLocation":480,"imageIndex":6},{"imageOffset":11082244,"imageIndex":0},{"imageOffset":10118800,"imageIndex":0},{"imageOffset":9594016,"imageIndex":0},{"imageOffset":9414092,"imageIndex":0},{"imageOffset":10825804,"imageIndex":0},{"imageOffset":9782100,"imageIndex":0},{"imageOffset":258760,"imageIndex":0},{"imageOffset":25204,"symbol":"start","symbolLocation":2840,"imageIndex":9}]},{"id":24130720,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":101219494264832},{"value":0},{"value":101219494264832},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":23567},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8369020408},{"value":0},{"value":4294967295},{"value":2},{"value":101219494264832},{"value":0},{"value":101219494264832},{"value":6161670248},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456563204},"cpsr":{"value":4096},"fp":{"value":6161670096},"sp":{"value":6161670016},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456487764},"far":{"value":0}},"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":11},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":11},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":11},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":11},{"imageOffset":514636,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":7},{"imageOffset":508588,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":7},{"imageOffset":505652,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":7},{"imageOffset":1442424,"symbol":"_NSEventThread","symbolLocation":148,"imageIndex":6},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130721,"name":"TSK bkgd","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6162247272},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300163576},{"value":5300163640},{"value":6162247904},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6162247392},"sp":{"value":6162247248},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8162636,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130722,"name":"NFM_Region_0","threadState":{"x":[{"value":260},{"value":0},{"value":103680},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6162820456},{"value":0},{"value":2560},{"value":10995116280322},{"value":10995116280322},{"value":2560},{"value":0},{"value":10995116280320},{"value":305},{"value":8369037944},{"value":0},{"value":5300165752},{"value":5300165816},{"value":6162821344},{"value":0},{"value":0},{"value":103680},{"value":104193},{"value":104448},{"value":5300164520},{"value":65535}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6162820576},"sp":{"value":6162820432},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8671884,"imageIndex":0},{"imageOffset":8162688,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130723,"name":"Cache Mngr","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6163393912},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300166528},{"value":5300166632},{"value":6163394784},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4294967295},{"value":6163394304}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6163394032},"sp":{"value":6163393888},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8160756,"imageIndex":0},{"imageOffset":8194548,"imageIndex":0},{"imageOffset":8379564,"imageIndex":0},{"imageOffset":8365744,"imageIndex":0},{"imageOffset":8162688,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130724,"name":"IOPAppMain","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6163967512},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300167480},{"value":5300167544},{"value":6163968224},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6163967632},"sp":{"value":6163967488},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5545500,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130725,"name":"ant_main","threadState":{"x":[{"value":260},{"value":0},{"value":1338368},{"value":0},{"value":0},{"value":65704},{"value":2},{"value":998379000},{"value":1798401},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300168440},{"value":5300168504},{"value":1},{"value":998379000},{"value":2},{"value":1338368},{"value":1798401},{"value":1798656},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756416},"cpsr":{"value":2684358656},"fp":{"value":6164541040},"sp":{"value":6164540896},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30912,"symbol":"_pthread_cond_wait","symbolLocation":1248,"imageIndex":12},{"imageOffset":8161348,"imageIndex":0},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5354968,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130726,"name":"GPS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6165114472},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300168840},{"value":5300168904},{"value":6165115104},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6165114592},"sp":{"value":6165114448},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8162636,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130727,"name":"SNS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6165687912},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300167880},{"value":5300167944},{"value":6165688544},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6165688032},"sp":{"value":6165687888},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8162636,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130728,"name":"fit activity","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6166259736},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300169240},{"value":5300169304},{"value":6166261984},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":4328227048},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6166259856},"sp":{"value":6166259712},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5800516,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130729,"name":"ftm main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998984000},{"value":5319681},{"value":0},{"value":256},{"value":1099511628034},{"value":1099511628034},{"value":256},{"value":0},{"value":1099511628032},{"value":305},{"value":8369037944},{"value":0},{"value":5300169640},{"value":5300169704},{"value":1},{"value":998984000},{"value":0},{"value":256},{"value":5319681},{"value":5319936},{"value":4327002112,"symbolLocation":33240,"symbol":"guard variable for wxAnyValueTypeImpl<std::__1::function<void ()>>::sm_instance"},{"value":1}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756416},"cpsr":{"value":2684358656},"fp":{"value":6166833584},"sp":{"value":6166833440},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30912,"symbol":"_pthread_cond_wait","symbolLocation":1248,"imageIndex":12},{"imageOffset":8161348,"imageIndex":0},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5862188,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"triggered":true,"id":24130730,"name":"TVM main","threadState":{"x":[{"value":18202705409982595352},{"value":4982097824},{"value":1},{"value":1},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":1895274821926060143},{"value":1895274821926060143},{"value":1158},{"value":2883584},{"value":262144},{"value":4981801088},{"value":18546},{"value":0},{"value":15534603968991363200},{"value":0},{"value":0},{"value":18202705409982595352},{"value":18202705409982595120},{"value":5310274192},{"value":256},{"value":4327006288,"symbolLocation":1456,"symbol":"guard variable for RequestConsolidator::getInstance()::sSelf"},{"value":4328283336},{"value":4},{"value":4328280064},{"value":4327600128},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4309964060},"cpsr":{"value":1610616832},"fp":{"value":6167408240},"sp":{"value":6167408224},"esr":{"value":2449473540,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4318839300,"matchesCrashFrame":1},"far":{"value":18202705409982595352}},"frames":[{"imageOffset":10207748,"imageIndex":0},{"imageOffset":1332508,"imageIndex":0},{"imageOffset":8196116,"imageIndex":0},{"imageOffset":7795016,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130731,"name":"TVM defrag","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6167981672},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300170440},{"value":5300170504},{"value":6167982304},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6167981792},"sp":{"value":6167981648},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8162636,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130736,"name":"parse main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998997000},{"value":5313537},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5301354168},{"value":5301354232},{"value":1},{"value":998997000},{"value":0},{"value":256},{"value":5313537},{"value":5313792},{"value":922337203685477580},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756416},"cpsr":{"value":2684358656},"fp":{"value":6168554048},"sp":{"value":6168553904},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30912,"symbol":"_pthread_cond_wait","symbolLocation":1248,"imageIndex":12},{"imageOffset":8161348,"imageIndex":0},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":128140,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130737,"name":"GPX archive trk","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6169128344},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5301354568},{"value":5301354632},{"value":6169129184},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":5400},{"value":214749}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6169128464},"sp":{"value":6169128320},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8750204,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130738,"name":"URM Main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6169701960},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5301350776},{"value":5301350840},{"value":6169702624},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6169702080},"sp":{"value":6169701936},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5688360,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130739,"name":"mma sql bkg","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6170275432},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5301351176},{"value":5301351240},{"value":6170276064},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6170275552},"sp":{"value":6170275408},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8162636,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130765,"name":"TLG main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":44987},{"value":999398000},{"value":257},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300171224},{"value":5300171288},{"value":1},{"value":999398000},{"value":44987},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756416},"cpsr":{"value":2684358656},"fp":{"value":6171422320},"sp":{"value":6171422176},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30912,"symbol":"_pthread_cond_wait","symbolLocation":1248,"imageIndex":12},{"imageOffset":8161348,"imageIndex":0},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":8749632,"imageIndex":0},{"imageOffset":8162688,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130766,"name":"libcurl Async H","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6171995624},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300172584},{"value":5300172648},{"value":6171996384},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":6171995920},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6171995744},"sp":{"value":6171995600},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5657124,"imageIndex":0},{"imageOffset":8162688,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130767,"name":"Download Manage","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6172568952},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8369037944},{"value":0},{"value":5300172984},{"value":5300173048},{"value":6172569824},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4322762517,"symbolLocation":398669,"symbol":"std::__1::piecewise_construct"},{"value":4328194216}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6172569072},"sp":{"value":6172568928},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8166104,"imageIndex":0},{"imageOffset":5668256,"imageIndex":0},{"imageOffset":8162688,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130768,"name":"Shell main","threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":7},{"value":4643531072},{"value":10},{"value":2},{"value":0},{"value":4317352288},{"value":4317352128},{"value":2172813600},{"value":2172682528},{"value":2172682528},{"value":2172813600},{"value":4294967295},{"value":0},{"value":30},{"value":0},{"value":0},{"value":4439976704},{"value":4327006208,"symbolLocation":1376,"symbol":"guard variable for RequestConsolidator::getInstance()::sSelf"},{"value":4328386560},{"value":4328387972},{"value":4328386560},{"value":2048},{"value":4328386560},{"value":4328387968},{"value":16},{"value":4}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4317351056},"cpsr":{"value":1610616832},"fp":{"value":6173142800},"sp":{"value":6173142736},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456522756},"far":{"value":0}},"frames":[{"imageOffset":38916,"symbol":"__accept","symbolLocation":8,"imageIndex":11},{"imageOffset":8719504,"imageIndex":0},{"imageOffset":8707764,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24130771,"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":136568,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":28,"imageIndex":13},{"imageOffset":820376,"imageIndex":0},{"imageOffset":820060,"imageIndex":0},{"imageOffset":819720,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}],"threadState":{"x":[{"value":260},{"value":0},{"value":134912},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6174862904},{"value":0},{"value":256},{"value":1099511628034},{"value":1099511628034},{"value":256},{"value":0},{"value":1099511628032},{"value":305},{"value":8369037944},{"value":0},{"value":5310274448},{"value":5310274512},{"value":6174863584},{"value":0},{"value":0},{"value":134912},{"value":134913},{"value":135168},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6174863024},"sp":{"value":6174862880},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}}},{"id":24130772,"frames":[{"imageOffset":38916,"symbol":"__accept","symbolLocation":8,"imageIndex":11},{"imageOffset":1220360,"imageIndex":0},{"imageOffset":1036660,"imageIndex":0},{"imageOffset":10184780,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}],"threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":6175436144},{"value":6454790276,"symbolLocation":0,"symbol":"szone_malloc_type_calloc"},{"value":4294967248},{"value":1},{"value":0},{"value":1},{"value":1895274821926060143},{"value":514},{"value":1430619136},{"value":32768},{"value":5031084160},{"value":8239},{"value":1},{"value":30},{"value":0},{"value":0},{"value":4620289280},{"value":5031131088},{"value":4327602280},{"value":4309668368},{"value":6175436536},{"value":4327011409,"symbolLocation":41,"symbol":"guard variable for wxAnyValueTypeImpl<wxVariant>::sm_instance"},{"value":6175436488},{"value":4328005632},{"value":6175436800},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4309851912},"cpsr":{"value":1610616832},"fp":{"value":6175436192},"sp":{"value":6175436160},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456522756},"far":{"value":0}}},{"id":24138444,"name":"WebCore: Scrolling","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":547569675534336},{"value":0},{"value":547569675534336},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":127491},{"value":193024},{"value":0},{"value":18446744073709551569},{"value":8369020408},{"value":0},{"value":4294967295},{"value":2},{"value":547569675534336},{"value":0},{"value":547569675534336},{"value":6180020184},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456563204},"cpsr":{"value":4096},"fp":{"value":6180020032},"sp":{"value":6180019952},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456487764},"far":{"value":0}},"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":11},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":11},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":11},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":11},{"imageOffset":514636,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":7},{"imageOffset":508588,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":7},{"imageOffset":505652,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":7},{"imageOffset":1010128,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":7},{"imageOffset":1723112,"symbol":"WTF::Detail::CallableWrapper<WTF::RunLoop::create(WTF::ASCIILiteral, WTF::ThreadType, WTF::Thread::QOS)::$_0, void>::call()","symbolLocation":52,"imageIndex":15},{"imageOffset":1939532,"symbol":"WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*)","symbolLocation":244,"imageIndex":15},{"imageOffset":27496,"symbol":"WTF::wtfThreadEntryPoint(void*)","symbolLocation":16,"imageIndex":15},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24402925,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":12}],"threadState":{"x":[{"value":6215004160},{"value":204311},{"value":6214467584},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6215004160},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456733928},"far":{"value":0}}},{"id":24403830,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":12}],"threadState":{"x":[{"value":6215577600},{"value":80939},{"value":6215041024},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6215577600},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456733928},"far":{"value":0}}},{"id":24407897,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":12}],"threadState":{"x":[{"value":6158807040},{"value":0},{"value":6158270464},{"value":0},{"value":278531},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6158807040},"esr":{"value":0,"description":" Address size fault"},"pc":{"value":6456733928},"far":{"value":0}}},{"id":24408192,"name":"Shell handler","threadState":{"x":[{"value":260},{"value":0},{"value":3840},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6176583048},{"value":0},{"value":768},{"value":3298534884098},{"value":3298534884098},{"value":768},{"value":0},{"value":3298534884096},{"value":305},{"value":8369037944},{"value":0},{"value":4327577824},{"value":4327577920},{"value":6176583904},{"value":0},{"value":0},{"value":3840},{"value":3841},{"value":4096},{"value":4327019840},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6176583168},"sp":{"value":6176583024},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":8160756,"imageIndex":0},{"imageOffset":1217460,"imageIndex":0},{"imageOffset":8718792,"imageIndex":0},{"imageOffset":8716360,"imageIndex":0},{"imageOffset":8710320,"imageIndex":0},{"imageOffset":8162664,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]},{"id":24408193,"frames":[{"imageOffset":21624,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":11},{"imageOffset":8720508,"imageIndex":0},{"imageOffset":8716552,"imageIndex":0},{"imageOffset":1206176,"imageIndex":0},{"imageOffset":1237052,"imageIndex":0},{"imageOffset":10184780,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}],"threadState":{"x":[{"value":4},{"value":0},{"value":12},{"value":0},{"value":0},{"value":0},{"value":2},{"value":0},{"value":4317352008},{"value":154015},{"value":1548097},{"value":503360},{"value":4769988396},{"value":1},{"value":4769972224},{"value":613548112},{"value":29},{"value":8369038040},{"value":0},{"value":12},{"value":4672634976},{"value":4672634928},{"value":12},{"value":4770532688},{"value":4770502848},{"value":32},{"value":9223372036854775799},{"value":3},{"value":4770618032}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4317352060},"cpsr":{"value":1610616832},"fp":{"value":6160526496},"sp":{"value":6160526464},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456505464},"far":{"value":0}}},{"id":24408227,"name":"JavaScriptCore libpas scavenger","threadState":{"x":[{"value":260},{"value":0},{"value":9986816},{"value":0},{"value":0},{"value":160},{"value":0},{"value":99998896},{"value":6182317720},{"value":0},{"value":11008},{"value":47279000005378},{"value":47279000005378},{"value":11008},{"value":0},{"value":47279000005376},{"value":305},{"value":8369037944},{"value":0},{"value":12884961344},{"value":12884961408},{"value":6182318304},{"value":99998896},{"value":0},{"value":9986816},{"value":9994497},{"value":9994752},{"value":6182318304},{"value":8197783552,"symbolLocation":1312,"symbol":"_MergedGlobals"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6456756372},"cpsr":{"value":1610616832},"fp":{"value":6182317840},"sp":{"value":6182317696},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6456501996},"far":{"value":0}},"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":11},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":12},{"imageOffset":23329312,"symbol":"scavenger_thread_main","symbolLocation":1328,"imageIndex":15},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":12},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":12}]}],
"usedImages" : [
"source" : "P",
"arch" : "arm64",
"base" : 4308631552,
"CFBundleShortVersionString" : "7.4.3",
"CFBundleIdentifier" : "com.garmin.connectiq.simulator",
"size" : 17170432,
"uuid" : "25e26045-70fb-33d3-bb8b-ac5b2063b202",
"path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
"name" : "simulator",
"CFBundleVersion" : "7.4.3"
"source" : "P",
"arch" : "arm64e",
"base" : 4333240320,
"size" : 49152,
"uuid" : "3d687e9b-e092-3632-bc1d-74b19d492de0",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 4625514496,
"CFBundleShortVersionString" : "324.6",
"CFBundleIdentifier" : "com.apple.AGXMetal13-3",
"size" : 6963200,
"uuid" : "4127f44c-9853-3b87-b300-dc4614ed8bcc",
"path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3",
"name" : "AGXMetal13_3",
"CFBundleVersion" : "324.6"
"source" : "P",
"arch" : "arm64e",
"base" : 4652531712,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
"size" : 425984,
"uuid" : "a969aeaf-d20c-3296-b195-742e2b280d5e",
"path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
"name" : "AppleMetalOpenGLRenderer",
"CFBundleVersion" : "1"
"source" : "P",
"arch" : "arm64e",
"base" : 4747837440,
"CFBundleShortVersionString" : "7.0",
"CFBundleIdentifier" : "com.apple.audio.codecs.Components",
"size" : 9371648,
"uuid" : "383b5b29-4e54-35da-a59f-a19118dfbf03",
"path" : "\/System\/Library\/Components\/AudioCodecs.component\/Contents\/MacOS\/AudioCodecs",
"name" : "AudioCodecs",
"CFBundleVersion" : "7.0"
"source" : "P",
"arch" : "arm64e",
"base" : 6452723712,
"size" : 335012,
"uuid" : "b2882096-462b-3878-be2a-410f7b1a27fd",
"path" : "\/usr\/lib\/libobjc.A.dylib",
"name" : "libobjc.A.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6519812096,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 21221376,
"uuid" : "b88a44c1-d617-33dc-90ed-b6ab417c428e",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2575.40.6"
"source" : "P",
"arch" : "arm64e",
"base" : 6457192448,
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5197824,
"uuid" : "190e6a36-fcaa-3ea3-94bb-7009c44653da",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "3302.1.400"
"source" : "P",
"arch" : "arm64e",
"base" : 6646849536,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3178496,
"uuid" : "950f1236-acaf-379d-819f-6c6b0b5deabd",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "arm64e",
"base" : 6453059584,
"size" : 532288,
"uuid" : "398a133c-9bcb-317f-a064-a40d3cea3c0f",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "arm64e",
"base" : 6456483840,
"size" : 241656,
"uuid" : "eee9d0d3-dffc-37cb-9ced-b27cd0286d8c",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6456725504,
"size" : 53248,
"uuid" : "642faf7a-874e-37e6-8aba-2b0cc09a3025",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6455791616,
"size" : 581628,
"uuid" : "bbab286c-2e51-3d64-9ae3-a4102935fe32",
"path" : "\/usr\/lib\/libc++.1.dylib",
"name" : "libc++.1.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6454685696,
"size" : 270336,
"uuid" : "1480b446-99f7-3757-9d4e-5ba3014a2726",
"path" : "\/usr\/lib\/system\/libsystem_malloc.dylib",
"name" : "libsystem_malloc.dylib"
"source" : "P",
"arch" : "arm64e",
"base" : 6961319936,
"CFBundleShortVersionString" : "20620",
"CFBundleIdentifier" : "com.apple.JavaScriptCore",
"size" : 25354176,
"uuid" : "f61ed267-6231-3865-b890-881c8186dd0c",
"path" : "\/System\/Library\/Frameworks\/JavaScriptCore.framework\/Versions\/A\/JavaScriptCore",
"name" : "JavaScriptCore",
"CFBundleVersion" : "20620.2.4.11.5"
"sharedCache" : {
"base" : 6452248576,
"size" : 4865835008,
"uuid" : "d272b91e-f9f0-3854-b5b9-508b21c25dcc"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)\nWritable regions: Total=5.5G written=899K(0%) resident=899K(0%) swapped_out=0K(0%) unallocated=5.5G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nCG image 1168K 32 \nCG raster data 2880K 6 \nColorSync 704K 36 \nCoreAnimation 1824K 59 \nCoreGraphics 48K 3 \nCoreImage 16K 1 \nCoreUI image data 4048K 32 \nDispatch continuations 64.0M 1 \nFoundation 48K 2 \nKernel Alloc Once 32K 1 \nMALLOC 1.2G 182 \nMALLOC guard page 288K 18 \nSTACK GUARD 56.5M 30 \nStack 23.9M 47 \nVM_ALLOCATE 135.4M 419 \nVM_ALLOCATE (reserved) 3.9G 1 reserved VM address space (unallocated)\nWebKit Malloc 192.1M 5 \n__AUTH 5722K 698 \n__AUTH_CONST 73.2M 947 \n__CTF 824 1 \n__DATA 28.6M 929 \n__DATA_CONST 25.4M 957 \n__DATA_DIRTY 2787K 344 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 610.8M 6 \n__OBJC_RW 2374K 1 \n__TEXT 1.1G 979 \n__TPRO_CONST 272K 2 \nmapped file 350.6M 65 \nowned unmapped memory 1312K 1 \npage table in kernel 899K 1 \nshared memory 896K 15 \n=========== ======= ======= \nTOTAL 7.7G 5826 \nTOTAL, minus reserved VM space 3.9G 5826 \n",
"legacyInfo" : {
"threadTriggered" : {
"name" : "TVM main"
"logWritingSignature" : "e230cd19e25e62954854e322f9e3896d905d915b",
"trialInfo" : {
"rollouts" : [
"rolloutId" : "61675b89201f677a9a4cbd65",
"factorPackIds" : {
"HEALTH_FEATURE_AVAILABILITY" : "65a855f5f087695cfac03d1f"
"deploymentId" : 240000170
"rolloutId" : "654d8c0661e7447155256fcd",
"factorPackIds" : {
"SIRI_TEXT_TO_SPEECH" : "67bc8efbb5bba227d9922cdc"
"deploymentId" : 240000284
"experiments" : [
Model: MacBookAir10,1, BootROM 11881.81.4, proc 8:4:4 processors, 8 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: LPDDR4, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Sep 28 2024 04:40:32 version 18.20.462.0.7.8.175 FWID 01-10fa77df
IO80211_driverkit-1345.10 "IO80211_driverkit-1345.10" Dec 14 2024 17:47:07
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Air, Apple Inc.
